Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Another Hall's deal!!!
Old 04-12-2011, 09:37 AM
  #14301
SS1875's Avatar
Originally Posted by red01camaroz28
So what wasn't working right then on Saturday?
What are you talking about??
Old 04-12-2011, 09:00 PM
  #14302
red01camaroz28's Avatar
I thought you were talking about Massey's car since they were just talking about it in the few previous posts.
Old 04-13-2011, 09:22 PM
  #14303
SS1875's Avatar
Nope something else.
Old 04-14-2011, 08:22 PM
  #14304
tscheu5452's Avatar
Who do you guys recommend to repair this? Plus a couple of other touch up areas. Hell if I can find quality work at a decent price, I would like to repaint the whole car.
Old 04-14-2011, 10:12 PM
  #14305
The Beast's Avatar
I'm a painter at the Dimension body shop. Depending on damage and the paint code, I could probably do it for $250-300. If you're serious, I can repaint the whole think for a couple thousand depending on condition and prep work needed. The less I have to prep, the less it'll cost you
Old 04-15-2011, 12:05 PM
  #14306
Bigrob339's Avatar
I used my buddy tim kiefer who works at IAA auto body in New Haven, he did my engine bay which looks sick! Hit Nate or I up for his number, the guy does amazing work and is very detailed about everything he does.
Old 04-15-2011, 01:13 PM
  #14307
GMMillwright's Avatar
Just got back from RPM. Took the trans and converter, not the whole car (they're swamped). Rodney and the crew were awesome. Go in, introduce myself, tell Rodney what's up (TJ wasn't there today), and they just dropped everything and went to work. Literally, 4 guys started tearing it apart while I waited. Looked very NASCAR-esque. Pretty amazing. Bottom line: nothing broken, only a torn seal. They all remarked how "new" it all looked. Decided that since it's already apart, upgrading it to Stage 7. Rodney actually recommended a Stage 6 with a billet output shaft, but it wasn't that much to go to the 7 with billet input and output shafts and some other upgrades.
The bad news: still don't know what caused the "noises". They'll test the converter on the dyno when it's all back together. Rodney suggested the locker/rearend.
Added bonus: since it's already apart, they'll start on it right away. Probably have it ready to go back in the car in a week.
Old 04-15-2011, 01:27 PM
  #14308
JCattSS's Avatar
Great news Scott! The guys at RPM are always top notch. With the level 7 its just one less thing to worry about.
Old 04-15-2011, 04:05 PM
  #14309
SS1875's Avatar
Good to hear it wasn't all torn up. Wow, Rodney actually talked to you ....
You are blessed. TJ is a good guy to deal with as well.
Old 04-17-2011, 03:55 PM
  #14310
The Beast's Avatar
Old 04-17-2011, 07:20 PM
  #14311
crosstraining's Avatar
Does anyone have an ECM that I can borrow? I have 2006 LQ9 going in a 72 nova. I am having trouble getting the injectors to pulse. I want to make sure it is a computer problem before I buy another one. It would need VATS turned off, but I do have HP tuners.
PM me
Thanks,
Brandon
Old 04-17-2011, 10:02 PM
  #14312
Ponyhntr's Avatar
Default 2002 WS6, 402 ci, STS
The time has come to sell the wife's toy that hardly gets driven anymore now that we have 2 kids and a G8 GT. I thought I would give you Ft. Wayne Peeps a first look at it and if anyone is interested it would give me a good excuse to come home for a bit.
2002 Trans Am WS6
Pewter with ebony Leather
Power Everything, T-tops
Tinted Windows
87,xxx miles
402 iron block (~8,000 miles)
Forged pistons, rods and crank
Ported 6.0 heads
STS turbo system
T67 turbo
3 core intercooler
~8psi of boost
540 hp, 590 ft-lbs to the wheels
Single in-tank Walbro
Racetronix plug and play harness
60 lb. Mototron injectors.
6-speed Manual transmission
Pro 5.0 Shifter
RAM dual disk clutch
Steel 3-4 shift fork, billet keys in 3-4 synchro
Aluminum Driveshaft
Moser 12 bolt, 4.11 gears, Auburn Posi
Edelbrock torque arm
solid rod-end LCA's and Panhard bar
cross drilled and slotted rotors
SLP H.O. hood, black stripes on hood
misc interior pieces painted body color
Boost and air fuel gauges on A pillar
aftermarket CD player
Link to Pics:
http://s33.photobucket.com/albums/d92/ponyhntr/WS6/
The car runs and drives great, with more fuel system and a bigger/better turbo it would make some really good numbers!
Any questions just ask!
$13,000
Old 04-18-2011, 08:58 AM
  #14313
CALL911's Avatar
Thats a hell of a deal Josh! There are some builds that cost more than that car that won't have everything that does. Good luck on the sale buddy!
BTW, Nick, the car is looking great!
Old 04-18-2011, 12:24 PM
  #14314
The Beast's Avatar
Thanks Ben,
I replied to your PM, BTW.
Old 04-18-2011, 08:50 PM
  #14315
SS1875's Avatar
Geez Josh, now nobody will be interested in my car....
Nice looking car. Best of luck with the sale.
Old 04-19-2011, 01:26 AM
  #14316
Juiced2000SS's Avatar
Wow Josh, that's a great deal for someone! Now you can get that sc for your GT also
Old 04-19-2011, 06:37 AM
  #14317
The Beast's Avatar
A fuel system in Fort Wayne that's not half assed!? WHAAAAAAAAT!?!?
Magnafuel 4303 pump w/ pre and post filter
Sumped tank
-12 from sump to pump
-10 from pump to rails
-8 return
Old 04-19-2011, 08:37 AM
  #14318
digitalsolo's Avatar
PM me
Thanks,
Brandon
Brandon,
I'd give you a 99% chance it's NOT the PCM.
Does your HP Tuners talk to the PCM? If it responds, it's extremely unlikely to be bad. Much more likely that there is an issue with power or signal wiring to the injectors.
Do you have a copy of the pinouts for the harness and PCM? I would take a multi meter and set it to "buzz" mode so that it beeps/buzzes when you touch the leads together, then make sure you have continuity on all the leads, as well as consistent voltage at the injectors.
Also, make sure any +12 IGN leads you've grabbed have power during crank as well as run.
-Blake
Old 04-19-2011, 11:41 AM
  #14319
switches's Avatar
Oh look a car with a good fuel system that will never see the streets of fort wayne. Get that ****** on the road already.
Old 04-19-2011, 11:57 AM
  #14320
Originally Posted by digitalsolo
Brandon,
-Blake
Blake,
HP does talk to the PCM. I get cranking RPM's & I can see where it pulses 1 time. I do not have a copy of the pinouts(yet). That was last thing the guy helping said to do this past weekend. I have the stock pinout & with that we took a look at my PSI harness and were able to figure most of the wires out. We did not yet check them with the multimeter. Jon @ PSI is sending me another PCM, so I can rule that out. I got the PCM off ebay a year ago, so it did not come from PSI.
Thanks for the help. I will let you guys know how it goes. Hopefully I'll get the PCM by this weekend.
Quick Reply: Another Hall's deal!!!
