EMC similar format with *New info & products*
#141
#145
big hammer:
Stock ls3 castings are the last of the hotrodders heads
Darth_V8r:
Imo the top reason to do ls3 heads is intake options
I just Hope FAST makes runners for the others. If not guys should go to the MSD for higher RPM if that's what there looking for in a low profile package.
Darth about the Pontiac I really *like the *Buick it is and was a big block in a small package compared to All other Big Blocks. But it Doesn't have the supporting hardware to make big Hp: Heads and oiling are #1 on the list.
#147
That's just how it goes brother. There's a guy who did his own shorter FAST Ls7 runners some time ago while FAST was making/selling them for the Ls3.
https://www.corvetteforum.com/forums...2-runners.html
https://www.corvetteforum.com/forums...ces-639wh.html
#151
HioSSilver
I may have to do my own short runner ls7 fast.
I also made some calls again today after reading....Dart block it is for choice.
Cylinder Wall Thickness, min. ................................….. .275" @ 4.185"
With a 4.220 bore still leaves more wall thickness .235 than the DART SHP: .230 wall thickness @ 4.185. Also spoke with the guys @ MLS they said that the 4.250 bore gasket is sold with a disclaimer and they will or don't sell it and they don't back it. The most MLS is willing to warranty is there 4.225 gasket set. And if you EVER ask or wanted to Know, the CGI Dart: Ls Next Iron block goes for a Cool..........$5000.00 and takes 10 weeks to make.
#152
Idk......what's worse than a fe?.....lol
Oldsmibile be a Y block
Good idea on checking runner length of the mid runner ls3. But the dude that shortened his ls7 runners seemed to be in the ballpark.
#153
That's pretty much impossible with a 4.4" bore spacing. Probably a typo, should be .215" minimum wall thickness at 4.185" bore.
#155
Crappy oiling.............check
gigantic diesel bus sized mains.........check
90 pound crankshaft...........check
crap-tastic Arma Steel weak *** rods..........check
small cam bearings AND weak *** lifter valley....check
whats not to like HIO...??????
Dude goes all 292/312 blue oval reference on us....LMFAO...
#158
KCS I hope your wrong....Not in a bad way. I did call Dart also but you can never be to careful. If your right KCS I won't do nothing or think of building nothing. I looked and liked the Dart,Titus and World Products Ford Windsor blocks and some can go to 4.200 to *4.220 I think on the the new Titus.* Priced CHI 3v pro heads and a 4.170 Eagle crank *dirt cheap again dirt cheap*Decided that I'd stay LSX and use RHS heads if the Dart is to be used. That would be crazy to move to a Ford and I have LSX on my right forearm and it's HUGE. I'm down to 2 blocks or resleeve the 5.3. I just want to do something different not the typical 4.200 or 4.185 bore combination then choose the crank size. I may have to just stop looking.
Ls Next Iron block
Go here: Click on the *TechSheet*
http://dartheads.com/dart-product/ls-next-iron/
Cylinder Wall Thickness: .275" @ 4.185" bore
SHP Ls Next Block: click *Tech Sheet*
http://dartheads.com/dart-product/shp-ls-next/
Cylinder Wall Thickness: .230" @ 4.185" bore
Ls Next Iron block
#159
whats not to like HIO...??????Dude goes all 292/312 blue oval reference on us....LMFAO...
@Patron. Nice links on the ls7 runner mods!
