Sigh more 383 problems. Fall down go boom
Old 05-20-2011, 09:22 AM
Z28Roxy's Avatar
Default Sigh more 383 problems. Fall down go boom
The car sometimes (not always) made a knocking or tapping noise for about half a second to one full second then stopped on start up. Builder said this was normal until all the air got out of the oiling system.
I drove it yesterday and it seemed perfectly fine. Good oil pressure, good coolant temperature, etc. Then when I decided to let her rip it had no power at all at about 4000rpm. I left off the gas, heard a small boom and oil pressure went to zero (or damn near zero). I unplugged the injector fuses and cranked (it did turn over but still zero pressure).
Now I have it towed to the builder's shop, I'm thinking it could be a clogged (rtv) or broken oil pump or pickup, but would that cause a lack of power too?
Old 05-20-2011, 09:31 AM
white ghost's Avatar
Lack of power sounds like an ignition or fuel problem. What's your tune look like? Leaking any fluids? What's your oil look like? Any debris or milky look?
Old 05-20-2011, 09:34 AM
Oh and I don't think you should ever have "air in the oiling system" never heard of a stock vehicle doing that which means a properly built and running modded car shouldn't do it.
Old 05-20-2011, 09:59 AM
1961ba427's Avatar
I've never heard of that on a Chevy V8 either. I'm sorry to hear you're having more trouble.
Old 05-20-2011, 10:11 AM
draggin97s10's Avatar
yikes, id be on the builder!
Old 05-20-2011, 10:15 AM
No gay? Haha. Just kidding.
Old 05-20-2011, 10:17 AM
Z28Roxy's Avatar
Well I had it towed it back to the builder for now... but no it wasn't leaking any fluid. I didn't check the oil after the kaboom (no dipstick) and had it towed back to the builder. I had to walk 2 miles home barefoot (dumb, I know, I should have kept my cell with me).
And all the ignition/fuel components are good.
quik95lt1's Avatar
lack of power a bang and no oil pressure is usually a really really bad sign......i dont mean to scare you but i'd be pulling the oil pan off if i were u
Old 05-20-2011, 10:18 AM
Z28Roxy's Avatar
Well, check the name. It wouldn't be gay :p
Old 05-20-2011, 10:23 AM
Haha. Its a joke from another thread. How long has your build been complete? Did your builder give a warranty being he said it was "normal" when you called him about his problem?
Old 05-20-2011, 10:26 AM
Z28Roxy's Avatar
I got the engine back, put it back together, drove it home from the alignment shop (about 40 miles) and that's it. This was the second drive.
Old 05-20-2011, 10:30 AM
Did you finish assembling just the long block or did you do short block too?
Old 05-20-2011, 10:31 AM
Z28Roxy's Avatar
No he gave me the long block with the intake and opti installed.
Edit: by "it" I meant put the car back together. The engine was already assembled.
Old 05-20-2011, 10:37 AM
Well if he's any sort of a quality builder he'll warranty the work and part in the bottom end that went boom. If your lucky it may be a spun bearing. If you are unlucky you may need a new crank. Good luck.
Old 05-20-2011, 10:51 AM
ckyconan2003's Avatar
Who dropped the engine in?
You have full power to 4000rpm then nothing or do you feel it skip?
I'd check to make sure the shaft didnt break or become dislodged, run your plug wires and make sure you're not arcing on your headers, and finally make sure your rear main seal isnt leaking oil which could be on your clutch/flywheel assembly.
I'm with quick95lt1, that oil pan has to come off.
Old 05-20-2011, 10:57 AM
sweetbmxrider's Avatar
That sucks. Post pics of carnage.
Z28Roxy's Avatar
Yeah the pan is coming off. Im justt making the builder do it because im not going to do this in my driveway. Could a broken pump shaft cause power loss
Old 05-20-2011, 12:15 PM
quik95lt1's Avatar
no just the boom..........im putting my money on a rod..........sorry
Old 05-20-2011, 12:27 PM
gatorhead's Avatar
No one else caught the no oil dipstick part lol......so why no dipstick?
Old 05-20-2011, 12:40 PM
quik95lt1's Avatar
now i did........yea whats the deal with no dipstick??? this may sound dumb but there is oil in it right???
Quick Reply: Sigh more 383 problems. Fall down go boom
