Help pushin a stockbottom end lt1 into the 10s
Old May 8, 2012 | 02:29 AM
  #181
1961ba427's Avatar
Anything to update?
Old May 8, 2012 | 02:39 PM
  #182
chas010's Avatar
No not really , i drove the car around town but im currently waiting for pcmforless to email me a tune.
Old May 8, 2012 | 05:17 PM
  #183
Jason94z's Avatar
Originally Posted by chas010
What do I need to buy to get that intake working on my Lt1?
I have no AC or anything.
Do I get a "upper air box removed when new 50" and then the cold air thing from speed inc? What else do I need?
Edit: will if fit under my stock hood?
Thank you
Old May 8, 2012 | 05:23 PM
  #184
chas010's Avatar
Yes Its an entire ls1 intake and speed inc ram air kit.
No, It will not even come close to fitting under a stock hood.
Old May 8, 2012 | 05:46 PM
  #185
BADHAWK51's Avatar
Any plans on attending the shootout ?
Old May 8, 2012 | 06:35 PM
  #186
Mississippi's Avatar
Originally Posted by joelster
I think he wants to do it N/A, Spraying into 10's is too easy at the ET he's at.
I didn't know you had everything removed under the hood like that, lol. That thing IS pretty light.
!headliner
!visors
!console
!passenger seat
drill out every stupid bracket in the interior, there will be like 4-5lbs worth
grab the sawsall and have at those inner fenders
!door bars
!E brake
shallow stage
get the front tires rock hard
adjust your launch rpm for 3 consectutive runs and pay close attention to the 60ft. You may be surprised at what your car is happiest with.
For $$$$ stuff
ditch the cat-back and run some flowmasters off of each pipe. Flowmasters work extremely well in a blow-through system (not a transverse design like stock f-bod). They are light and relatively cheap. Car will pick up a few top-end ponies and shave about 20lbs easy.
Plastic racing seats. Will save 35lbs on the driver side
I'm sure a smooth elbow might free up 2-3 ponies but.........
I would run some sort of ram air setup ditching the foglights. It will add power up top, especially over 50mph. Mine can be duplicated for about 20bucks.
Here is mine:
The rubber piece between the TB and maf is from Lowe's in the pvc section. It is made by fernco, it is like $7,00 or something. The chrome piece is by spectre but you can run dryer tubing which is flexible and will get the job done. After mine goes under the rad support there is a Y piece and then dryer tubing through each of the fog light holes. Tiny filter attached to the Y, but you can run without them at the track. You can honestly make a similarly effective setup for about $20.
Hey man, have you done a right up on that ram air set up you are running? I really like that and it looks great. If you haven't done a right up you should or at least pm me the info. Lol.
Old May 10, 2012 | 04:28 PM
  #187
chas010's Avatar
Tune came in..Sweet!
Old May 10, 2012 | 04:39 PM
  #188
Jason94z's Avatar
OK thanks
Scratched off my list of "to do" hehe
Old Jun 9, 2012 | 04:57 PM
  #189
chas010's Avatar
https://www.youtube.com/watch?v=Otad...e_gdata_player
Shake down passes!
Old Jun 9, 2012 | 07:27 PM
  #190
TravisMcGill2000's Avatar
What was thw times... I couldnt tell
Old Jun 9, 2012 | 07:53 PM
  #191
chas010's Avatar
That run was a 10.94 at 123
Old Jun 9, 2012 | 08:29 PM
  #192
joelster's Avatar
Got any vids of me?
Old Jun 9, 2012 | 08:30 PM
  #193
Congrats man. That thing rollin out. Whats rest of th slip look like.
Old Jun 9, 2012 | 09:47 PM
  #194
chas010's Avatar
I'll upload one Joel
Old Jun 9, 2012 | 09:51 PM
  #195
chas010's Avatar
This kinda mild tune was set to shift at 6400 to test it out. Im already running better than a tenth faster than the 503 can that was shifted at 6800. I'll tune it down to 10.80s this year in the heat
Old Jun 9, 2012 | 10:56 PM
  #196
1961ba427's Avatar
Nice....looks like it's well sorted and easy to drive too. I bet it's very consistent.
Old Jun 9, 2012 | 10:57 PM
  #197
3DFORMULA's Avatar
Congrats!
Old Jun 10, 2012 | 01:24 AM
  #198
TSAEB's Avatar
Very nice !!.
Old Jun 12, 2012 | 08:21 AM
  #199
chas010's Avatar
Originally Posted by 1961ba427
While it's torn down that far....is there any way you could try your alternator mount on the driver's side? Or just look and see if you think it would fit if you just flipped it around. I would really appreciate it, but you will probably be past that by the time you read this.
Sry I didnt see this in time. I tried to measure it up as best I could and it looks close.
Old Jun 12, 2012 | 08:15 PM
  #200
studderin's Avatar
My favorite LT1
