M6 to A4 and A4 to M6 Conversion info requested
Old Jun 18, 2009 | 05:43 PM
  #541
BigT2002's Avatar
anyone know the best place to buy the T56 instead of waiting for one to show up?? Also, how much am I looking to blow on it?
Old Jun 19, 2009 | 09:43 PM
  #542
Stang-Slayer's Avatar
Just put up something in the classifieds on here and ls1.com....
I hate tramendous ammounts of luck....Didnt take long either for people to start sending offers....Just make sure u let them know u have money in hand....so ur not one of these guys just bull shitting around
Old Aug 5, 2009 | 01:12 PM
  #543
4Birdman's Avatar
https://ls1tech.com/forums/manual-tr...ap-wiring.html
Help me.
Old Aug 5, 2009 | 02:41 PM
  #544
Im almost done with my swap....run into a couple little probs but i got two quick questions for ya....
1.) Should my brake lights be on all the time until I get a tune?
2.) If the master cylinder is slightly off where the rod is a little bit of an angle is this going to hurt anything?
Thanks guys!
Old Aug 5, 2009 | 02:44 PM
  #545
the_merv's Avatar
The Master should be fine, it's made to move around a little bit.
If your Tail Lights are on all the time then you have the Brake Switch out of adjustment.
How did you do your wiring?
Old Aug 5, 2009 | 04:39 PM
  #546
I still havnt got it running yet....I broke a master cylinder....and a slave cylinder at different times....weird crap happening....
I didnt finish all the wiring yet....I just havnt done the reverse lock out and the cruise control thing (I think....not sure what hte second one was lol)
Old Sep 13, 2009 | 10:32 PM
  #547
Devils Mentor's Avatar
I have never seen it in the list of needed parts to do an A4 to M6 swap, but do I need to replace my starter with a manual type or will my starter from my auto work?
DM
Old Sep 13, 2009 | 11:47 PM
  #548
the_merv's Avatar
Same Starter..that's why it's never been listed.
Old Sep 14, 2009 | 12:51 AM
  #549
That is what I thought, but it would make since that it would need to be replaced. Good job GM
DM
Old Sep 16, 2009 | 02:19 AM
  #550
OK.... Not to beat a dead horse, but my Bird is a 98; are the starters the same from 98 to 02? I know there were some differences with the 98's, I just want to be safer than sorrier.
DM
Old Sep 16, 2009 | 07:55 AM
  #551
the_merv's Avatar
I know the early Gen III Trucks have different Starters..don't know about the Cars..
Old Sep 16, 2009 | 03:58 PM
  #552
Do'h! I seen that you are in Jacksonville and was like; Oh ****, local help!, then I read a little more, lol.
Well I just want to be clear on the starter thing since the local "know it all" shop here keeps talking different starter... different starter...
Thanks Bro!
DM
Old Sep 30, 2009 | 10:15 PM
  #553
White.Lightning's Avatar
Lots of good info in here. I'm doing a M6 to A4 swap in my 1998 T/A soon. I was going to swap in a 2002 pcm and 2000 harness but found out about the gauge cluster etc.
Now I'm researching and probably just going to get a 1998 A4 harness and make the PNP and shiftlock work again with my M6 interior harness.
Old Oct 23, 2009 | 11:16 PM
  #554
Detoxx03's Avatar
Now i'm thinking about doing a A4 to M6 swap
Old Oct 24, 2009 | 12:49 PM
  #555
spaulsen's Avatar
doing mine right now......i have one question tho...im changing ecm and harness with my swap. so the only thing i need to worry about ( with the wiring part ) is the black clutch swith ( neutral safety ) , hatch release, and reverse lights right? the factory dash harness for the cruise control pluged right into the peadle swithches.
on the reverse lights tho, since im using a m6 engine harness and ecm will i have to do the wiring for the reverse lights?
Old Nov 2, 2009 | 08:14 PM
  #556
mean94lt1's Avatar
will be doing this soon so subscribing
Old Nov 3, 2009 | 07:49 AM
  #557
the_merv's Avatar
You will have to tweak the Cruise Switches on the Pedals..basically add in a switch on the Clutch Pedal so the Cruise will dis-engage when you push in the Clutch.
Yea you will have to install a N/S Switch if you want it to be safe, that's not hard to do. I put a Relay on the wire that goes to the Starter, and the Switch controls it when the Key is in the start position.
The Reverse Lights are easy..find the 2 that are in the Harness, and take the 2 that are on the Auto Shifter and run them over to the Harness.
I don't know about the Hatch Release..I don't have that.
Old Nov 3, 2009 | 01:24 PM
  #558
Mr. Trick's Avatar
How do you hook up reverse lock out? I did the swap last year but I never hooked it up. My car is a 98 btw.
Old Nov 3, 2009 | 01:49 PM
  #559
the_merv's Avatar
Take the Reverse Lockout Connector and lay it next to the VSS Connector(the wiring is about the same length). Take one of the wires from the Connector and connect it to PCM RED #42(1998 LS1 F-body). Take the other wire and connect it to 12v power. This will make the Reverse Lockout function like it's factory when the Car is tuned for it.
Old Nov 5, 2009 | 05:33 PM
  #560
Mr. Trick's Avatar
OK thanks. When I did the swap I used a M6 pcm, so when I hook it up do I still have to tune for it to function correctly?
