Old Apr 26, 2016, 01:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
LS4 Transmission Problem Thread (4T65-HD); Current Total Inside
Old Jan 19, 2011 | 07:49 AM
  #101
LS4_SS's Avatar
you can go ahead and move me from the slippage list to the complete failure list now.
kthxbye.
Old Feb 2, 2011 | 12:11 AM
  #102
06ssimpala's Avatar
hey guys i bought my ss last summer and it had 75k on it when i bought it.. months later roughly 82k one day taking off from a light (normal excel) it suddenly came outta gear, as soon as this happend i let off the gas and it went back in. it happened a few more times after that.. it comes and goes. sence about 88k it hasnt done it. now im at 91k Just put a cooler on it 2 weeks ago, does this mean the tranny is on its way out?
Old Feb 2, 2011 | 05:48 AM
  #103
blakss's Avatar
More than likely you'll join the club pretty soon
Old Feb 2, 2011 | 04:49 PM
  #104
06ssimpala's Avatar
oh nice!.. looks like ima drive this car alote less and drive my Spirit R/T more.
Old Feb 2, 2011 | 05:04 PM
  #105
LS1 Racing's Avatar
Added you to the list.
Yes, you trans is well on it's way to the grave yard.
Old Feb 2, 2011 | 11:06 PM
  #106
ChipC's Avatar
Add me to the list on replacement. 80K miles on the first one. It was replaced under warranty with a GM replacement. Replaced the second one and torque convertor under warranty at 97K miles. I am at 103K right now.
Funny thing, I have not really been hard on this tranny as far as acceleration. One time at the track at 10K miles and made 5 passes. I have driven a large number of high speed highway miles (90mph - 125mph interstate passes of 100 - 300 miles). I really believe heat seems to be more of a problem. Unfortunately, this car just seems very comfortable at these speeds.
I also have a 97 GTP with a swapped pulley (swapped at 40k miles) and of course the earlier, weaker version of this tranny with 104K miles. Original tranny and no problems. I have made somewhere north of 100 track passes with it, but nowhere near the number of high speed highway miles. Really interesting how the same design has held up quite differently.
Chip
Old Feb 2, 2011 | 11:52 PM
  #107
LS1 Racing's Avatar
Chip
The failures that are so common with the transmissions has little to do with how you treat them. If you look at some of the other threads here, you'll see that it happens to be people who baby their cars just as often as it does to those who abuse.
There are some major differences in the valve body compared with your GTP. The LS4 version is tuned to shift extra smooth, and the compromises that GM made to achieve that also shorten the life of the trans. On top of that, you've got poorly designed and engineered parts in the valve body that cause TCC issues. And to top it off, the LS4 is probably making 40 lb-ft of torque more than a pulley'd GTP.
Combine all of those things, and you have long list of failures.
Old Feb 4, 2011 | 12:25 PM
  #108
BLKGXP's Avatar
...add my '05 GXP to the failure list. Bought it 2 summers ago with 51K and it was slipping badly/running high temps by the following spring. Gave GM $3000 for a certified tranny (62K) and they even let me see all the shiny medal in the pan- awesome.
I've always owned Pontiac, GTP-Fiero-GXP but its a straight up robbery they cut so many corners trying to make that tranny work in our cars-
Thanks for putting this to a list!
Old Feb 4, 2011 | 01:02 PM
  #109
LS1 Racing's Avatar
Added you to the FAILED list.
Old Feb 4, 2011 | 02:12 PM
  #110
LS4_SS's Avatar
as i said before, you can move me to the failed list as well
Old Feb 4, 2011 | 02:46 PM
  #111
LS1 Racing's Avatar
Updated you on the list.
Sorry about the delay!
It's amazing that the failed versus problem ratio is nearly even.
Old Feb 4, 2011 | 11:43 PM
  #112
LS1 Racing's Avatar
We've reached forum immortality: Sticky Status!!
Old Feb 5, 2011 | 10:58 AM
  #113
BigEd_98Formula's Avatar
I don't own a GXP but was eyeballing them as a replacement for my CompG.
I bought a truck instead because for I work basically needed one.
What's surprising to me is that there are so many failures when you consider GM pretty much had the aftermarket torture testing these 4t60's style transmissions behind the 3.8 Supercharged motors, we pretty much found out what breaks in high hp, more so high torque, applications for them....which really in marketing materials were described as GM FWD V6 transmission and the 4t80 style as V8 FWD transmission, although it pretty much is exclusively behind the Northstar.
I was really hard on my CompG, and other than changing the fluid and watching out not to cook it, was fine. I'm not going to sugar coat it, I put a pulley on it, did ton's of burnouts, and even did an off road rally in the winter with it and pushed it to "keep pace" with some of the Subaru's.
If any of you are in the Buffalo Area, feel free to send me PM if you need help finding people to help you should you find yourself needing work out of warranty. There's a strong group of performance guys who know GM stuff very well in the area.
Old Feb 5, 2011 | 03:24 PM
  #114
Dante06's Avatar
Add me to the second list, Ive got the slip, rev, clunk deal going on. Still running though.
Old Feb 6, 2011 | 12:52 AM
  #115
LS1 Racing's Avatar
Added you to the list!
Old Feb 7, 2011 | 05:29 PM
  #116
jdwilks's Avatar
I am already on the list but have a question. Mine is getting worse and worse finally so do you just take it in or schedule an appt? And what happens if they find nothing wrong, will I be out a diag fee or anything? I also noticed I am burning a good amount of oil which I know there is a TSB for it but not sure there is a fix from GM yet. Never got a low pressure light (or low oil light) but I was a good 2 to 3 qts low. Guess I need to start keeping a better eye on it
--Edit/Update -- Made an appt for next Friday (Feb 11th) to have my transmission looked at by the local GM dealership. Hoping they determine its crapped out and ready to replace. We shall see
Old Feb 7, 2011 | 06:18 PM
  #117
LS1 Racing's Avatar
Depends on how busy your dealer is. I had developed a good relationship with a service manager because of the problems I had, so I would always call him the day before bringing it in
Definitely get it in and have them pull the pan. I'm sure they'll find material in it, and you'll get a rebuild or a SERTA unit.
Old Feb 7, 2011 | 09:50 PM
  #118
BigBlackBoxChevy's Avatar
Any idea when my trans will completely fail? The last 4 months or 6,000 miles the TC has been engaging and disengaging from 40-70mph. Really frustrating when you try to pass someone and your car falls flat on its face.
For the first time last week my car started shifting from 2-3 almost immediately after it gets into 2nd. Haven't seen anyone with this issue. Just wondering when I'm gonna get in my car and it not move.
Old Feb 8, 2011 | 09:42 AM
  #119
LS4_SS's Avatar
VERY soon.
mine did the tcc slipping higher in the rpm range for about 3 or 4 days, then finally took a crap
Old Feb 9, 2011 | 06:02 PM
  #120
chaley1987's Avatar
getting a real bad clunk and stutter going about 50-60 mph. its so bad, it feels like the car is going to shut off. started as every three days, it is now an everyday problem almost making it undrivable. so i am slowly stacking funds for a rebuild.
