Z06 clutch ?
Z06 clutch ?
I am about to go through with my A4 to M6 swap and i am in the market for a clutch, pressure plate, throw out bearing, and pilot bearing. I was thinking of going with the z06 setup but I can't find a place to get them. Anyone have the part numbers for these items. Also what is the part number for the newer slave and master cylinder (00-02). Thanks
I plan to just do some regular DD with some put it to the floor fun. I have heard alum flywheels work well for this kind of driving. I am interersted in the Z06 clutch, PP, and flywheel if you have them. If not what is the part number and I heard it comes as a kit gmpartsdirect with the flywheel, clutch, and pressure plate.
I think SDPC (sponsor) has the Z06 clutch/flywheel/to bearing for like 450. gmpartsdirect may have it for a little less. If you go to gmpartsdirect.com and look under like 2003 vette (z06) and find the kit under "flywheel" it should be 400 something. Do a search for Z06 clutch pn
