C6Z Solid Roller LS7 Build
Old Dec 7, 2023 | 05:34 AM
  #61
jayyyw's Avatar
Originally Posted by Ryans99ls1
It's all going to hinge on how it lines up under 6250 in the real world. My shifts hit ~5250, 5750, 6000..
Rev it higher!
Old Dec 7, 2023 | 07:36 AM
  #62
Ryans99ls1's Avatar
Originally Posted by jayyyw
Rev it higher!
8100 is all i got on the e92 if i want any sort of rev limiter lol. I'd love 8500ish. But yea, i think those shifts were with a shift point just shy of 8000. MSD probably wont make it beyond 7800. Trinity will want it all
Old Jan 2, 2024 | 08:19 AM
  #63
Ryans99ls1's Avatar
So i am having the header collector stepped up to 3.5in with a 3in to 3.5in vband and then having a 3.5in x pipe made, for far cheaper than the setup through ARH. The standard 3.5in ARH x pipe necks back down to 3in after about 2.5ft (probably 18in after the x merge). Is that enough to length to realize most of the gains from the 3.5in collector? Does the exhaust really slow down enough in that 2.5ft length to not be affected by going back down to 3in?
i know the ideal solution is to dump it asap after the collector, but i am not about that life at this point. i am also not fabbing up 3.5in over the axle and modifying the cans. The extremes are already straight through. I am ultimately trying to decide if its worth it to incorporate a cutout when it goes back down to 3in before going over the axle.
Old Jan 2, 2024 | 09:07 PM
  #64
Last 1's Avatar
I think I would install a set of cutouts and call it a day.
when I go to the track I just pull the pipes back to x pipe and install turndowns.were I live in a rural area I can get by doing this .I’ve been riding around like this since the first of November.but I’m getting ready to pull the motor so I don’t what to add work to myself
as far as over the axle 3” pipes ,were I’m running a trans brace I had to modify mine with a hammer to clear the brace (passenger side) in order to get my Corsa muffler straight
Old Jan 3, 2024 | 06:56 AM
  #65
Double06's Avatar
The 3.5 inch for 2.5 feet will work fine. The 3 inch manderel over the axles is fine - it cools off quickly. I think there have been some dyno tests on a 468 Corvette in Arizona and there really was not much difference on the stuff you were talking about above. The 3.5 inch for the 2.5 feet will get you 95% of the way there on what might be only a 20 hp gain to begin with so you get 19 of the 20 hp.
Old Jan 3, 2024 | 12:22 PM
  #66
spanks13's Avatar
If you do run it open headers or cutouts you will want at least 16" of tubing before dumping the exhaust. Open headers just at the collectors will be down quite a bit.
The power gains from 3.5" is likely from the larger collector, not from having 3.5" tubing after the 3" collector. I'd be interested to see a comparison.
Old Jan 3, 2024 | 12:50 PM
  #67
Ryans99ls1's Avatar
Exactly what i was i wondering. Thank you. I am fine getting 90% of the gains if it means keeping things as simple as possible.
I am ambitious, but also lazy when it comes to constantly getting under the car. Definitely not getting under the car to remove and swap exhausts. I'll gladly spend some coin for convenience, just trying not to overcomplicate things for small gains.
Right, i know there has to be some length after the headers, but i really had no idea what the length should be. And after the x merge, i've got a few feet to play with. Just want to make sure i get it right before welding anything.
Thanks all!
Old Jan 3, 2024 | 05:18 PM
  #68
Bob570's Avatar
It was always my understanding that x-pipes make more power than open headers, even with an extension on them. Particularly in the midrange.
Old Jan 3, 2024 | 08:21 PM
  #69
jayyyw's Avatar
Going full 3" exhaust from the stock mufflers, that neck down to 2.5" at the muffler, is worth ~10whp on most setups. If you're trying to eek out every last bit of power, I would absolutely keep it 3.5" all the way or have a cutout put in right before it necks down. Going to dumps was worth some power on my setup according to the ol' butt dyno.
Old Jan 4, 2024 | 07:52 AM
  #70
Ryans99ls1's Avatar
I was a bit lazy in typing "dumping them asap after the collector", i really meant - forget about connecting to the rest of the exhaust after the x, just dump them somewhere before the axle. I just wanted to understand how far back i need to take the 3.5in to reap most of the benefits. The ARH 3.5in section in their x pipe just seemed short to me.
If i leave single digit hp on the table by NOT including a cutout and running 3.5in to the axle and 3in the rest of the way, i am 100% fine with it. But it is likely one of those things i will experiment with once the setup is together.
Old Jan 4, 2024 | 10:35 AM
  #71
Last 1's Avatar
I see your running a QuickTime bell house and a mantic clutch me to.
since you don’t like doing maintenance I’m with you ,I cut a window in mine at the bottom were I could see what going on.around 4 1/2 w by 2 1/2 h
and also I drilled one hole inline with the pressure plate bolts if they back off.
