forgive me if this is stupid but..
Old 03-12-2008, 12:05 AM
fbodyfreek's Avatar
Default forgive me if this is stupid but..
is there any true gain from using an electric water pump? i know that it frees up about 7hp on some cars, but then i got to thinking and remembered mine was cam driven and i assume that the gain had come from a deletion of a pulley on the other cars. so.. am i correct? thanks.
Old 03-12-2008, 12:13 AM
97badass's Avatar
takes a restriction off the valvetrain and frees up ~10 hp i believe
Old 03-12-2008, 10:03 AM
ROWDYZ28's Avatar
I gained about 10hp from doing the pump and a March pulley set. I rec doing it.
Old 03-12-2008, 10:53 AM
EliteCamaro94's Avatar
what pump is best for a basically stock LT1 car but soon to get bolt ons, or does it even matter?
Old 03-12-2008, 11:03 AM
B-Rad420's Avatar
Not really much of a difference unless someone has proved that one will run for more total hours before dying. I have had 2 of the Meizeres (SP?) on different cars and like them alot.
Old 03-12-2008, 11:20 AM
fbodyfreek's Avatar
so you think it's worth the 200 bucks if i already have a 160 stat to put in anyway? seems like the best time since the system will be drained anyway.
Old 03-12-2008, 11:24 AM
Formula350's Avatar
You'll have to mod your housing, just so you know. Unless that's just a Meizer thing.
It's not a big deal, especially if you have a dremel or air tool.
Don't know about 97s, but you have to block off the rear hole in the water pump where the drive shaft used to go in. My buddy used a small *** frost plug, we sat at the parts store milling through their selection to find one that'd fit.
Old 03-12-2008, 11:27 AM
LT1MAN's Avatar
i put a big oversized aluminum radiator in mine and then got an ewp and it wouldn't fit.
Old 03-12-2008, 11:32 AM
97LT1's Avatar
I think you have that backwards the CSR has to have the housing modded. Mezier is supposed to be drop in.
Old 03-12-2008, 11:35 AM
sdm1234's Avatar
i have a meziere and i had to cut the shroud. and mine came with a freeze plug.
Old 03-12-2008, 11:44 AM
Formula350's Avatar
Ah, that might have been when my friend got, CSR.
I'm talking about the water pump housing, or are we on the same page and that's what you mean by shroud? I assume fan/s when I hear that.
Old 03-12-2008, 11:53 AM
flippy1974's Avatar
i have a meziere and had to trim on the fan shourd and mine came with the plug.
Old 03-12-2008, 12:10 PM
sdm1234's Avatar
oh sorry i was talking about the fan shroud.
Old 03-12-2008, 01:03 PM
iceman15's Avatar
I got a CSR and i had to trip the fan housing a tad to allow clearance, I felt a difference with the EWP just make it habit to check your gauges frequently as a precaution
Old 03-12-2008, 01:16 PM
Bad93TA's Avatar
Is there different flow rates for them or are they all the same?
Old 03-12-2008, 03:20 PM
97LT1's Avatar
Well not sure about the CSR, but there are a regular mezier and a HD model. The HD model has a slightly higher flow.
Old 03-12-2008, 03:29 PM
1badzee's Avatar
I have the meziere.. it installed with ease. It comes with everything you need. All you'll need is like a small punch and a hammer to knock out the impellor... My temps stay constant at 178-180* city or highway
Old 03-12-2008, 03:55 PM
projekt70chevelle's Avatar
Approximately how long do these things last?? Also is there a way to maybe hook up a small l.e.d. light or something that would warn you if the pump failed?
I have been looking into them, and the only thing that scares me is the idea of it just dying suddenly, especially since i would be DDing the car.
Old 03-12-2008, 09:42 PM
1badzee's Avatar
buddy of mine has been running with his for 3 years now and counting..
Old 03-12-2008, 09:50 PM
GMRACER13's Avatar
Another benefit of an EWP is that you can run an adjustable double roller timing chain for a factory roller equipped SBC since you won't need that gear on the back of the cam sprocket to turn the factory water pump. A definite plus if you want to degree in an aftermarket cam or if you just want the added strength.
Quick Reply: forgive me if this is stupid but..
