Another Hall's deal!!!
#3221
I still appreciate cars that weren't built by their owners and are quick. Most of the owners tend to have most knowledge of what is actually done to it.
The only people I dislike are the guys that will claim they built it, yet paid someone else to do it.
#3222
#3223
You confuse me. You go out, you race everything in sight. when you lose you go eh, i drive a saturn, of course I was gonna lose, then when you win you talk about how whatever "bad ***" car you beat just lost to a saturn.
#3224
Backyard Biscuits and Wheat Grass Juice. Found a leak....fitting coming off the fuel rail to the FPSS and the small allen plug on the side of it. I hope I got them tight enough or they are coming off and the allen head plug is getting more teflon paste!!
#3225
#3226
I always wondered why people didn't do their own psychological/educational/neruological/academic/emotional assessments...why pay someone for that??? Everyone should do their own mental health assessment and treatment, if not your a *****!!!
I love the mentality of build it yourself or else it isnt yours...always killed me! Build it yourself usually means put some parts on a car. Who "built" your block, did you forge it? Did you design the suspension parts your throwing on with tools that someone else designed and built? I put some parts on my Camaro, and paid friends who are mechanics to do the other 90%!
I will say this...in my 18 years of having fast cars and racing/modifying, etc...the fastest cars are almost always the ones that someone had outside work done on...not too many "home built" cars were at the top of the list that I ever saw. There is a reason for that...
I think its cool if you do as much as you can, but to insinuate that if you didn't build it yourself, it somehow doesn't count is as hillbilly as it gets!! I guess I will put a statement in my sig "If you didn't go to school for a long time and don't make six figures and pay someone to work on your car then it doesn't count"
Doing your own work is relaxing to a point, but if you get serious, you will need the experience and talent of someone who does it for a living. Anyone of us here with an air compressor and some grinding tools could port an intake, TB, or even heads...however I would rather pay Al to do it though!
#3227
#3228
I'm sure others have used it and can tell you better than me how it holds up on the long term.
#3229
#3230
Basically plumbers pipe dope..it's supposed to be fine as that's what they recommend for the pipe threads on my Nitrous/Fuel lines. I think either I didn't have the fittings tight enough or enough dope on the plug itself. All the other fuel line fittings seems to be doing okay with the paste at this point(knock on wood) I will have to wait and see before saying it will stand up to fuel.
#3231
i wasn't calling anyone out! wtf! all I did was ask, whats the deal with the srt-4? quit ****** yelling like you got something to prove! I don't recall saying I could beat it. Just knowing what I do about srt's I think it'd be a good race if everything is in working order and he really is at 400whp.
#3232
Somewhat similar....the product I used is made by Oatey and it's called Great White Pipe Joint Compound with PTFE ( Lowe's carries it)...flexible white, non-hardening, non-separating paste, withstands up to 3,000 PSI on gases from -50 to +400*F. 10,000 PSI on Liquids from -50 to +500*F.
So hopefully it will br fine for my application.
#3234
Sounds like it should be. Only thing I'd worry about is whether it'll cause corrosion in those fittings or not. I've heard nitrous hates Teflon in general and reacts to create a corrosion type of ordeal.
#3235
Nitrous doesnt like teflon tape that gets stuck in the plunger seat.
#3236
I've heard both horror stories. That's why I tried not to use it anywhere on my system. I didn't know if the Teflon and nitrous corrosion thing was true, I just avoided it all together.
I have seen on the used nitrous system I have laying somewhere the threads had Teflon tape on but it's turned into like a green powder; like the color of battery terminal corrosion.
#3237
I know they say no Teflon tape...likes to break of and get into the screens of the Solenoids but I honestly can't say I've heard that it causes a corrosive effect....I will check with my Nitrous Guy on that one, just to be safe.
#3238
If a piece of teflon tape gets caught in the plunger seat it can cause the solenoid to leak. If you get enough teflon tape to plug a fitting screen you are obviously doing something wrong. You should run a good inline filter and not worry about running screens.
Teflon paste casues NO corrosion or corrosive effect.
#3239
#3240
