430" F710 drag engine
Old Aug 23, 2021 | 07:27 PM
  #61
rkupon1's Avatar
Fack FB! Guess I wont be learning nothin!
Old Aug 23, 2021 | 10:18 PM
  #62
helicoil's Avatar
Haven't seen anything enlightening there yet.
I don't doubt the potential of the F710's - I just want to see some recipes that are yielding these BIG numbers and some intellect used when sharing the dyno numbers. It would be great to see the claims prove out on the track.
I am not downplaying the heads, I own a set, I am mostly interested in seeing someone share their realities with a little factual data to support them.
Surely these 900+HP builds have gone down the track and someone has footage and car details. Haven't been able to find one yet out there that adds up.
Please share,,,,
Old Aug 23, 2021 | 10:34 PM
  #63
DualQuadDave's Avatar
Originally Posted by helicoil
Most tricks of the trade are pretty hush, hush. Sometimes manufacturers are open to share, sometimes others are not and sometimes the people you talk to at an outfit are just sharing third and fourth hand experience and don't know ****! and have never built anything impressive themselves, tuned anything, raced anything or ran an engine dyno, otherwise you likely wouldn't be talking to them on the phone! Success in this industry is based heavily on marketing and advertising. Forums are a fun place to share stories and 'sometimes' there are knowledgeable people with real experience sharing info. just sometimes.
I would trust Westech's results, third party, un-biased typically. I trust the dyno I use, the numbers it produces line up with on track performance (based on weight and speed). The customers they have are people that are often looking for small gains and have flushed out an engine combo for everything it is worth. I rarely see engines that are cheaper than 40K in the shop. He is a phenomenal carb guy. He doesn't over-inflate, sell engine packages that he claims will make XXXX HP nor does he advertise. He shows up at the NHRA races and races in Top Dragster. Word of mouth, track performance and reputation is what his small business is based on. He is continually humbling people that bought this or bought that which made XXXX HP on Joe Blow's dyno. Most leave with nothing to brag about. That is the REAL world, just sayin.
If your engine dyno sheets aren't several pages in length for one individual pull and include things like fuel flow (before and after), air mass measured (if done correctly!), BSFC and list specific correction factors it is hard to validate the engine dyno numbers until it is in the car and raced. They all help make sense of the horsepower and torque numbers.
Dyno calibrations are super important. It is amazing how many hacks are out there that own an engine dyno that don't have a clue how to calibrate or use their software and are not using all the inputs to acquire info needed to validate things. The average customer has no idea what they aren't seeing. It is equally amazing how many customers and end users are out there that get there XXXX HP engine and don't understand why it isn't performing at the track and are not educated enough to know they got screwed by their engine shop or who they bought parts from and the claims made were B.S. It often becomes a finger pointing contest in the end and no one person is holding ALL of the information to be able to point to the problem, it is he said, she said kinda story.
I agree with knowing and seeing fellow racers showing up at the track and not running the times they should based on the dyno numbers they claim. See that quite a bit,,,
1.8HP per cube is good power. 2.0HP per cube is stellar. 2.1HP per cube is outstanding and would be doubtful to see from any non-professional outfit not doing these kinds of builds in volume and would be the equivalent of a blind squirrel finding a nut, even for many of your professional shops who are not able to take the block from the crate to the final product and dyno. These kind of builds are not going to leave any stones unturned and will leave nothing on the table from cam and valvetrain design to compression ratio.
2.2HP per cube combos will use the best of the best and will be geared to racing only types of builds with detail focused on everything from super thin ring combos to fully ported and matched induction systems, elaborate windage control systems, optimized header size and design that capitalize on scavenging dynamics in the operating range the engine is designed to run at to spot on tuning using expensive fuels! I would expect to see that only from a one stop shop who specializes in NA builds (non-power adder) as the engine build often entails details and tricks not normally found in a power-adder type of set up, not always, but often. Otherwise if I see a post, dyno sheet or info being shared that claims XXXX HP it is 99% likely to be bullsh!t.
Wow! With a great post/experience like that, they'll either ban you or put you in charge . Well said, Sir!
Old Aug 24, 2021 | 02:07 AM
  #64
Corona's Avatar
When you want something people just don't know who to Talk 2 or look for...on the ET I can't help but on the Hp ... It's big Lift and Knowing a cam Designer who's it's not there 1st Rodeo with a High Hp drag build and cam Timing ..
https://www.lsxmag.com/news/project-...rpm-dyno-pull/
Your not gonna find anyone around here Building Nothing like this YB maybe...
Helicoil you Need Lift and crazier Cam timing and being @ 13 points on compression with that cam it's close enough it possibly could run on Pump gas....
with a splash of racing gas with that cylinder pressure bleeding duration.
And I know you do this...and I don't..but it reminds me of something I read when Purps 440 didn't do as well as expected...
Marcella or someone great stated that he was using a Half *** 8k 800 Hp cam Expecting more.. something along those lines
FB works fine and Ben was very Knowledgeable...on what I was asking..
These high Power builds share Certain things in common.
Crazy cams and compression....
Contact Erik K and you'll have your Questions answered or pointed in the right direction and who to Talk to...HP or ET
Fact.
Re cam it....you've got your Baseline. 👍
Old Aug 24, 2021 | 02:12 AM
  #65
Corona's Avatar
I'll make a friend Everyday and twice on Sunday to get to the facts and someone Who does what I'm asking or thinking of...
Skip the trial by error ...I don't have money like that.
