Track Time Compilation updated 5 MAY 2015
Old May 22, 2010 | 11:55 AM
  #61
havelegs's Avatar
Originally Posted by DavidGXP
Before I got tuned, I left the trans in drive and once the trans shifted into 2nd I moved the shifter down to M and up shifted at 5800-5900rpm. You should just pass through the finish line when you tapshift into 3rd.
stock 2-3 shift in auto is way to early. I think its at 5400. You need 5950 realistically.
And this helped me a lot. Enjoy!
http://www.zzperformance.com/grand_p...les1.php?id=21
I keep mine in 2nd, I have a plug in tune that bumped up that shift point to redline however I still hold 2nd for as long as possible.
Old May 22, 2010 | 11:56 AM
  #62
AlabamaGuy's Avatar
Originally Posted by havelegs
Went to the track again last night
Best run of the night on a hot 85 degree humid night
.684 RT ( I need to work on this )
60' 2.12
1/8th 9.0
1/4 13.94 @ 99.8mph
Catless?
Old May 22, 2010 | 12:02 PM
  #63
havelegs's Avatar
Originally Posted by AlabamaGuy
Catless?
Catted DP, I can't deal with the fumes of no cat
Old May 22, 2010 | 12:03 PM
  #64
havelegs's Avatar
Also, I should add that I run with the cutout open. I should probably give it a try with it closed to see if I get any improvements.
Old May 23, 2010 | 09:26 AM
  #65
2005gxp's Avatar
13.9@96mph 2.12 60' k&n intake and flowmasters. all season tires.
Old May 23, 2010 | 09:32 AM
  #66
rquinn19's Avatar
Holy low trap, Batman
Old May 23, 2010 | 11:58 AM
  #67
AlabamaGuy's Avatar
That's what I'm sayin! Should have been higher than that with that 60'. The ET is dead on though...
Old May 23, 2010 | 12:15 PM
  #68
Gorske's Avatar
14.046 @ 100.94
2.287 60ft.
With Goodyear RS-A tires with 42,000 miles on them at 22psi, launch off idle. Was about 75 degrees for that pass and I spun about half way threw 1st. Im still happy with it.
Old May 24, 2010 | 11:47 AM
  #69
MidLifeCrisis's Avatar
13.93 @ 101.79
2.19 60ft.
Stock tires with 25,000 miles at 30psi all around and 3/8th of a tank of gas. It was my first time at the track in this car. Made five passes in all, this was my best run of the night.
Old May 25, 2010 | 09:06 PM
  #70
CenTexSS's Avatar
60' 2.12
1/8th 9.0 @ 79.1 mph
1/4 13.94 @ 99.8 mph
On factory tires
Those are scary similar to my times when I had a catted DP and that kind of weather.
Old May 26, 2010 | 08:27 PM
  #71
havelegs's Avatar
Are you running an exhaust cut out as well? I keep mine open and it is at the bend before the cat on my DP.
Old May 27, 2010 | 12:18 AM
  #72
AlabamaGuy's Avatar
Gentlemen, let's try to keep this thread as un-cluttered as possible. If you have any questions for people about their times let's start using PMs. Feel free to congratulate or comment on the times but specific questions are probably better left to private messages.
Old Jun 3, 2010 | 07:59 PM
  #73
CenTexSS's Avatar
C'mon AG, you're the only one that doesn't list specific mods!
Old Jun 3, 2010 | 11:44 PM
  #74
AlabamaGuy's Avatar
Old Jun 21, 2010 | 04:22 PM
  #75
94ss06gxp's Avatar
throw me up there, im 405m left lane, mods in airbox mod, !res!, cutout.
Old Jun 26, 2010 | 04:50 PM
  #76
JP_GXP's Avatar
Rossko ran a 12.95 @ 109.3 with a 2.04 60', 8.45 @ 86.7 1/8. Mods listed N2O@100, CAI, PwrAidTBS, HOGANDPw/RP ,Res.del, Borlas., Poly-Mmnt, Trans Cooler, Street radials.
I looked it up because I'm probably gonna put nitrous on mine and thought it should be posted.
Old Jun 26, 2010 | 05:57 PM
  #77
2005gxp's Avatar
13.629 @ 106.67MPH 2005gxp 2.2 60' DT headers/res/flowmasters/custom tune/K&N Intake/ubend/ssc's street tires
Old Jun 27, 2010 | 11:15 PM
  #78
AlabamaGuy's Avatar
Holy ****! nearly 107 mph?!?!?
Old Jul 9, 2010 | 02:29 PM
  #79
2005gxp's Avatar
ran a 13.6@101 last saturday, last olne was still better lol im still peeling the rubber off my slicks
Old Jul 10, 2010 | 04:25 PM
  #80
AlabamaGuy's Avatar
Was teh timing off at your track when you trapped 106? This time you had the same ET but trapped 101.
