LY6 6.0l cam and combo questions
Ok so I just brought home a 20K mile LY6 6.0, for those that arent familiar with the rpo LY6, it has factory installed #823 L92 heads.
My questions are about the rpm limits of the factory bottom end(rods/bolts/pistons/crank), so that I can choose a cam. How high of rpms will theese thinks take before failure? I'd like to spin it to 7000ish.
I really dont want to pull the heads off, but if I do, I will do a quick port cleanup in the bowl area of both the intake and exhaust, and mill the heads.
Any cam recomendations? car is a 67 camaro, TKO 600 5 speed, 4.10 gears, I will use an edelbrock victor jr carb intake w/either a 750 or 850(I have both), msd 6012 to control the ignition, and a set of 1 7/8" headers.
Thanks in advance for any advice.
Barrett
Barrett
Man, I'd love to hear any responses to this also. I'm looking at getting the same engine and put it in a 1978 Z28 with a 5 or 6 speed tremec. But I am trying to keep the fuel injection and electronics on it.
Anything I've read about these short blocks says they can handle just about any street car could throw at them. One article said 1000HP. I don't know if I'd believe that. But I'm sure a 600HP engine would stay together.
The rods and pistons are the weak parts. No way you will see an LQ4 rod live at 1000hp(maybe one pass). The cranks are living at 1,000hp for quite a few guys here. Not sure if you know but they are forged. If you are shooting for lower hp upgrade the rod bolts to arp along with the mains. Pick a good forged piston and call it a day.
the LY6 has forged rods and the hypereutectic pistons. The rods in the LY6 are the same as what's in the LS2/LQ9 ... I'd say spinning to 6500-7000 isn't a stretch. Just gotta watch that PTV clearance.
edit: oh, and are you keeping VVT? If not, why?
car is almost complete - waiting for my L92 victor JR. its been on backorder since the end of march. I am not going to run VVT untill I convert to EFI, probably in a couple years .
As soon as it is runs,its going to the track w/ stock LY6 long block /vicJr /carb /eddy headers /TKO600 /4.10's, and then an LSr comp cam :-) which is on the shelf at home, ready to go! tic toc get them intakes out of the foundry edelbrock!!!!!!!!!
