Project gutted Formula
Old Jan 10, 2009 | 03:39 PM
  #41
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by 3rdgen92maro
holy crap man thats a hell of a list you got there. thanks for the reply it looks like i most of the stuff you have on the list plus the entire hvac system and power steering. your car is gonna fly once its done. ive been following your build on both of your cars for some time youve done some great work. thanks again for the reply man.
hows the sunny weather in FL man i wish i still lived there...****** snow
Yes, that list has taken a lot of time to put together. A lot of the little things really add up once you get to cutting on things. It is definetly addicting when you start cutting. You start thinking, "What else can I cut out? How much does this weight? That shouldn't affect the structural integrity of the vehicle too much.... Should it? Oh well, I'll cut it out any ways."
1200 rwhp and around a 2900 lb raceweight should make my 93 a lot of fun. I got a few major parts for it today. Thanks for the kudos on the projects. It's a lot of work as I'm sure you are aware of.
Florida is awesome as always. It is roughly 78 with a breeze and sunny.
Old Jan 10, 2009 | 06:09 PM
  #42
krill's Avatar
Looking god man, nice wheels BTW
Old Jan 10, 2009 | 10:08 PM
  #43
Formula350's Avatar
1200?! >_> Unless things have changed and you went and bought the GMPP LSX racing block, I'm not sure you'll be able to reliably make your goal
Old Jan 11, 2009 | 12:00 PM
  #44
fuel's Avatar
its giong to be a high of 58 on friday, in the tampa area. good racing weather if you hooh up
Old Jan 11, 2009 | 03:25 PM
  #45
OWN3D BY MY PROF!
Before I .... The update is coming soon. I'm just waiting on some parts to get here.
Old Jan 11, 2009 | 09:44 PM
  #46
Formula350's Avatar
I await it
Old Jan 17, 2009 | 08:33 PM
  #47
3rdgen92maro's Avatar
im finally back from hell thank god.
Old Jan 17, 2009 | 11:07 PM
  #48
hopefully i can get some work done on the car this week. i wanna freaking drive it already.
Old Jan 25, 2009 | 02:23 PM
  #49
well its finally going back to together. got the dash, clutch and alt bracket put on last night. with any luck itll be running today. ill get some pics of the progress.
Old Feb 1, 2009 | 04:34 PM
  #50
a few updated pics of the car...i got a set of prostars to
my custom hvac delete panel
my new alt relo bracket courtesy of blackz93
Old Feb 1, 2009 | 04:36 PM
  #51
next on the list of mods is QA1 R series front coilovers, competition eng. drag shocks and adj LCA's hopefully those go on today
Old Feb 5, 2009 | 07:38 AM
  #52
matthewjosh's Avatar
I can tell you right now that you're not around 300 lbs.
Mines near 306 lbs, but that only includes the items I am not putting back in. Mine is still going to have the AC, PS, both stock front seats, and all the interior panels.
Front Bumper Support = 25.375 lbs
Fog lights and brackets = 4.0625 lbs
Cruise control, cable, and throttle cable cover = 4.4375 lbs
Air pump and brass fittings = 5.9375 lbs
Stock horns = 1.875 lbs
Stupid siren and loud horn = 2.5 lbs
Stock Y pipe and single cat = 21.1875 lbs
Frame horns = 5.125 lbs
Fender metal = 1.25 lbs
Rear Seatbelts = 4.1375 lbs
Aftermarket Speaker Wiring (will be added to considering there is a ton more of it) = .25 lbs
Carpet = 29.0375 lbs
Windshield washer fluid resevoir with water = 8.0625 lbs
Heat shields beneath the car = 2.1875
Soon to be useless exhaust hangers = 2.00 lbs
Rear Seats = 22.4375 lbs
Random exhaust hangers, brackets, nuts, and bolts = 9.25 lbs
Front Speakers = 2.75 lbs
Rear Speakers = 3.25 lbs
Front Speaker Brackets = 1.25 lbs
Interior brackets including (rear seat brackets, antenna bracket, rear seat belt brackets) = 3.875 lbs
Security System Hood Lock = 2.6875 lbs
Antenna + Wire (not including the actual metal rod) = .25lbs
Stock catback = 50.1875lbs
Rear Armrests = 4.21875lbs
Extra Metal Trimmings = 1.00lbs
Emergency Brake System = 12.125lbs
Door Fiberglass = 1.90625 lbs
Door Crash Bars and Brackets = 17.5625 lbs
Window Regulator Metal = 1.8846535171744791666666666666667 lbs
Driver's Air Bag = 3.625 lbs
Passenger's Air Bag = 9.46875
Heater Core (empty) = 1.03125
AC Tube = .09375
Black Mat = 10.03125 lbs
Airbag Crash Sensors = 1.53125 lbs
Mat That is Underneath the Dash Pad = 2.34375 lbs
Heater Core Hoses = 2.0125 lbs
Front Sway Bar = 15.09375 lbs
Plastic Shrouding = 4.968749 lbs
Power - Manual seat slider = 14.4375 - 10.8125 = 3.625 lbs
Grand total to this point = 305.884699 lbs + all the stuff I still have to either cut out or weigh.
I still have roughly 300 lbs that I plan on removing or cutting. I had a really good list of everything I have and planned on removing going on my other computer, but it crashed. I need to try and get it off of there some how. It should be around 2900 lbs with me in it once it is operational. Eventually, I could get it down to 2650 retaining the amenitites I listed above by my calculations, but plans have changed and I'll be adding a few heavy objects.
There's a link to my 93 project in my sig if you would like to check it out. I should be updating it starting next week. I'm working on gathering parts for the new engine now and I should start putting the interior back together on Monday or Tuesday.
Good luck with the weight reduction. The most important thing to remember in regards to taking out weight is all of the little things add up.
What are the frame horns??
Old Feb 5, 2009 | 09:21 AM
  #53
Black94Z28's Avatar
Wow! its scary how similiar your build up is to mine! I removed all the stuff u had, my alternator setup looks identical, and you have the wheels i WANT!! Check the link in my sig as i should start cutting come nicer weather!
Old Feb 5, 2009 | 10:12 AM
  #54
CamaroRacing12's Avatar
its strange... this is like the season of weight reduction builds.... its a hip trend nowadays... hell im on the bandwagon... go fast for cheap
Old Feb 5, 2009 | 12:33 PM
  #55
AChotrod's Avatar
Damn you guys!! Ill get started on mine soon!
Old Feb 5, 2009 | 12:48 PM
  #56
BlackLT1Z's Avatar
This is how all the LS1 boys brag about their times. Unless we are willing to do the same thing... we wont be able to brag.
Old Feb 5, 2009 | 12:50 PM
  #57
ill have to check out your build. gotta love some prostars all though idk how the stock 10bolt is going to handle the 28in ET STREETS. needless to say im on the hunt for a new rear. the 28s should make my car drive like it has 2.73 gears in it LOL.
It deff is the season for that.LOL gotta go fast and cant afford all the parts to make big power so i just decided to make it as light as possible. im hoping for 12.3s out of it
well get to work already...the winter is ticking by LOL
Old Feb 5, 2009 | 12:59 PM
  #58
With the 275/60/15 ET STREETS
i know there on backwards...i just wanted to see what they looked like
Old Feb 5, 2009 | 01:19 PM
  #59
SoxXpupPeT's Avatar
i Love the look of Mt's on the back like that! Looks great man!
Old Feb 5, 2009 | 02:17 PM
  #60
Black94Z28's Avatar
Drool...my pants are tight starring at those weld prostars! Was going to get a set but i OWE this year for taxes Anyways bad *** car! U need some full shots of it!
