Keeping Our Cars SAFE From Clutch Explosions
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I've read more than one thread on this site about pressure plates/flywheels failing and causing catastrophic damage to these cars, and we've all heard stories about them causing damage to the drivers, as well! Lets use this thread as a guide on keeping our cars (and our legs!) out of harms way.
What options do we have when modding for safety?
Please post up pictures, links, prices and experiences with all kinds of products designed to improve safety. If we all educate ourselves further about safety devices available to us, we are more able to make smart choices which will in turn (hopefully) elimate any future threads like this one.
SFI approved bellhousing It won't shatter.
I'd say a SFI approved billet steel or aluminum flywheel too, as it won't shatter.
Only other thing I can thing of is to have your flywheel and presure plate balanced. Install correctly and touque to specs.
Here's some pics from when I put mine in.
http://fastls1.com/forums/showthread.php?t=10218
There's a write up on here about it too. The search function just isn't working for me right now so I can't find it.
Originally Posted by Ferocity02
1) Don't buy a SPEC 3...(get an LS7 clutch instead)
The thread was asked about safety and CONTAINING a clutch explosion. I don't think clutch brand should come into play as I have seen stock, Centerforce, and Ram clutches explode on cars ranging from a 1969 Chevelle to my friend's 1995 5.0.
Like everybody else said, an approved bellhousing and/or tranny blanket, and making sure you torque the bolts to correct specs are the best things to do.
Originally Posted by TroubledWine3
That's funny, I know a few 6-second-in-the-1/8th LS1s and plenty of 7-second ones running a SPEC 3 that haven't blown up. There's been, what, 3-4 stories in 3-4 years of them blowing up and all of a sudden they are the only clutch to ever explode? I think not.
As for the LS7 clutch, it costs about the same as the SPEC, holds the about the same amount of power, drives like stock, no chatter, probably not going to explode as it is used on production vehicles, and will probably last 125,000+ miles, depending on the driver.
There's been a hell of a lot more than just 3-4 stories. Do a search on this forum and you will find 5-6 from this year alone. Also find me a thread where a clutch other than SPEC or stock has blown up... Sure clutches in other cars have had a problem, but I'm strictly talking LS1's, as this is an LS1 forum. The fact remains that SPEC obviously has issues with making durable clutches. I'm sure a lot of their clutches turn out to work very well, but personally I would prefer to buy from a company who has far less complaints and stands behind their product.
I do want to know more about these SFI bellhousings though. I understand that they wont explode and let pieces fly out and hit the motor and such. But what kind of damage could that still cause to the crank/engine/tranny? If something blows with enough force to go through a bellhousing and car, then even with a SFI housing, that force still has to go somewhere right?
Crank should be ok cause of a nice strong billet flywheel, it has a big peice of metal that seperates it from the tranny also so probably the only real thing exposed is the input shaft.
As for the LS7 clutch...probably not going to explode as it is used on production vehicles
Second of all, the main reason you see so many SPECS explode in LS1s is exactly that...this is an LS1 website, so you're only going to hear about LS1 explosions. 2nd of all, SPEC is BY FAR and exponentially the most ran clutch on this board.
Third of all, a lot(not all, but a lot) of the stores have circumstances which outweigh the "only SPECs fault" tactic. The newest one was a guy who had flood damage up to his interior in the car and was already trying to get his insurance company to repair the car when he STILL went and ran the car and thus, catastrophic failure. If you knew your motor had water in it, and you ran it 'till it blew up, would you blame the company who made the internals or the fact that you ran your car knowing it had damage?
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
I'm not saying SPEC is the be-all-end-all clutch. But what I am saying is I know plenty of drag cars who are at the strip AT LEAST twice a week and running in the 11s consistently on a SPEC 3 clutch and I've seen a sponsor's torque arm break, I've seen a 12 bolt posi break, and I've seen the internals of a transmission break while the SPEC was still grabbing like new.
I wish I had the money to run a Tex or a McLeod dual and if you are putting down significant numbers(if I was putting down any more than 400 at the wheels, I'd run a Tex), then you should. But you cannot blame a manufactuer for something that is out of their control when there are FAR more clutches running great times, doing their job, and NOT failing than are. You have to look at the statistics and realize that 5 stories in 3-4 years isn't THAT bad on a specified board when there are probably 10s of thousands of SPEC clutches being ran in LS1s right now.
there may be more spec failures we heard of and i agree that it is due to more being sold, however i still think they are top of the list for failures. of all the people i personally know with a spec, only one works like it should. all we are trying to do it help people in their decisions here. if a spec has blown up and you are concerned with safety spec may not be your top choice. everyone will have their opinions, lets leave this thread for info instead of defending a certain clutch based on failure per amount sold. spec has just proven to us that there are repeated failures with their clutches, could be fixed now but maybe it isnt. i wouldnt chance it though.
You just contradicted yourself, first of all.
Everyone has their opinions on SPEC clutches. Mine is obvious. I made a thread for anyone who owns or had owned a SPEC clutch just to get their thoughts on it, I would like to hear what the customers have to say.
ThaThe thread was asked about safety and CONTAINING a clutch explosion. I don't think clutch brand should come into play as I have seen stock, Centerforce, and Ram clutches explode on cars ranging from a 1969 Chevelle to my friend's 1995 5.0.
I would not consider an LS7 clutch "stock", as it did not roll out of the factory with it installed. No contradiction has occured.
And last I checked, nobody in your thread had anything but high remarks for their SPEC.
Anyways, back to the safety topic...
I think everybody agrees that a shatterproof bellhousing and/or tranny blanket at the two best things to do when trying to contain a clutch explosion. Making sure your bolts are torqued to correct specs is a big one as well, and not slipping/heating your clutch and running it hard if it has just been slipped or is hot is another one.
The LS7 clutch is rated for much more power and thus much less likely to explode due to stress on a highpower LS1/LS6 than an LS1 clutch on the same car. I would not consider an LS7 clutch "stock", as it did not roll out of the factory with it installed. No contradiction has occured.
I'd bet my 385 rwhp slicks & skinnies LS1 F-body that weighs in at 3600lbs plus driver weight hits a drivetrain much harder on a high rpm launch than an LS7 powered Y-Body would.
All that weight transferring harshly through that single point in the drivetrain matters just as much if not more so than the actual power numbers. I've fragged clutches meant for a much higher HP, but couldn't handle tossing over 3800 lbs (including the driver) forward in a 1.70 60' at 6000 rpms.
Back to the safety question, if you're doing a lot of drag racing and are hitting your clutch that hard, I recommend not only a really stout clutch (like a McLeod Twin Disk) but also a McLeod SFI bellhousing.
