Gen 4 Rod? I thought I had gen 3s
Ok so I'm new to the ls motors, built many old sbc, ford's etc. anyways I bought a 2004 lm7 and to my knowledge they were gen 3s correct? I learned after I had the short block together that gen 4 rods were better, I had to pull piston and rods back out to read Gap my rings because I'm going boost so while I was there did some digging into the rod differences and it seems mine fit the gen 4 description, there 15mm thick and squared on both ends? any info is appreciated
if you have gen 4 rods youd know, theyre much more beefier! they almost look identical to a scat aftermarket rod
check out this post for the difference
https://ls1tech.com/forums/forced-in...l#post18227154
Restricted User
04 was the only year that you might find a Gen 4 rod with a pressed pin.
They were phasing out the old rods but hadn't finished phasing out the old pistons, so the Gen 4 rod was bushed for a pressed pin. Those aren't very common.
there are some mix-match "gen 3.5" piston & rods out there.
check the last picture in this post (#337)
https://ls1tech.com/forums/conversio...l#post19439674
clearly a gen 4 shaped rod.
no locks or provisions in the piston for them & pin is press fit.