I shouldn’t have any issues because I throw the nuts away that mantic sends with
the clutch and buy locking ones.
and I also do a little more clearance around we’re bleeder line come out.
in case I have to tighten them up.
i think we’re on the same page as far as to we’re we want to get our cars
I’m waiting on pistons /my best et was 10.52 /136.18 with a 1.605 /60 foot NA
ps from what I read I would stay away from aftermarket transmission mounts and stay with the oem transmission mounts
Old Jan 4, 2024 | 10:37 AM
  #72
02EBC5Z06's Avatar
aftermarket are perfectly mine. The biggest issue is people that replace just the engine or just the trans mounts, and then break ****. I'd recommend amt motor and trans mounts. As whatever engine mount you use, you want matching mounts for the trans.
Old Jan 4, 2024 | 11:09 AM
  #73
Last 1's Avatar
Wheel hop what kill differential in C5/C/6 corvette. I’m running Henson motor mount and oem transmission mounts with no issues
I reached out to Sebastian19X about aftermarket transmission mounts and he told me to stay away from them.
he said he killed a lot of side covers running them.he’s been running his car for a long time.
take it for what it’s worth
Old Jan 4, 2024 | 07:23 PM
  #74
jayyyw's Avatar
I ran Hinson mounts with OEM trans mounts for a long time. Didn't start breaking parts till I made 1400+WHP.
Old Jan 5, 2024 | 07:49 AM
  #75
Ryans99ls1's Avatar
i am not against maintenance, i am building a solid roller with two intakes lol. i am just not going add things for the sake of adding them. Pulling and swapping exhausts is just something i have no interest in doing if it's not worth much of anything. Only reason to cut into the bellhousing is if i was to go to an adjustable clutch, which is not out of the question but not in the immediate future. The mantic has been good for me so far, i will let it ride until it's done.
i am going to be on bias ply's for any dig racing. outside of some quick shudders in the burnout, wheel hop is pretty much non existent. If i end up breaking anything, i will look at it decide if i need to swap any of the mounts out.
Old Feb 22, 2024 | 08:28 AM
  #76
Ryans99ls1's Avatar
Cam is in. Didn't like what i saw on the oil pan gasket though. It was torn/knicked around the oil pump gasket portion, probably from previous owner sliding the oil pump on over it instead of lowering the pan. Didn't have pressure issues, but it's no good. So I need to replace that and then I will get the AMT mounts in and Improved Racing oil thermostat on and plumbed. Only measured one, but quench came in right at 0.035 so should be good there.
Went to measure pushrods and when i put the intake rocker on, it only had 0.002" lash with no pushrod installed behind it. The exhaust rocker has 0.010"+ in it's torqued condition with no pushrod, the inside of the intake rocker is hitting the topside of the pedestal corner. So i will soften those corners up to help make room and make sure nothing is getting beat up at RPM. It's just way too close for comfort. The heads already needed clearanced at the most first/last locations for the rockers, so this is no biggie. Head studs are in and the cometic rivets are drilled out though. Slowly but surely getting there.. weather has been far too cooperative for February, but i will take it!
Old Feb 22, 2024 | 03:18 PM
  #77
02EBC5Z06's Avatar
I blame DJ
Old Feb 23, 2024 | 07:17 AM
  #78
Ryans99ls1's Avatar
Originally Posted by 02EBC5Z06
I blame DJ
I like to blame him for everything. Much easier.
Old Mar 4, 2024 | 07:53 AM
  #79
Ryans99ls1's Avatar
Oil pan gasket is swapped, AMT mounts are in, Improved racing thermostat and lines are in, timing cover and balancer are on. Stupid T40 PLUS bit will be here today so i can torque those dumbass special bolts on the balancer. Torqued a head down and measured the pushrods. 7.6025" on the intake, 7.6665" on the exhaust (T&D rockers take about 0.100" of the factory length of 7.8, i had .062" cut off the heads, and my gasket is .011 thinner, so it lines up pretty well) I'll order those from Manton today. Upgraded the starter wiring and wrapped the starter. Heads are clearanced for the rockers. Was able to get 1 header wrapped, still need to do the other.
Hard parts are over. Just need to keep chipping away at getting the rack and accessories on. Then doing the aux pump setup and fitting the intakes. Probably put the stock intake on to get the exhaust fab'd, we'll see.
Old Mar 25, 2024 | 08:27 PM
  #80
Ryans99ls1's Avatar
Intake pushrod holes need hogged out for the 3/8 rods to clear at max lift. A few were still really close, which was surprising. Another round of grinding coming up. Exhaust side has plenty of room after 2nd round of clearancing.
