Ls2 408 stroker
Old Oct 2, 2019 | 06:41 AM
  #341
Smokey B's Avatar
It means what's stated, that it's .300 taller than the typical lifter.
It looks like a Morel lifter by the photo. You can Never get a lifter that's too good or that has more rpm capability than what's needed.
Btw that web address will be taken down...there not a vendor of ls1Sales.com
Old Oct 2, 2019 | 06:43 AM
  #342
Smokey B's Avatar
Just what I said it's a Morel lifter.
Old Oct 2, 2019 | 12:16 PM
  #343
bortous's Avatar
Guys i got two camshaft recommendations for a LLSR.
249/261 .675 .657 113LSA +4
250/258 .657 .657 114LSA +4
Which one would you prefer for my combo and why?
Old Oct 2, 2019 | 12:37 PM
  #344
Bspeck82's Avatar
Nearly the same. Major Difference is the intensity of the intake lobe. That being said the first one would be more aggressive and make a little more power.
Old Oct 2, 2019 | 12:54 PM
  #345
Patrick G's Avatar
LS1 Tech Administrator
Selecting your cam by committee can leave you with less than desirable results. When you've been discussing your situation for months with cam designers who know your goals, it's best to trust their judgement.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Oct 2, 2019 | 01:08 PM
  #346
bortous's Avatar
I agree Patrick.
I have no reason to doubt.
Old Oct 2, 2019 | 05:31 PM
  #347
big hammer's Avatar
Good poast OP
Old Oct 2, 2019 | 05:32 PM
  #348
big hammer's Avatar
Pushrods first for sure. I would NOT go to 5/16 x .105. That's not enough. The 11/32 will fit. They fit cathedrals even.
I thought you had said you had the YT 1.7's with 10mm upgrade.my bad on that one
7/16 baseball bats ftw
Old Oct 3, 2019 | 04:31 AM
  #349
bortous's Avatar
Another update.
I finally went up and saw my tuner today to speak about my vehicle.
I also took it for a test drive.
Firstly let's discuss the combination.
After a lengthy discussion I finally have the answers I have been looking for.
The issue with the combination is the roller rockers with the higher ratio.
This is what is causing the instability.
So I have two options.
Either replace the rockers with the ultra lite pros, and go back to the standard ratio as well as change over the springs and utilise a PAC 1207X spring kit instead.
This will fix it and engine will also make more power due to the increased stability.
2nd option is to go for a LLSR and some new lifters to suit and the current valvetrain will work well with it.
Both options will cost the same so it's a no brainer to go the solid roller and this is what I am doing.
When I test drove the vehicle I was surprised how well it runs.
That 242/257 113 LSA +3 camshaft drives just as smoothly as my old camshaft even though it has double the overlap. No bucking or surging whatsoever. A testament to his tuning ability.
That wide split camshaft pulls real well from 2000rpm+ too. I was expecting torque loss in that rpm range and it didn't happen. (which is great)
Also the mid range torque with the mid length runner fast was strong.
Probably stronger than the long runner fast compared to before which took me by surprise so I'm glad I changed the runners over. I cannot feel any losses at all.
I did notice though that the stall converter is a little looser now compared to before.
It still drives nice but it;s definitely changed.
I did not get a chance to put the foot down because the fuel tank was low and I couldn't get out to a decent back road to do a proper test.
The half throttle runs gave me a good indication though.
I'm really keen to see the difference how a solid roller will feel at part throttle response in the mid range.
So now everyone, before you I have two camshaft choices to pick from and I would to know which one to choose
Camshaft 1: 250/258 .657 .657 114 LSA +4
Camshaft 2: 252/262 .675 .657 113 LSA +4
Personally I am thinking the first one.
Old Oct 3, 2019 | 04:49 AM
  #350
Jimbo1367's Avatar
Have Patrick do the honors. Its be the best $50 you ever spent.
Old Oct 3, 2019 | 05:54 AM
  #351
Smokey B's Avatar
Where's the Num-Skull who said new heads for a valve train issue.
Please Read the Diagnosis.
Old Oct 3, 2019 | 07:13 AM
  #352
ddnspider's Avatar
Kudos for being able to detect a valvetrain issue without any visible sign of one on the graph. Takes a lot of knowledge and skill.
Old Oct 3, 2019 | 07:22 AM
  #353
lazerlemonta's Avatar
It is the smoothest instability i have ever seen in a graph myself. Maybe the smoothing function was set to infinity
Old Oct 3, 2019 | 08:24 AM
  #354
AINT SKEERED's Avatar
Low lash solids pull forever but seems your car is doing better than a dyno number shows. I originally hoped my 427 would do 600rwhp through an automatic. Reality is 553 but will fry the drag radials from 70mph roll in 2nd.
Dyno is a tool,dont be to caught up on the final number.
This dyno is to show low lash stability with same rockers and springs you currently have.
Your cam choices both bigger than mine too.
Mine is 246/262@.050. .689/.672 112+4. Pull ended at 7600 still going up.
Old Oct 3, 2019 | 09:23 AM
  #355
bortous's Avatar
Let me rephrase smart ***.
Valve-train harmonics issue.
Old Oct 3, 2019 | 09:33 AM
  #356
bortous's Avatar
That's a very smooth curve.
I hope mine ends up being the same.
Camshafts specs are indeed similar.
I have a little more intake duration and a bit less exhaust duration.
The split on cam one is less to ensure I have a stronger mid range torque curve.
I am told too much exhaust split kills low and mid range torque.
It will still hit 7500rpm with an IVC of 52 and EVO of 64.
I'm still having trouble deciding which one to go for.
Old Oct 3, 2019 | 09:38 AM
  #357
ddnspider's Avatar
https://www.enginelabs.com/engine-te...s-in-distress/
Consider before tearing it apart and spending $$$$ to find root cause????
Old Oct 3, 2019 | 10:56 AM
  #358
spanks13's Avatar
I thought there was eventually a graph posted showing a clear drop in power and stability at higher rpms?
Old Oct 3, 2019 | 11:06 AM
  #359
psicko's Avatar
So how did you and your tuner determine it is a "valvetrain harmonics issue"?
How does that explain why you're only making about 385ft-lbs of torque at about 4300RPM or why you're only able to muster a peak torque of about 400ft'lbs of at 5000RPM?
Do the two of you really think you're experiencing "valvetrain harmonics" at such low RPM?
Old Oct 3, 2019 | 11:15 AM
  #360
bortous's Avatar
Torque is way up now.
I saw the latest graph today.
I should've taken a photo of it.
It's the rockers and camshaft combination.
This is the only reason we are seeing a lower power figure.
Which is why I said, if I change the rockers and springs and keep current camshaft, engine will make more power and torque.
If i go for a solid roller the current valve-train will work well with it.
Pat G told me the same thing too.
