Ls2 408 stroker
I'm curious to see how the lifters on Darth's build does.
I will have information on my build in the middle of next week once alternator gets replaced.
Can't do much without it functioning properly.
In the worst case scenario and I have to get new lifters I will get the solid lifters that cam motion sells but because I'm in Australia they are much cheaper to post from summit racing.
I read the cranes are pretty much OEM spec and size and will probably oil better.
But we will see.
I heard back from my tuner today.
As stated I needed to replace the alternator and I also decided to replace the battery also as it was around 5 years old and is most likely on it's way out.
The replacement optima yellow top battery arrived last night.
The issue now is that the battery won't fit in the bracket I have in the boot/trunk.
I had a optima red top 35 battery before.
So now what I had to do is purchase an optima blue top D34M as this is the only other optima that will fit that damn bracket.
Luckily tuner is buying the yellow top battery from me so it's all good.
I should have an update with the oil pressure issue (or non issue) some time next week.
Has anybody else had an issue with a D35 yellow top battery not fitting a TLG Billet Optima Battery Relocation Tray / Hold Down Mount ?
And it's 30 lbs off the nose. Think how much money guys spend to lose 30 lbs. This on'es easy. Call it "indirect weight reduction"
I know they were pretty good up to about 2009.
Then they cheapened them and hence the poorer results.
The blue top is the cycling battery. I think it's rated at about 300 charging cycles but I will never take it down that far.
I was looking at Odyssey batteries also and these appear that their quality is what the optima used to be.
What is the brand of lithium battery you are referring to?
Is there one that suits a 2005 Pontiac GTO?
Kind of one of those things. Sometimes you just have to mod the car in order to mod the car.
But it ain't cheap.
The cost is $1195 USD with the ebay special.
It will work out even more expensive getting this direct from the USA.
Australia charges a USD $238 import tax for this damn thing!
eBay has progressed from the 10% tax they're supposed to collect for our government, and have upped it to as high as 25% on some items. And there's no law against it, they call it "extra fees for collecting gst". So they're just basically swindling us all over here.
Our government just screws us any which way possible over here to try stop us from doing anything that isn't controlled by them and their 10 multi millionaire mates. Australia has become a communist state.
About your battery, you could just buy a cheap new exide acid battery and mount it in the trunk/boot in battery box on the l/h side as far back as it'll fit. It helps traction on the street quite a bit. I had it like that with my old heads/cam VTii HSV R8. With a full tank of fuel also it hooked surprisingly good on 18" street rubber. Moving the 15kg or so of battery from the front to the back helped traction considerably. The battery cable fits no problems under the plastic trims along the l/h sill panel.
I have already ordered the optima blue top.
My previous battery was already in the trunk.
Where abouts in Aus are you?
