LS7 - Anyone know what the EGT is?
One consideration is to run Ti exh valves. After speaking with four of the most reputable Ti vlv sources to determine what I might need to do to the heads (seats, coating, finish), I was told to NOT run Ti in the exhaust on a street build if EGT's would be in excess of 1400 deg F where longevity was a primary consideration (and it is). Actually, 1400 was the max and it would be preferable to keep EGT's under 1400.
If I had a baseline from OEM, that would be most helpful as I will not be running an OE cam with the same exh opening point.
I like to figure things out on my own, verse following the crowd. Sometimes I end up following, but only after I detirmine they are going where I want to go.
Unless you are going to constantly turn this motor past the 7500rpm mark you will not need a Ti valve.
So, in conclusion if your answer is no to the two things I just stated then again, you will NOT need a Ti valve.
Don't take our word for it, Call HKE, AES, LME, KUP, Billy Briggs and see what they say. They will tell just what we said.
If you don't want to take our advice or their's then just do like you said. Figure it out on your own.
Adding spring pressure and running lighter short travel lifters will enable the valve train to run at oem rpms, but why do that if it can be avoided? A lighter valve train is always preferable to compensating with spring pressure.
I've spoken to WCCH, AI, Linernoise, AFD, RPM Motors, Rehre Morrison, Texas Speed and I have also had conversations with a program manager for one of GM's aftermarket racing department, as well as Ferrea, Trick Ti, Del West and Xceldyne. Each one has there own opinions and recommendations.
I'm just flushing out my options guys.
Lets start over. It seems you are trying to kill a cockroach with a bazooka here. What kinda car is this and what is the intended usage? Are you road racing some kinda car that will see 8000+ rpms on a roadcourse or is this a street car that will have a H/C pacakge and will see the occasional track romp?
