LT 1 T56 work on a LS 1 ?
The LT1 Bell Housing is the same config as the standard SBC. It will bolt up, but be lacking the 12 o'clock bolt hole and the block is obviously missing the 2o'clock hole. Overall, a bolt will be missing.
You will have to measure if you need an extended pilot bushing or not.
American Power Train sells adapter flywheels to mix/match clutch assemblies.
Not really an issue....
Nope, It will bolt up.
Of course he would. Obviously he can't use the LS style TO bearing meant for the LS t56, he has to use the pull diaghram style with fork. But it will bolt right on, use the LT1 clutch hydraulics and he's GTG.
I know what your thinking is he can't simply put the LS bellhousing on it and thats true.
No sir. The input shaft, front bearing plate (midplate), and bellhousing are different. This has been asked on here a million times....
https://ls1tech.com/forums/manual-tr...-pictures.html
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
