disabling headlights
Underneath the center defroster vent on your dash is the light sensor for the headlights. If you cut it off and crimp the two ends together you will be able to run your headlights when ever you want to. And run your fog lamps with out your headlights at any time. Kinda hard to get that part of the dash off but it can be done.
wrencher
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Go to
www.ls1camaro.net/sections.php?op=viewarticle&artid=21
It is a slightly different method, but it works.
i just did the mod earlier after seeing this post, i could not get the connector to come off the sensor, so i cut the wires far down, wound them together, and put tape around the ends...worked great
i did mine for the simple fact that when goin down a driveway, and someone in front of u is backin out, with the headlights on, it blinds them and they can't see....also when runnin from the cops...but who does that
