6800-7000 rpm, how reliable, 05 GTO
I am preparing to swap in some new pieces. Flowtech ported 243's, PAC 1521's, Comp Cams Ultra Pro-Magnum LSx Rocker Kit, Morel link-bar lifters, 5/16 push rods, EDC 235/241 .614 on 112. Already on the Goat are a FAST 102 and Vararam.
If this setup is still making power in the 6800-7000 range will a stock bottom end hold up or just become a huge bomb with a short fuse. Shooting for 400 to the wheels uncorrected.
how many miles are on your engine? personally i wouldnt go through all that work if the engine has more than 70k miles depending on how hard you drive your car. i mean if your going to tear your whole enigne apart you might as well do pistons and everything. you might want to consider puttng those parts on a new short block! and do you plan to do the work yourself?
Currently the power peak was right at 6600-6700 with just cam,LT's,exhuast, factory airbox. You guys are good!
Mine shifts 1-2 at 7000rpm, 2-3 at 6800rpm, and 3-4 and 6600rpm (never make it that far) ... rev limiter is set at 7200rpm. I've had it set up like this for over 60k miles now ... no issues. I do change my valve springs every ~35k and use the lightweight LS6 valves.
Thanks for all of the info. Sounds like a resaonable gamble to spin it to those levels. I should of said it up front. My question about the rpm's was geared towards road racing. The gearing of a car just does not work perfectly at every track and sometimes a corner comes up and it just does not make any sense to grab the next gear for 1-2 seconds. It just ends up being faster to hold on to whatever gear your in even though you are out of your power band.
I ran my Corvette to 7000 on a regular basis when it had the 01 6.0 with 130k mi on it. I had upgraded rod bolts, stock bottom end other than that. Now I run my 08 6.2 up there with just upgraded rod bolts. No problems on either one. I did replace the main bearings on the 6.0 but I don't think it had anything to do with my operating range, probably the mileage had more to do with it.
Changing rod bolts without checking the concentracy (sp?) of the rod bearing could be a gamble. People do it and I've seen people have no issues, or get the bearings to tight/lose. It's best to measure the bolts stretch rather than torque value as the type of lube and bolt materials can change the torque requirement.
