Projekt Lazarus - Numbers Posted!!
Originally Posted by AINT SKEERED
my sniper needed 2throttle body spacers to get full throttle. I like to call it extra plenum volume 😁
Originally Posted by spanks13
I wouldn't run a bunch of spray through a $2000 plastic intake lol.
I can't wait. You need to come up for rental and we can race! I'm not toooooo much lighter lol.
I'm at 13.5:1 on C85 for fuel. Everything is very similar. I did the triple disc clutch because I'll be spraying eventually. I can't remember if you have the Holley 105tb. Top ends are almost identical except your heads have a little more knowledge in them. I think our lifters are a little different but both solid so shouldn't matter. Bottom ends are similar too really except I'm bigger bore. So very much apples to apples. Streetcar ftw!
And it is a chemical TB spaceur!! LOL
Still rockin the NW 102. That might be the single longest lasting performance part I've put on the car, now that I think about it. it's the one thing that keeps getting copied forward. I'll call it an "investment". Sounds better that way.
I'm very interested to hear how you like the triple disc. Keep me posted!
Ok, so high compression with rocket fuel... got it
CMD Extreme Pressure Lube #3 works well for balancer installation.
Ditto on what 70Chevelle said on the light hone. I had to do that on an LS3 stroker at the shop. Couldn’t even get the dang thing started on the crank until I honed it.
It’s a real bitch getting the crank key aligned on a hard press. And if you pull it on with the key miss indexed, you will be just about as mad as you were pulling the stuck hub off. 😊
Odd about the cam plate bolts. I agree I like the normal bolt style better.
Ron
Ron
Ron
Ron
Hit a snag but very minor. My fuel rails are not compatible with the intake. Fun fun fun. If I buy tall injectors I can make one work. Or I order a fuel rail and keep my current injectors.
Will post up what I decide. In the meantime I have not got **** done. Cause last minute holiday ****.
I'd do sniper fuel rails and have the ability to go to a return style fuel system. But your injectors are maxed almost now right?
Need to see if holley will ship just the brackets. Or else I can swap in my 42's, but they were so maxed out it was absurd. Or I just get yet another fuel rail.
