1100hp LT1 short block build w/ PICS!
Old 07-06-2007, 08:31 PM
fergymoto's Avatar
Default 1100hp LT1 short block build w/ PICS!
I have spent the last few days preparing my block, checking clearances, fitting bearings etc. Looking to build the first 1100hp stock short block LT1 in history
Specs are:
-Factory 2 bolt main block
-Factory main caps and bolts
-Factory crankshaft
-Factory rods and bolts
-Factory Mahle pistons
-Factory timing set (new GM chain, GM Vortec cam sprocket)
-Factory oil pump
-Clevite "H" series bearings
-Hastings moly rings
-Custom grind cam by Bret Bauer
.030" deck height
Standard bore
Pics:
Just kiddin, no 1100hp goal
Old 07-06-2007, 08:47 PM
Matts94Z28's Avatar
I was starting to worry! What did you use to paint the block?
Old 07-06-2007, 08:58 PM
NotACop97Z's Avatar
thats an attention getter if Ive ever seen one!!!
Old 07-06-2007, 09:03 PM
jakesz28's Avatar
Sounds like you need alot of nitrous and it will be a one pass wonder.
Old 07-06-2007, 09:13 PM
mike2244's Avatar
more like a one shot wonder
Old 07-06-2007, 09:15 PM
wrd1972's Avatar
1100HP with 2 bolt mains...KABOOM
Old 07-06-2007, 09:16 PM
6techniques's Avatar
wow, you actually had me on that one, lol.
Old 07-06-2007, 09:58 PM
infinitebird's Avatar
haha, had me too
LT1MAN's Avatar
x2....
Old 07-07-2007, 12:36 AM
TwoFast4Lv's Avatar
I was just waiting for a picture of the stock pistons in the pan
Looks good!
Old 07-07-2007, 01:56 AM
Revelation Z28's Avatar
JB weld can do wonders
Old 07-07-2007, 02:05 AM
the_merv's Avatar
Bubble Gum them in there..
The Title had me too...then I saw the pics and was pretty muck like WTF..yea ok..
Old 07-07-2007, 03:02 AM
Imnotfast's Avatar
Seen the PM rods and only thought was you bring the car I will bring the mop.
Old 07-07-2007, 06:17 AM
fergymoto's Avatar
LOL I know all you guys were just sitting there reading the beginning of the post like "WTF kind of clown is this guy?"
I just used Duplicolor High Gloss Black 500* paint. Nothing special.
This is just a stock shortblock setup obviously. I'm going to be running my Lingenfelter heads and the custom gring cam with the Cadillac lifters, 1.6 rockers, 918 springs, and good pushrods. Hoping to go 11.60s with it in a 3600lb car. Short times with the old setups were low 1.60s. Can I do it?
Old 07-07-2007, 08:27 AM
ZEX-Z's Avatar
I was definetly looking forward to the results........ LOL! But on the real....... I will be the outbreak monkey and test my ARP studded 396 Two Bolt main LE3 heads and LE4 cam+ alot of juice LT1 professionally balanced. I have a great tuner and a hell of a fuel system so this could get interesting. Two bolt mains, bring it on.
Old 07-07-2007, 09:01 AM
camar0corey's Avatar
What crank on your setup zex-z?
That black paint on the motor looks good, maybe I should try to paint mine.
Old 07-07-2007, 09:48 AM
mthegodfather's Avatar
That was a good one.
Old 07-07-2007, 10:02 AM
scorpion_z28's Avatar
Very nice looking Motor u got there...good luck on the 400whp motor
Old 07-07-2007, 11:33 AM
97blkz's Avatar
I was going to call you out, lol!
Old 07-07-2007, 01:41 PM
Imnotfast's Avatar
Nothing wrong with 2 bolt blocks and studs. Have gone in the 10's and over 400 poines.
Quick Reply: 1100hp LT1 short block build w/ PICS!
