anyone know about a 94 lt1 timing chain
Lunati does make a timing set for early non-vented setups, but it hardly better than the stocker (bar-link type). The OP is asking for a heavy duty alternative it seems, and the only real solution is the LT4 ED kit or a double roller such as the Cloyes 3145.
JMHO, of course.
JMHO, of course.
JMHO, of course.
JMHO, of course.
after i get the motor back ill b hoping for 900-1000 thru a th400. so ya im not sure bout a stocker! and i have a brand new opti. what all parts will i need to convert? later model opti, later model cover, and what else?
For that kind of power, you'll need a double-roller, hands down. You need an electric water pump, 95 timing cover, vented optispark/accessories (including vacuum tubing and harness).
Just curious, what type of setup are you planning on running? 1000HP is a ridiculous amount of power through an LT1. Expect some flak unless you spill the beans.
For the LT1 (1992-94)
Timing chain
30-125
$29.95
Cam gear
30-130
$365.95
Crank gear
30-131
$29.95
Water pump drive gear
30-132
$89.95
Complete kit
30-135
$549.95
well before i took it apart it put down 670 thru the th400, and that was with stock casting heads, stock lt1 intake, a2A intercooler, pump gas, at 14 psi. now its getting ported afr 220's, ported lt4 intake, A2W cooler, race gas, a little more comp, and more boost! so i think 900 will be easy, but hoping for 1000! might have to change turbos to get there tho!
