Old Apr 26, 2016, 01:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
LS4 Transmission Problem Thread (4T65-HD); Current Total Inside
Old Apr 9, 2014 | 08:11 PM
  #441
jimzz430's Avatar
Unhappy Ditto
My '07 SS tranny went about a month ago, 92K, never a problem ever before. Still drives when it hasn't warmed up, but when it does, there's nothing. I shut it off for a while a few miles from home and when I restarted I was able to limp back home and up my driveway. Going to take it out this weekend, it's finally warm here.
Old Apr 14, 2014 | 11:34 AM
  #442
jsmith309's Avatar
My trans from a stop feels like its starting out in 2nd then after pulling for a few seconds feels like it downshifts into first. almost a rev and clunk but its pulling forward the whole time.
Old May 29, 2014 | 08:39 PM
  #443
Brittmcss's Avatar
Mine was slip banging in my 06' monte ss, I put in the shift kit for it and it fixed my problems, well for now.
Old Jun 29, 2014 | 07:00 PM
  #444
MidnightMafia's Avatar
GM 4T65 RACING TRANSMISSION COMPONENTS (GM writeup, kinda interesting)
Old Sep 17, 2014 | 12:17 PM
  #445
catsat43's Avatar
Originally Posted by D J Real
holy hell, I think the real question is who still has their stock trans and hasn't had any problems? **** I think just me and a few others on here fall into the category.
My 2008 gxp has over 78 thousand miles on it.I have owned it for two months have no recordable issues with it.
Old May 4, 2015 | 01:01 PM
  #446
BILL BERESFORD's Avatar
Default 2009 Impala SS
Recently my SS Impala has been not shifting into 1st gear when stopped.
At take off it will start out in 2nd then a abruptly shift down to 1st resulting in a harsh "thump" I recently had a BG flush done on the tranny and the fluid is new and full. When shifting manually it works fine. I have been told it is a sticky shift valve and to just drive through it for a while and it will work it self out. I don't buy that. Have any of you had this issue? What else should I look for? How about an additional additive? Prior to the flush it was starting to do this and why I decided to do the flush.
Also it dosent do this all the time. I would say about 6 out of 10 starts it will happen. when going down the road all is well. shifts smooth, down shifts smooth when passing.
Thanks for your time.
Bill
Old May 25, 2015 | 06:19 PM
  #447
Sint3k's Avatar
Bill
There is a seal that applys the forward clutch, it starts to allow fluid around it and it does not build up pressure, thats why manually shifting it works, because the when the shifter is in 1st, the pressures are higher allowing it to overcome the leak. I drove like this for years and had no additional problems for a long time. Eventually i had it rebuilt by TEP.
Old Jun 2, 2015 | 09:59 AM
  #448
spawne32's Avatar
official diagnosis of the failure of mine at 100k from the trans shop was burnt input clutches, actuator fit limit valve failure and snapped forward and reverse bands. Go figure.
Old Jun 3, 2015 | 09:51 AM
  #449
rottonj's Avatar
That was a good rebuild job the last owner paid for.
Old Jun 3, 2015 | 12:21 PM
  #450
spawne32's Avatar
lol they didnt even open the trans up, they said everything in there was original GM stuff. shame there is no way he can get any recourse for that, guy paid well over 2000 bucks for the trans and never got anything.
Old Jun 9, 2015 | 12:29 PM
  #451
wallyn70's Avatar
ok, not sure if im at the right place, but here goes. 2008 impala ss. sometimes when I
stop at traffic light my trans drops out of gear, then when I press on the gas, it jumps into gear. only does it sometimes, mostly in the morning after about a mile and a half.
(first traffic light.) then its good for the day.any ideas? also cost to fix? thanks, wally.
Old Jun 14, 2015 | 07:24 PM
  #452
Sint3k's Avatar
Its a common problem with the forward seal leaking, there is no fix until you have it rebuild , in the mean time use the shifter manually when starting out and put it in 1st, this will raise the line pressures to overcome the leak.
Old Jul 26, 2015 | 01:11 PM
  #453
BALBI's Avatar
Originally Posted by 06MonteSS
I've owned my car since brand new.. I special ordered it when I bought it... and I made it to 100,000 miles on my stock original tranny...
I'm now on my replacement GM SERTA tranny, and am at just about 102,000 miles...
2006 Impala SS with no mods. I am the original owner with 140k miles.
I started to see the slippage at stops signs recently.
Old Oct 1, 2015 | 04:55 PM
  #454
07Montejr's Avatar
Default Rebuilt @ 97,000
My trans had the typical issue of soft 1-2 shift and poor reverse engagement then the day it went out it was a "o" ring failure that bypassed all the pressure out the vent.
I did a performance upgrade with hardened shafts
Shift kit
External cooler
Mini high stall converter
Program updates from Baker Engineering
Now I have a problem with it randomly stalling from what seems to be the tcc not unlocking
Old Oct 1, 2015 | 05:36 PM
  #455
91parkave's Avatar
Moderator
Shift kit
External cooler
baker needs to go through your tune again
Old Mar 6, 2016 | 10:03 AM
  #456
chauncey's Avatar
08 GP GXP bought in 2011 with 85k. Rebuilt trans. and new TC shortly after at 86k under 100k powertrain warranty. Now in 2016 with 112k, obviously not drove daily, slipping at lockup. Knew it was going to happen but not this soon. Time to find me a G8.
Old Mar 6, 2016 | 01:00 PM
  #457
rottonj's Avatar
Where was the transmission rebuilt? 26k is crap
Old Feb 4, 2017 | 07:23 PM
  #458
NewmansLS4's Avatar
Default Pretty much gone
Originally Posted by 91_rs-teal
81k on stock GP trans 200 degrees when idling WOT slighty chatters into second. Also soft shift then slight accel (not fully into 2nd) results in slip from first then clunk into second. so have to watch how i drive
Originally Posted by LS1 Racing
Thanks for posting. I've added you to the list and total.
06 GP GXP 140,### miles and slipping bad sometimes it will shift just fine but now more than ever slipping when take off won't budge I'll shut it off then start it back up sometime it will go. And thanks for your post
Old Feb 4, 2017 | 07:40 PM
  #459
NewmansLS4's Avatar
Default Slipping
This thread has moved to http://www.gmls4.com/index.php/topic,33.0.html , which is at GMLS4.com.
It will no longer be supported or updated on this site. Please visit the above link to report issues and obtain information regarding the transmission problems that are so common to the LS4 cars. You will also find resources there that will teach you what you need to know about addressing and preventing the problems from happening again.
I have a 06 GP GXP 141### miles and I think it's finally gone the transmission that is, for the last couple of weeks slipping once in a while between 1-2 and sometimes it wouldn't sometimes I could push the throttle little more than it would grab, tonight I had to shut it off and start it back up then finally I was able to make it home, just curious to which way I should go different torque converter and clutches with shift kit, or rebuild kit
Old Sep 8, 2017 | 09:08 PM
  #460
Nathan Pfoh's Avatar
time for a new transmission or rebuild..
these trannys are only good for around 90-100 thousand miles..
my 07 Monte Carlo AS is in the shop as we speak getting a new one.
