Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Another Hall's deal!!!
Old 09-15-2008, 07:52 PM
  #4081
krobinson123's Avatar
http://www.slponline.com/view_product.asp?P=31067 Anyone know if one of these will fit directly in place of my Hooker muffler? I need a new muffler because the one I have blew a baffle out and rattles like a son of a bitch. Plus I know of 2 people in town that took those off their cars because they were too loud so I'm sure I can get a used one for cheap
Old 09-15-2008, 08:01 PM
  #4082
CALL911's Avatar
Kyle, I doubt its what you're looking for, but I have a Flowmaster muffler that was on my Formula prior to my Magnaflow that I'll sell to ya cheep.
Old 09-15-2008, 08:02 PM
  #4083
Th3Cobb's Avatar
Originally Posted by digitalsolo
Hey I have a boxer 4 Subaru.
Wanna race next time we have 4" of snow?
you gonna get some tires that wont roll off your rims first?
Old 09-15-2008, 08:19 PM
  #4084
digitalsolo's Avatar
Meh, they're free lifetime replacement.
Old 09-15-2008, 08:49 PM
  #4085
SDB
SDB's Avatar
Beast...get the heads/intake/TB to Al and have him do the port/polish and then send the heads to Jow so he can figure out CR and stuff! SHould be a great setup. Get a single 88mm turbo, your motor will be well suited to that, 76mm will be too small!!! Find someone to pick out a good cam for it....
Old 09-15-2008, 09:03 PM
  #4086
Killer Klover's Avatar
GT4088R
Old 09-15-2008, 09:49 PM
  #4087
The Beast's Avatar
Originally Posted by thedarkness
well six bitches in a bitch boat that thing right there makes me harder than a diamond in an ice storm
x2
Nick, you need a 99+ harness AND PCM. If you guy a 98 harness, I'll have to repin the entire thing, and thusly have to stab you. Twice.
My bad
Originally Posted by JPH
All looks good Beast, 370cid. I like the pistion selection, espically with the coating on the tops, skirts would have been awesome to, and the upgraded HD wrist pins are a PLUS! Your 99+ecu looks good(2002 would be the prime choice), but the '98 harness I would stay away from. I don't even think a 99+ecu and a '98 harness will work together correctly?(keep apples with apples if you know what I mean) Try to get me some head gasket volumes, and engine deck clearances, and lets see what you SCR will be?
And the best part is, I got all it for a KILLER price What headgasket and size do you reccomend I run? and I'll get that one then
Yup heads and IM will be going to him, I'm going with a Holley 90mm TB, so no porting is necessary on that. So you don't think an 88 will be to big and be laggy? Because I've learned from experience that turbo lag is a SOB. And The cam god himself said something along the lines of a 22X/22X .590/.583 115
Originally Posted by Killer Klover
GT4088R
No BB for me
Old 09-15-2008, 09:55 PM
  #4088
The gt4088r is BB
Old 09-15-2008, 10:03 PM
  #4089
JPH
JPH's Avatar
Originally Posted by The Beast
x2
My bad
No BB for me
Cometic 4.060/.0XX?
Old 09-15-2008, 10:06 PM
  #4090
JPH
JPH's Avatar
OK i need to find 2 poll terminals to go threw this and not leak as this is a fuel pick up for a bike any ideas ?
Get ahold of a fuel cell company that make fuel cells and THERE OWN sending units, ask for an engineer and they should be able to help you. If not, I guess I could try for you, since you got me hooked up with imoan!
Old 09-15-2008, 10:07 PM
  #4091
The Beast's Avatar
Cometic 4.060X.0XX?
4.60 x .051 alright?
http://www.cometic.com/da_viewimage.aspx?da=695
Old 09-15-2008, 10:09 PM
  #4092
The Beast's Avatar
The gt4088r is BB
I know, I want a non BB turbo
Old 09-15-2008, 10:16 PM
  #4093
Guys that are recommending a 88 trim turbo; this is a street car with a stick. An 88 might be quicker, but it's going to be a lot less fun on the street without a big stall automatic.
And automatics suck. Yes, that's right, I said it, automatics suck, they're boring. Faster, sure, but boring. If I was going to build a bracket car, I'd build an automatic, if I'm going to build something for fun, sticks are the way to go. I believe Nick is of the same school of thought.
Old 09-15-2008, 10:19 PM
  #4094
Why not put in another bulkhead, feed the wires through it and epoxy it closed. That will keep the wires from getting damaged, and be cheaper/easier than a 2 poll terminal. You could use a metripack on the inside as well. A -6 fitting will clear two 12 gauge wires.
Just a thought, that's the setup on my dual pump setup I'm putting together for the FC. Of course, a proper terminal is fancier, fo' sho'.
edit: and damn, that's a big fuel setup on a bike.
Old 09-15-2008, 10:23 PM
  #4095
Simple GT4088 just drop the R
Joe i think this will work Thoughts ?
Old 09-15-2008, 10:25 PM
  #4096
The Beast's Avatar
x2... Automatic for a street car = IMO... Race car, then it's a different story... Dr Turbo recommended a 76-82mm with a minimum .96ar
  #4097
Those are better than my idea. What's the size on those?
Old 09-15-2008, 10:26 PM
  #4098
The Beast's Avatar
Hook me up with some prices. All t4 flanges, 76-82mm. I can get 76-78mm turbonetics for $1000. Is your phone back up and running?
Old 09-15-2008, 10:34 PM
  #4099
http://cgi.ebay.com/ebaymotors/MONIT...spagenameZWDVW
Look around For garrett part numbers to the turbo you want I'll help you out. Ya phone is up and running but i dont have anyones phone number. Do you want stainless or steel ?
Old 09-15-2008, 10:41 PM
  #4100
JPH
JPH's Avatar
4.060/.051 okay, need to measure the head across chamber first to verify bore, then thickness will be degtemined by our desired SCR.
Quick Reply: Another Hall's deal!!!
