Projekt Lazarus - Numbers Posted!!
Old Dec 5, 2019 | 11:27 AM
  #281
rkupon1's Avatar
Sounds like all race car shyt to me...i mean great info, but who da phuk shiftn 9k on the streets? The $ involved alone is one thing. The longevity n reliability is another. Even at 800rwhp only, and 9k rpm shifts, id say on a good day you ll be in jail in time for hungry man turkey pot pie dinners...
Old Dec 5, 2019 | 12:25 PM
  #282
Smokey B's Avatar
Comparing port entry & exit. Gives u a idea of how the runner is tapered ......vs others. Runner length determines RPM points. Reason I left your thread Darth...you got some ....people out here. You know if I've asked I will share it with u. This is for your keeping, I'm trying to get to the bottom of things.
It was a 9k intake... keyword was. There's a Mathematical formula these guys use, btw.
Old Dec 5, 2019 | 02:42 PM
  #283
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Jake,
Its good that you will be happy/content with 650 RWHP with your build.
I think it will make 670-680 RWHP @ 7200 RPM, even with a "compromised" intake...... LOL
I think you really nailed your cam specs. Looking forward to your results.
Appreciate all the data and knowledge/experience that you share.
Dan
Old Dec 5, 2019 | 02:53 PM
  #284
lazerlemonta's Avatar
It would be awesome if every thread was not a peter measuring contest or full of what ifs. Point being this car has a set plan thats not going to be deviated from the parts list posted. So the discussion of x, y , z intakes and cams are useless imo If he was searching for the next best thing and ready to spend money asking for help i would say then these posts are relevant. Just an opinion.....
Old Dec 5, 2019 | 03:14 PM
  #285
Smokey B's Avatar
Makes sense Laser but alot of stuff is unknown and it's just a formula..you can go back thru a part to C why it's doing what it does. And know.... Darth when u get a chance what R u seeing in the entry.... I intend to learn intakes on all that's available if possible. I'd be a dumb *** to have learned heads and not learn what sits on top
Old Dec 5, 2019 | 03:31 PM
  #286
Darth_V8r's Avatar
Moderator
Originally Posted by Smokey B
Makes sense Laser...Darth what seeing in that entry....
IDK. Car is in at home in SC, and I'm in AZ... I can't measure until Monday, and I'm tearing the car down on Monday.
Where I'd like to be end of day Monday is heads off, new cam and lifters installed, and cam degreed. Then on Tuesday, I can take my time on reassembly and make sure I get good gasket sealing on the front cover, water pump, etc. Also on Tuesday, I'll hopefully be setting my rocker wipe pattern. If all goes well, I'll get the measurements I'll need to order pushrods by end of day tuesday. I'm going to remeasure the deck height to recalculate the head gasket. I'm thinking .038 for quench instead for the normal .035 to account for RPM. I'm thinking the pistons were right at zero, but I'll remeasure all that before I order gaskets. I'll reuse my current head gaskets to measure for pushrods, since I can adjust for the last few thousandths.
Typically if I have parts, I can blitz through a build at a pretty decent clip. once I get the gaskets, I'll finish assembly up to the point of installing the pushrods and rockers. Then that last day should be around three hours to set lash, install the covers, coils, and plug wires. If all goes well, the car is running by Christmas, and if it goes really well, I can get the street tuning well-enough dialed in to see what kind of numbers I might be looking at. Or i'll find out I'm out of fuel pump again...
Old Dec 5, 2019 | 03:33 PM
  #287
Smokey B's Avatar
Don't go crazy because of time .....you got it.
Old Dec 5, 2019 | 05:12 PM
  #288
What fuel pump you running Darth?
Old Dec 5, 2019 | 05:14 PM
  #289
Darth_V8r's Avatar
Moderator
Walbro 255 overvolted
Old Dec 5, 2019 | 05:52 PM
  #290
AINT SKEERED's Avatar
. Every good thread gets spoiled that way
Old Dec 5, 2019 | 05:56 PM
  #291
I had the 255 in my car that worked well for my LS2 build. I went ahead and went with a 450 for the 434 while the car was down. I didn’t want to run into the very same thing you just mentioned could happen.
Old Dec 5, 2019 | 06:04 PM
  #292
Same here.
Old Dec 5, 2019 | 09:29 PM
  #293
Floorman279's Avatar
Originally Posted by AINT SKEERED
Same here.
another option that I always recommend on larger builds is the lonnies doubles. idk just makes more sense to me than running a 450 while just cruising. I'm sure that I will need to Hobbs switch it to come on at 6500. the thing I like about it is I cantf get stranded due to a bad pump.
Old Dec 5, 2019 | 10:22 PM
  #294
Darth_V8r's Avatar
Moderator
I may end up that direction. For now I'm hoping to just make it through dyno without needing upgraded pump.
Old Dec 5, 2019 | 11:23 PM
  #295
If I have to go back into it I will use twin 340's. I have a zex switch for my meth kit to come on at 50% throttle already. 450 is dead quiet though and works great . No need in changing it now
Old Dec 6, 2019 | 10:44 AM
  #296
ramairws6's Avatar
I have Lonnie's kit with twin 340's that activate with my nitrous and love it!
Old Dec 6, 2019 | 10:50 AM
  #297
Darth_V8r's Avatar
Moderator
How loud is it? And by loud, can you hear it over a dual 3" exhaust bolted to a high compression engine?
Old Dec 6, 2019 | 11:08 AM
  #298
Mickyinks's Avatar
Fore innovations twin 255 lph intank... Only hear it on start up... max duty cycle ive seen with 65lb injectors was 72%. Good quality kit
Old Dec 6, 2019 | 11:26 AM
  #299
Darth_V8r's Avatar
Moderator
Thanks! That's about where I am on my injectors. 80% range on 60's.
I was hoping not to need to cut up the bucket, but I guess it's coming.
Old Dec 6, 2019 | 08:18 PM
  #300
yea the cutting sucks especially on the non baffled plastic tank. my gauge is good and I have gone a needle width above 1/8 before.....was scared
