LS2 build Question
Old Oct 12, 2006 | 03:53 PM
STKN1STGEAR's Avatar
Default LS2 build Question
I am considering building an LS2 for a 99 F-Body.
What do you think about these specs?
New LS2 block - $900
Honed w/ a torque plate - $100
New Rods (I-beam style)-Forged - $425
8.5:1 dome pistons & rings -Forged - $565
.525 x .525 cam & lifters - $250
Stock LS1 crank - have
Stock LS1 heads & intake - have
35# injectors - have
Vortech Supercharger 12-14 PSI - have
I was told to run Methanol injection.
Is it worth the added cost?
Is this a good setup for street and autocross?
Old Oct 12, 2006 | 04:33 PM
Cop Car's Avatar
sell your motor and transmission complete
built LQ4/9 motor with forged pistons and L92 heads with a single plane or sheet metal intake. stock crank and stock connecting rods.
Old Oct 12, 2006 | 06:48 PM
Well I'm not ready to do that just yet.
I want to use the parts that I already have.
So does anyone else have an opinion on the question at hand?
Thx
Al
Old Oct 12, 2006 | 08:26 PM
Randy WS6's Avatar
The stock heads and intake is going to be very restrictive with the 4" bore and the cam, you can put 2.02" & 1.575" valve in the stock seats and do some porting and clean up the bowls a little and atleast try to find you a used LS6 intake and a set of headers.
Old Oct 12, 2006 | 09:30 PM
What Kind of HP at the crank do you think that it will produce with the stock heads and intake?
Old Oct 12, 2006 | 10:55 PM
Nate_Taufer's Avatar
I would try for around 9-9.5:1. Superchargers like more static compression than turbos. Pick up some L-92 heads and intake, throw on some valve springs and go to town.
Nate
Old Oct 13, 2006 | 09:44 AM
Nate
Nate,
I was told to not go over 9:1 and run as much boost as I want.
I plan to run approx 13 PSi for now.
Al
Old Oct 13, 2006 | 03:47 PM
Bump Bump
Old Oct 14, 2006 | 11:22 AM
Bandit28's Avatar
450 475 crank hp if your lucky with stock heads
Old Oct 14, 2006 | 11:58 AM
IS there any way to prove this without using a dyno?
do you know of a chart or ref that I can look up that spects and see approx what I'll get from this?
Old Oct 14, 2006 | 01:10 PM
Bandit28's Avatar
i hvae no idea but im going to say no but stock 5.7 head and 6.0 heads have basicly "no *****" if you know what i mean, so basicly get them ported and some big valves. As well as a good healthy cam, you make alot of your power in the heads and valve train.... goodluck
Old Oct 15, 2006 | 12:54 PM
Thanks for the info
Al
Old Oct 17, 2006 | 09:54 AM
Does anyone know what valves are in the stock heads of an 2004 silverado SS? I think they are 918 heads.
Al
Old Oct 17, 2006 | 11:29 AM
cws T/A's Avatar
I seen a member here , LS6son running a 408 with stock 241's 244/248 .612''/.615'' 114lsa and an ls6 intake making 469 rwhp and 467 rwtq through a 9'' . Thought that was pretty good myself.
heres the link https://ls1tech.com/forums/dynamometer-results-comparisons/588600-how-much-do-i-stand-gain.html
Old Oct 17, 2006 | 07:03 PM
Ttt......
Old Oct 18, 2006 | 01:39 PM
Blown04Z06's Avatar
there is a dyno in my thread you might be interested in looking at
https://ls1tech.com/forums/dynamometer-results-comparisons/586000-403ci-reusing-stock-manifolds.html
also blower + auto cross, there is no point to it, you will never hit redline in an auto-x where peak power is made. if you do your asking for tail whip lash action with 13 psi. all motor and gears for auto-x. blower is a waste IMO. i ran in SCCA for 2 years, 1 full season with a blown S2000 which worked out great, gave that car the extra power it needed. in a f-body, it needs suspension in order to run auto-x properly, not gobs of power.
take the LS2 to a 4.030 bore + 4.1" crank and make a 418 ci motor out of it and you will be in the 550/500 territory on motor alone with all the right parts. power under the curve will kill a blown 346, i think even with pushing 12-14psi
sell your old motor, sell the blower to pay for a LS2 418ci.
Old Oct 18, 2006 | 06:07 PM
https://ls1tech.com/forums/showthread.php?t=586000
Thanks for the reply.
I still would like to know what size valves are in these heads?
Thanks
Al
Old Oct 18, 2006 | 10:16 PM
cws T/A's Avatar
I dont think you can bore a sleeved { aluminum LS2 }engine only Iron . You will have to resleeve to add cubes .
If your not going to stroke the LS2 you wanna build its not worth it , your more at risk of detonation with the larger bore.
Them injectors will be 2 small at a 14psi power level
Methanol is good but , you should run an FMIC
