oil pan to work with hooker long tubes
Old 02-13-2008, 08:42 PM
nasty96's Avatar
Default aftermarket oil pan to work with hooker long tubes
looking for aftermarket oil pan to clear hooker long tubes anyone know of any
Old 02-13-2008, 09:42 PM
SLawson86's Avatar
stock? i dont really follow, i have hookers and clear fine
Old 02-14-2008, 11:08 AM
1badzee's Avatar
+ 1.. i have the hooker offroad longtube headers and it clears fine
Old 02-14-2008, 11:10 AM
infinitebird's Avatar
haha, any headers that didn't work with the stock oil pan wouldn't sell too well I don't think.
Old 02-14-2008, 11:32 AM
BOLO's Avatar
I have JetHot long tubes(same design as Hookers) and it clears the oil pan.
Old 02-14-2008, 04:57 PM
nasty96's Avatar
yea mine has been clearing with the stock pan also i meant any after market oil pans clear them.. i know the canton will not...
Old 02-14-2008, 05:02 PM
nasty96's Avatar
edited
Old 02-14-2008, 11:25 PM
chevy dude's Avatar
if you get aftermarket it cant be much wider than stock. i got pacesetter long tubes and got about 2 inches on either side
Old 02-15-2008, 06:25 AM
RBE17's Avatar
I've used two different Canton's in the past and have not had a problem w/ clearance using Hooker LTs.
Old 02-15-2008, 01:29 PM
mean_greenz28's Avatar
ive got a canton pan on my new engine and when we test fitted the hooker headers, we had gobs of room. I'm not sure what the part number was off the top of my head, but it was an "LT1" pan, but it will clear the stock k-member too.
Old 02-16-2008, 07:31 PM
O Holy P's Avatar
I have a Canton pan on my Z and it's fine w/ LT's. The only issue I had is it is a little tough to plug in the low oil sensor plug in when the headers are installed. If you install the headers and forgot to put the low oil sensor itself in...LOL, good luck. Make sure it's in before the headers go in. Otherwise, there are no clearance issues w/ Canton & Hooker.
P
Old 02-18-2008, 08:51 PM
nasty96's Avatar
thanks guys.. i had a friend who tried the canton pan and said it would not fit so he changed to pace setters... but i just got the moroso pan and it fit perfect... even cleared my main stud girdle..
Old 02-18-2008, 11:13 PM
matt94z's Avatar
I've got a Miloden stroker pan with Jet Hots and it fits fine..
Old 02-19-2008, 12:07 AM
Village Troll
SS RRR's Avatar
P
And your plug isn't burnt? I looked at that after the fact and decided the primary was much too close and figured the plug would get charred.
Quick Reply: oil pan to work with hooker long tubes