Old Aug 24, 2021 | 06:15 AM
  #66
rkupon1's Avatar
And yet ER made 900hp with a 440ci, <13:1 CR, and a set of Trickflow 260 heads...if I had to guess, id say a lot of these builds are ending up in grudge cars. Id never waste time trying to pick a cyl head again, just pick the right man!
Old Aug 24, 2021 | 06:28 AM
  #67
Corona's Avatar
The most common thing is .800-.900 + on Springs
with more than 270+ degrees of Duration then they set the LSA and ICL at some crazy 💩 like 106 ICL
You think the 280 cam was meant for 8500 but not with A 106 centerline ...it's makes power Below the curve...
Tendicies...of a grudge NA wanting the $ or 🏆
The build up of Cylinder pressure + Combustion and it's Escape using a Good Fuel....
Old Aug 24, 2021 | 06:46 AM
  #68
Corona's Avatar
It's all about the Tendicies go look over any 850fwhp+ "That's True! @ around the same bore and stroke size.. There are Newer builds Thread's but the old ones are better Serving as Technology has Advanced and the old simple idea using older Thread's makes it seem Simpler....then we ask so how Has technology made it more Efficient using the same basic Hardware. 😉
https://ls1tech.com/forums/dynamomet...e-dyno-na.html
and this is a BigDaddy race version 468
https://ls1tech.com/forums/dynamomet...aspirated.html
Old Aug 24, 2021 | 06:52 AM
  #69
Corona's Avatar
Is that Erik @ HKE before the HPR move talking about a 468 LSX Engine 😏 and 900+
ole news on Who to be friends with about HP and Honesty
Old Aug 24, 2021 | 07:05 AM
  #70
Corona's Avatar
One thing about a Good person is they Won't Lie to you .... whether you like it or not.
I've asked the Man Alot of questions
Truely Lmao... and I don't build engines 🤫
Old Aug 24, 2021 | 09:14 AM
  #71
JRFed's Avatar
He's getting ready to set the world on fire with a new combo he is working on with F710s real soon
Old Aug 24, 2021 | 11:49 AM
  #72
Corona's Avatar
He's done Alot of builds seen and unseen
Erik's one of my 1% of the top 1%
that I've made a group of over the Yrs...Chris Frank also and how He's took over the Market name it he'll port it 🤣
What I did was learn the Tendicies on a 4 inch crank and hp output with the Math Used...🤫
From the group and I don't like working on them..
but I love to spec them 👍 now time to place the theory on the bench seems simple enough.
Old Aug 24, 2021 | 11:56 AM
  #73
Corona's Avatar
My whole take and end game is like Helicoil...I'm not accepting nothing that's not on the table for Hp with my junk for parts...
if Chris made 750 with a 414 even on a bias Dyno I want that as he used a Elbow and a 102 mm TB with a GM intake.
4500 should Cover that...it's a Tendicies for Hp Vs
Old Aug 24, 2021 | 03:24 PM
  #74
JRFed's Avatar
We just had a customer make 770HP out of a 408 with our LS3s too if you haven't seen our post. 12.5:1CR
Old Aug 24, 2021 | 03:58 PM
  #75
Corona's Avatar
Pass it along,
​​​​​​as it's used as a reference 🤫...my Book is 700 min using a Factory block ....I skipped Tuskey's Cookbook. I'm trying to Murder it.
I'm @12.2 considering a slight mill Using the trusty ole Factory Stg1 heads you offer with @ the Same Size in cubic inches ... Super Victor EFI and a 4500
I know it's possible I'll go find the post .... I'm a FB 1st see Follower same with others on FB....MBE, EFI University, 3v , Proline.. Baldwin, etc...and I lost my original FB page, stolen idk. But Now I have less than 200 friends 😉
I didn't know half MF'er looking back now
Old Aug 24, 2021 | 04:31 PM
  #76
Corona's Avatar
Oh..."Ben White" found it on FB..
Oh 💩 reason for another Cam if failed re-cam the B!+#h. I'm thinking the cam now has potential but a
New Goal and fight using the Ole 4500
I also see m311's used .... Hmmmmm.
I've got a spare Head that needs some testing (intake attached, shrinking the valve in the seat testing Using a smaller intake Valve I'm @ 2.20 now 😉 and finishing work done to).... I'm out of the fight on the purchase of another head. I made 1 so I'll stick to it unless I break it..
Rowdy Yates 😉
Old Aug 24, 2021 | 04:57 PM
  #77
Corona's Avatar
770 well I'll be Damned...
that damn Free engine Simulator is Really paying itself off... Lmao.
...I'm happy for the guy and the builder 👍
I'm also getting back on the Simulator as
Billy GodBold's associate / team member sent me back His view on a cam I spec'ed...Billy reference me to Chris Ryan as he was on vacation....
Billy's a old Yahoo mail Buddy 😉
Sim and Pipe Max show similar numbers your talking about.
Oh I'm happy. Using Either or...I'm ready to keep paying to see this 💩🤣
​​​​​​then I can move on to looking 4 People.
Old Aug 24, 2021 | 06:02 PM
  #78
Corona's Avatar
I bit and Followed ...that engine also used a Hydraulic roller cam...
WOW ..
also watched the video by the Builder on there page. 👍 Thanks again.
Old Sep 3, 2021 | 10:21 PM
  #79
Bumping this up. More info to follow…
Old Sep 4, 2021 | 07:39 AM
  #80
Corona's Avatar
Helicoil said he's wanting to do some more testing.. also showed the engine on the Dyno...
