Pulley fell off ***question number two***
So my crank pulley fell off the crank yesterday. I have a SLP UDP and when it fell off it got scratched up and what not but where the belts ride it looks perfect. My question is, will the pulley be off balance? Should I get a new one or will this one be fine?
Install the used crankshaft balancer bolt.
Tighten the USED crankshaft balancer bolt to 330 N·m (240 lb ft).
Remove the used crankshaft balancer bolt.
Important: The nose of the crankshaft should be recessed 2.40-4.48 mm (0.094-0.176 in) into the balancer bore.
Install the NEW crankshaft balancer bolt.
Tighten the NEW crankshaft balancer bolt a first pass to 50 N·m (37 lb ft).
Tighten the crankshaft balancer bolt a final pass to 140 degrees using the J 36660-A .
