Projekt Lazarus - Numbers Posted!!
Old Dec 29, 2019 | 05:23 PM
  #381
cmysix's Avatar
Machine silver is the fastest of the silvers
Old Dec 31, 2019 | 08:12 AM
  #382
Darth_V8r's Avatar
Moderator
Kind of a dumb update, but slower progress. LazerLemonTA came to visit this weekend, and we had a blast. Also, this happened, which diverted a significant amount of time from the car:
Wife got me a pure, blue Great Dane female pup. Six weeks old and already eight pounds. Will likely weight 150 based on parents' weights
Lazer helped me figure a course of action that makes the most sense along with texting Tony at weird hours. Holley tall covers are on the way. Along with FAST fuel injector extenders. That gets me running once I measure for new spark wires. Buttoned up the front of the motor. Installing the hub became a fiasco, but not for any bad reason. Installer tool didn't reach all the way in, so a trip to fastenal to get some 16mm x 2mm thread rod and some nuts to build an installer tool. Credit to Lazer for coming up with that one.
Got the water pump and alternator installed as well. At this point, I need to install the radiator, fuel rail, valve covers, vacuum pump, and connect the headers to the exhaust. if Summit racing delivers today, I'll be able to measure for the new plug wires. I'm 100% positive the spark wires are going to be too short. Between the taller covers and thicker gaskets, I'll be close to 1" longer wires at a minimum.
Oh, and silver is the fastest color...
Old Dec 31, 2019 | 08:29 AM
  #383
ddnspider's Avatar
Based on my tracking I do believe Summit will deliver today so hopefully for you too....and Yes silver is the fastest.
Old Dec 31, 2019 | 09:57 AM
  #384
Summitracing's Avatar
LS1Tech Sponsor
Darth, congratulations on the new pup.
Thank you for choosing us for part of this awesome build you have going. As far as deliveries for today. Our records show only air packages are being delivered today. If you send us a pm with your info we can check into it.
__________________
800-230-3030
www.SummitRacing.com
Old Dec 31, 2019 | 10:30 AM
  #385
spanks13's Avatar
By science, red is actually the fastest lol
Old Dec 31, 2019 | 10:34 AM
  #386
Darth_V8r's Avatar
Moderator
I appreciate it. I didn't air freight, so that's ok. I have the tracking info. I think every build I have done has used yall for something.
  #387
Darth_V8r's Avatar
Moderator
Highway patrol certainly seems to think so...
Old Dec 31, 2019 | 11:13 AM
  #388
spanks13's Avatar
I just got a new puppy too. Goddamn they're needy. You'll be building fast trucks instead with a dog that big!
Old Jan 1, 2020 | 06:45 AM
  #389
Innovate's Avatar
Interesting read, I hope the Mamo MSD works for you. You should break 6 easily with your cam/heads combo. TQ is what you should worry about, what is your CR? I must of missed it.
Old Jan 1, 2020 | 09:25 AM
  #390
bortous's Avatar
I have a bengal cat who has very similar characteristics to a puppy.
Needy as **** 24 hours a day and he doesn't like exploring outside if I am home.
He always wants to be around me and doesn't like to be separated.
He sleeps right next to me and wants to be petted while he sleeps.
I thought this clingy behaviour would stop at a certain point but after 5 years it's evident it is here to stay.
Old Jan 1, 2020 | 10:25 AM
  #391
Darth_V8r's Avatar
Moderator
Compression is 12.7:1. Probably a little past the brink, but boostane exists as does E85. I actually figured out I have more cam than I realized. Cam dr report is on 1.7. I have 1.8. So lift at .050 is actually at .047. So assuming the math is right add two degrees to both sides intake and exhaust.
The intake should do ok. It ran neck and neck with fast lsxhr on a 468 thread. Only way I know to do better will be to cut the car up to fit a cid. End up being a $8000 intake. No thanks.
Old Jan 1, 2020 | 10:26 AM
  #392
Darth_V8r's Avatar
Moderator
Lol. That is actually kind of sweet
Old Jan 1, 2020 | 09:50 PM
  #393
According to Tony those rockers are 1.82. 😜
Old Jan 1, 2020 | 10:00 PM
  #394
Darth_V8r's Avatar
Moderator
Fine by me. All the lifts!!
Old Jan 2, 2020 | 09:49 AM
  #395
Darth_V8r's Avatar
Moderator
FWIW, plugs are BR7, gapped to .043. Have the High Energy Redline coils, so I could likely go to a higher gap, but I wanted to avoid misfiring. If I had stock coils, i'd have gone to .035.
I got the fuel injector extenders and Tony was concerned about the fuel puddling and hurting the way the motor drives. So, slight delay while waiting for new injectors. Although I can get the measurements I need for the plug wires. Tomorrow -- Wife's birthday today. I'm not suicidal.
Old Jan 2, 2020 | 10:04 AM
  #396
spanks13's Avatar
Injector spacers are fine on the rail side, but I'd never run anything between the injector tip and the manifold.
Isn't the BR7 the non-projected tip plug?
Old Jan 2, 2020 | 10:26 AM
  #397
Darth_V8r's Avatar
Moderator
Yes, non-projected tip. I did this on purpose due to the compression I'm running combined with the fuel I have available. Hoping it allows me to push the timing a little.
Old Jan 2, 2020 | 10:30 AM
  #398
ddnspider's Avatar
Good call, on all my higher HP stuff I run non-projected BR7's. Nice to have some cushion against detonation.
Old Jan 2, 2020 | 10:39 AM
  #399
Darth_V8r's Avatar
Moderator
I might have gotten that from one of your posts. I'm not honestly sure anymore. You can have the credit if you'd like. LOL
Old Jan 2, 2020 | 10:49 AM
  #400
ddnspider's Avatar
whateve's as long as it helps keep the motor in 1 piece and make power.
