EFI 24X LS1 pcm conversion
Old Jul 14, 2011 | 09:21 PM
  #61
BOLO's Avatar
^^ What??
Old Jul 14, 2011 | 09:27 PM
  #62
TravisA's Avatar
Lol! ^
Old Jul 18, 2011 | 12:31 AM
  #63
Kytong's Avatar
Originally Posted by BOLO
Finally doing the conversion slowly but surely. Here's some photos that I've taken so far. Still waiting on other parts to finish the conversion. Sorry: pics are not in order.
http://s742.photobucket.com/albums/x...camaro/EFI24x/
Great pics bro! Can't wait to see the finish product!!
Old Jul 18, 2011 | 07:06 AM
  #64
BOLO's Avatar
Thanks Kytong.
Old Jul 18, 2011 | 12:14 PM
  #65
qc97z's Avatar
Originally Posted by MTBSully
can you tune with EFI live or HP tuners if you do this mod?
Absolutely. Speed Inc tuned mine. I'm the first EFI Connection 24x car they've tuned, IIRC. They did a fantastic job.
Can you post some pics and/or vid on the conversion? Any pros and cons on the install? Thanks.
Absolutely no cons. It's a simple, straight-forward install, with very high quality components. And your tuner will thank you.
Originally Posted by dr97z
I have the conversion on mine now. First time in 6 years that I've had no misfire. So far, very worth it.
^This. Worth every penny.
Originally Posted by Nastyc4
Last I spoke to the guys who make the conversion there was no way to use a double roller etc under the cover with the reluctor. ANyone have any input on wether or not that is still true?
EFI Connection manufactures a cover that can work with a double roller, and stock timing covers can be machined to clear one as well.
Old Jul 18, 2011 | 01:08 PM
  #66
Firebat's Avatar
qc97z - Not running a MAF?
Old Jul 18, 2011 | 04:39 PM
  #67
qc97z's Avatar
Hell no! Speed Density all the way. It's easy to max out a mass airflow sensor when you're boosting 15 psi.
Old Jul 18, 2011 | 09:26 PM
  #68
BOLO's Avatar
qc97z, very nice set up. Are those custom plug wires? And yes, I may also go SD for my present combo. Again nice job on the conversion!
Old Jul 19, 2011 | 08:21 AM
  #69
qc97z's Avatar
Yep, they're MSD #32079, available from Jegs, Summit, etc. It comes with the LSx coil end boots and terminals, and a crimping tool.
Thanks for the compliment!
I also responded to your PM, FYI.
Old Jul 19, 2011 | 08:42 AM
  #70
VinR1's Avatar
are those plastic zip ties holding the wrap on that last primary?
Old Jul 19, 2011 | 09:31 AM
  #71
qc97z's Avatar
Lol, good catch. Yes they are. That pic was taken just after getting the header wrap on, and the parts shop supplied me the clips for a V6, and not a V8. So, I was short on the steel clips, and used the zip ties just to hold it on tightly to cure. They were replaced the next day with the proper clips.
Old Jul 20, 2011 | 08:35 AM
  #72
Sc0tt30's Avatar
Is there a big advantage on doing this conversion when running a supercharger? I may just be overlooking it. I see you get rid of the opti, which is great, and can take the engine up to higher rpms. Just trying to determine if it is worth going from a odb1 pcm to this.
Old Jul 20, 2011 | 08:43 AM
  #73
qc97z's Avatar
Absolutely. You get the tunability of an LS1 PCM, and the reliability of the ignition system.
Going from an OBDII LT1 PCM to an LS1 PCM is like....going from MSDOS to Windows XP.
If you want to do this on an OBDI car, you'll need a 96-97 style timing cover with the crank sensor provision.
Old Jul 20, 2011 | 08:48 AM
  #74
Birdie2000's Avatar
There are custom firmwares for the LS1 pcm that allow using a 2 or 3 bar MAP sensor so the computer can monitor boost.
Old Jul 20, 2011 | 08:49 AM
  #75
Sc0tt30's Avatar
The car is a 97. I did a OBD1 conversion on it before. You don't have to buy a new cover if your running a double timing chain?
Old Jul 20, 2011 | 10:23 AM
  #76
moehorsepower's Avatar
You can run a 2 bar on an OBD I for boost..Thats the purpose for running a 2 bar. I did it back in 97 on my 95 and ran 14lbs...
Old Jul 20, 2011 | 12:54 PM
  #77
qc97z's Avatar
My PCM doesn't have a "custom firmware" on it, and I have a FAST 3 bar map sensor on mine. works like a dream. Not sure what you're smokin'.
You need to have the 96-97 style timing cover to run the conversion. I assume you still have it on the car, considering it's a 97. You can run a double roller either by having your timing cover machined for clearance, or buy a billet piece from EFI Connection. Why do you need a double roller anyway? It's overkill.
Old Jul 20, 2011 | 03:16 PM
  #78
Birdie2000's Avatar
Well I apologize, I remember people talking years ago about being able to load a modified operating system on the LS1 pcms using HPTuners or something like that to allow them to use 2 and 3 bar maps in order to more accurately monitor and tune for boost. I was under the impression that you could do it on an LT1 pcm but you would give up a lot of resolution on the tables. Sorry if I'm misinformed.
Old Jul 20, 2011 | 03:30 PM
  #79
Tricked-Out-Toy's Avatar
Im confused, How are you doing that without a custom OS? What boost levels are you running?
Old Jul 20, 2011 | 03:35 PM
  #80
T/A KID's Avatar
I have the conversion and I am running the custom OS 2 bar SD. qc97z I would like to compare specs with your tune and mine, primarily the VE table and spark table. PM me if your interested. Thanks Ben
