I think im F'd. Milkshake.....Need Help.
This is going to be long, but i want to be detailed so hopefully someone can help me out here.
I just picked up a 95 z28 the other day that wasnt really running.It was dirt cheap so i didnt nit pick anything. The kid i bought it from said it had a bad water pump. I checked the radiator and it looked bone dry. He said it had been sitting for a couple months. I had to get it moved in the parking lot so a tow truck could get to it, so i threw a new battery in and it started right up. No knocks. No smoke. Sounded pretty good. Only let it run for like 3 minutes tops. Moved it about 150 feet and shut it down.
Had it towed home and swapped out the water pump, thermostat, and opti.I went to check the oil but the dip stick was broken.the cap was there but no stick. I wanted to flush the system so I just started pouring water into the radiator with the engine off. I could hear water just start pouring out, so I looked underneat and saw that the freeze plug on the drivers side of the block was gone and the water was just pouring out. So I went back to the store and got one and put it in. Filled the water up "which seemed like it took a TON of water" Turned the key and it fired right up. A little rough idle but sounded ok. The water level in the radiator dropped like a rock. I put more in as it was running and it started to "surge" up like it was bubbling. As it was doing this i also noticed some smoke/steam coming from the radiator fill neck, and steam/smoke was billowing out of the defrost vent inside the car. I had my brother in the car watching the temp. gauge and it only reached mid-way and just stayed there.
We shut the car off after running for about 10 minutes. watched the water level drop in the radiator and again tried to fill it up. Went to start it back up and it wouldnt turn over. I thought maybe it was out of gas because the gauge was all the way at the bottom. Put a gallon of gas in and it still didnt want to turn over. I got out and looked under the hood and noticed the vacuum line that attaches to the bottom side of the air intake wasnt on. I put it back on and tried again. The engine wouldnt turn over, but made a loud CLANG CLANG and I immediatly stopped. Something told me to look in the valve cover. On the passanger side valve cover is a tall vent like tube. I took the cap off and
it looked like thick yellow milkshake. I mean like FULL. I just walked away.
I did not notice any smoke out of the exhaust at all. Not sure what to do next. I have limited mechanical ability and lack proper tools to do much else. From my description does anyone have any idea of wtf is going on?
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
I paid $1,000 for a spotless red 95 z with mint black leather interior. The dash isnt even cracked, nor is the driver seat ripped.
The engine on the other hand. I dont know wtf to do with it. Any chance its something minor, or is it toast?
Worth every penny even with a popped motor,lt1's are getting cheap.
Is the engine crank case and lifter valley filled to the top with coolant or just the tube? Check the freakin oil man. Even if the dip stick part is broken off pull it off and check it. You need to make sure it's not milkshake in the crank case. 1000 isn't bad for a good condition roller but it woulkd be nice if the engine isn't absolutley Fubared.
The oil dipstick is broken. The yellow dipstick cap is there but no stick. I looked down into the tube and dont see anything. I took the breather tube cap off the passanger side valve cover and looked inside. It is full of thick yellow colored gunk.
get a motor off craigs list for around 500 bucks and either throw it in or go thru and freshen it up and then throw it in...then set that one on a stand and start a build
What i dont understand is why did the car start up and sound perfectly fine with no coolant in it even if only for a few minutes, and then after fixing the water pump and putting water in, this happens? I dont get it. Is there a list of possible problems here, or is it cut and dry headgasket or blown engine or????
