Summit stage 5 cam, c6 build progress.
Old Apr 5, 2021 | 07:24 PM
  #261
Mavn's Avatar
"I MAID THEESE"
Whoever said the heads on my baby cam wouldnt pick up was correct.
picked up 8 hp lol
Made 478.
Currently have the car apart for the stage 4 Summit cam to see if the big cam makes the heads shine. Or if they're just too large for an ls3. Was a humbling day on the dyno Saturday lol
Stay tuned for the big cam . Just waiting for it to come in . The ghost cam is out of the engine currently.
Old Apr 5, 2021 | 07:27 PM
  #262
Mavn's Avatar
"I MAID THEESE"
Old Apr 5, 2021 | 07:36 PM
  #263
LaBLKv6Z's Avatar
Just saw the vid and was like wtf? That 1hp gained from the rod mod intake doesn’t seem too bad considering the $$ spent LOL. This was on E?
Old Apr 5, 2021 | 07:38 PM
  #264
Stampede4ever's Avatar
Wow, wtf! I wonder how much the stock heads would pick up with some handy bowl work?
Stampede.
Old Apr 5, 2021 | 07:39 PM
  #265
Mavn's Avatar
"I MAID THEESE"
Not full e . I fucked up and only drained 1 saddle bag lol then put in 5 gallons of e. This was like e35 .
Old Apr 5, 2021 | 07:40 PM
  #266
Mavn's Avatar
"I MAID THEESE"
Stampede.
My stock heads were milled .030 with a REALLY good valve job and bowl blend .
Old Apr 5, 2021 | 08:22 PM
  #267
On your particular engine, what would you ESTIMATE is the power gain from just the above mods?
Actually was just interested in the bowl blend and valve job, but they're milled too, so OK.
Old Apr 5, 2021 | 08:41 PM
  #268
Mavn's Avatar
"I MAID THEESE"
Apparently enough that a set of aftermarket casting heads only picked up 8 hp lol
Old Apr 5, 2021 | 08:59 PM
  #269
Whoa... ALMOST not really worth putting the aftermarket heads on...... But 8 HP IS 8 HP... lol
But that said, sounds like very much a worthwhile mod!
I've read more than once here that a good bowl blend and multiangle valve job are 80% of a good port job, and only if the port mods are of benefit.
If I may ask, who did the above-described work on the heads?
Old Apr 5, 2021 | 09:27 PM
  #270
Mavn's Avatar
"I MAID THEESE"
my buddy Juan @Laguna race engines in Houston, TX. He does all my head work. Hes got some really awesome machines and does great work. Affordable too!
Old Apr 6, 2021 | 11:34 AM
  #271
dAgent's Avatar
See, this is what happens when "church port mafia" goes big port square heads. Man this thread snowballed ta fack out of control from "fix my daily driver honey" I'm not spending big money here so I'm just going to put a small cam in there and use what I have,... to aftermarket heads, 2 cams, etc. lol
Old Apr 6, 2021 | 11:46 AM
  #272
SLOW SEDAN's Avatar
picked up 8 hp lol
Made 478.
NA mods are a kick in the shorts for sure! Still not too late to go turbo
Old Apr 6, 2021 | 01:11 PM
  #273
Mavn's Avatar
"I MAID THEESE"
my favorite kind of build lmao!
Old Apr 6, 2021 | 01:13 PM
  #274
Mavn's Avatar
"I MAID THEESE"
nahhh. The fbodys the turbo car for now. After this thing does what I want I might get crazy with it. I do have 6 bolt thick deck heads after all 🤷🏻‍♂️
Old Apr 6, 2021 | 01:26 PM
  #275
Summitracing's Avatar
LS1Tech Sponsor
The heads may simply have too much CSA for the rpm and cubes of this engine. IF someone wants to stay with a smaller cam, converter and inexpensive intake, this at least shows how these particular heads responded. There are other aftermarket aluminum heads (TFS 255's as an example) that have a smaller high velocity port and would yield bigger gains with the present combination. So now it's time for more cam, more cubes, and an experiment with runner length. These will undoubtedly shift the power band up and to the right and it will be interesting to see if the longer runners crutch the bigger cam and heads to work better with that 3800 converter. Looking forward to the results!
__________________
800-230-3030
www.SummitRacing.com
Old Apr 6, 2021 | 02:50 PM
  #276
spanks13's Avatar
It is not just the CSA but the engine wasn't demanding any additional CFM at the power it is producing. I bet the stock heads that Mavn did would provide enough peak airflow to make 700hp with virtually no restriction. I would've been curious to hear more about how it drove with the 280cc heads with the small cam. 280cc is big enough for a high rpm 427+ cube engine. It might've even lost performance despite gaining some power. Some of that 8hp is likely from the little bit higher compression with 64cc chambers. .030 cut off ls3 heads is ~65.5cc.
I am a big fan of ls3 heads, but you really only need 225-235cc for a high performance ls3 going by the math alone.
Old Apr 6, 2021 | 03:20 PM
  #277
Mavn's Avatar
"I MAID THEESE"
The drivability with the Big heads was the same as the stockers. Drove like factory. Im with you on the nit needing a huge head . Im used to cathedral stuff. Where when you go to a 247cc or 235 cc cathedral from a stock or ported 243 you gain crazy amounts. Learning is fun!
Old Apr 6, 2021 | 05:53 PM
  #278
SLOW SEDAN's Avatar
Whats the “what I want” goal?
Old Apr 6, 2021 | 06:41 PM
  #279
RonSSNova's Avatar
Still have the stock torque converter in the car?
Old Apr 6, 2021 | 09:14 PM
  #280
Mavn's Avatar
"I MAID THEESE"
Yes. My 245mm circle d 4000 will be in in about a week
