Help pushin a stockbottom end lt1 into the 10s
Old Jan 29, 2012 | 08:50 AM
  #141
joelster's Avatar
Extreme Street N/A is calling you!
Old Jan 29, 2012 | 09:05 AM
  #142
3DFORMULA's Avatar
Originally Posted by chas010
Its time to start thinking about this upcoming season I'm going to swap out the cam for something new and see what she'll do.
Fantastic news, good luck
Old Jan 29, 2012 | 09:25 AM
  #143
1961ba427's Avatar
That's great to hear. Did you ever get an aftermarket TQ arm or shocks?
It's been awhile since I read this whole thread....do you street drive the car much? Asking because that will really effect your cam choice. Being one the stock bottom end effects it too I'm sure. I bet you will want to keep your max rpm close to where it is now.
Old Jan 29, 2012 | 10:13 AM
  #144
chas010's Avatar
No torque arm or shocks yet. On my wish list is a fast efi management system and a turbo 350 but they probably won't happen.
Old Jan 29, 2012 | 05:20 PM
  #145
3DFORMULA's Avatar
You may be able to make something like an adjustable pinion snubber much cheaper than a torque arm purchase. They had non-adjustable snubbers on the old Mopars from the factory. I think something like this may help, on a budget, control some differential wrap. Just a thought
Old Jan 30, 2012 | 03:19 AM
  #146
chas010's Avatar
I need to do something with the rear suspension, the last time I went to the track the car spun bad two out of three passes.
I'm going to make some phone calls to some lt1 specialty shops to see if I can get a cam spec'd for this set up.
Old Jan 30, 2012 | 08:55 AM
  #147
moehorsepower's Avatar
Do you know where your peak power / tq is at, maybe you have a little too much gear and the motor is on a downward slope past your pulling power, as with 6 speeds, people would short shift, stay in the power zone and run better numbers.What are your RPM's at then end of the quarter.
Old Jan 30, 2012 | 06:21 PM
  #148
BADHAWK51's Avatar
Joel, he would have to ad weight for extreme street but, I would love the competition his car gets down for what it is.
Old Jan 30, 2012 | 07:26 PM
  #149
blakez28's Avatar
Just read this whole thread. I'm hoping once I get my 503 that I'll be able to run these times. I'm going the less is more route, and stripping just about everything out as well. Nice build
Old Feb 13, 2012 | 09:37 PM
  #150
1961ba427's Avatar
Any news?
Old Feb 14, 2012 | 06:15 PM
  #151
chas010's Avatar
Im currently trying to find my "take it to the next level" cam
Old Feb 14, 2012 | 07:05 PM
  #152
1961ba427's Avatar
I'm sure plenty will be more specific, or fault me for being vague, but I would look for something with about 10* more duration on both sides and close to .600" lift - give or take .020" and a 108* to 110* LSA. In my opinion it won't matter a whole lot what specific grind/manufacturer you choose if it is in that range it will perform about the same.
That being said, I'd like to see you get some shocks, a good adjustable TQ arm, and TQ arm relocation crossmember on it and see if you can get the 60' down some more before you go into the motor.
Old Feb 14, 2012 | 07:51 PM
  #153
bowtienut's Avatar
Call AI and ask Phil to spec you a cam.
With their 228 cam that I'm running, I think you'd easily make that 10.70 goal at your weight. Many are going to say go bigger, but unless you want to step up the converter again, I think something around that duration is going to give you the best useable power through the 1/4 mile.
Old Feb 15, 2012 | 04:39 PM
  #154
chas010's Avatar
I have an email in to Ron at AI, thanks for all the help guys!
Old Feb 15, 2012 | 06:43 PM
  #155
355z28's Avatar
what brand lid is that? Im looking for one that slants on the sides like that.
Austin
Old Feb 15, 2012 | 10:46 PM
  #156
3DFORMULA's Avatar
I think you are gonna get the results you're looking for this year.
Old Feb 16, 2012 | 02:36 AM
  #157
Wicked94Z's Avatar
Where does the converter flash with the cc503? What valve springs? Pushrods?
Old Feb 16, 2012 | 08:26 AM
  #158
chas010's Avatar
Austin
The car has an SLP on it now. Not sure what make the origional one I bought was, it was used.
Old Feb 16, 2012 | 08:30 AM
  #159
chas010's Avatar
The Neal Chance flashes to around 4500 leaving off idle. The valve springs are Comp beehives and Comp push rods.
Old Feb 17, 2012 | 12:48 PM
  #160
Wicked94Z's Avatar
need more cam! plenty of converter... something about 10 degrees bigger on a 106 lsa would work nicely. A 232/238 on a 107.5 would do nicely, installed on a 104. Bullet has a nice .605" intake lobe and a .590" exhaust lobe that would work well here. Comp would be a 232/240 on a 108, installed on a 104. Lift is .603 intake and .609 exhaust. I'd probably step up the springs to pac 1219s (drop-in beehives for ~150 shipped) or shim what I'm assuming to be comp 26918 beehives down to .030-.035 from bind.
