tunnel mount tq arm with td's
Old 01-23-2011, 05:23 PM
hodge9386's Avatar
Default tunnel mount tq arm with td's
i have a spohn tunnel mount tq arm for lt's and am about to trade my magnaflow cb for a tsp td set up and am wondering if anybody knows if the td's will fit with the tq arm the way it is.
Old 01-24-2011, 11:11 AM
Jon@Texas-Speed's Avatar
They won't clear. I tried the same combo on my car a couple years back and it is not possible. No matter how much cutting on the exhaust and spacing on the TA it won't clear. Go with a tranny mounted TA and then get the TA relocation kit that gets it off the tail shaft and you should be good!
Jon
Old 01-24-2011, 05:25 PM
hodge9386's Avatar
if i just switched it out to a tunnel brace thats not for lt's will it work.
Old 01-25-2011, 09:20 AM
I don't think so. If you go with the flat cross member it puts the x-pipe too low and it won't go through the cross member that is bent to allow for the exhaust to go above it. I looked at everything and couldn't make it work. At least not that I thought would work very well.
Jon
Old 01-25-2011, 05:08 PM
hodge9386's Avatar
do you have a pic of ur set up so i can see how u did it?
Old 01-25-2011, 06:05 PM
YURVIEW's Avatar
I'm curious as well
Old 01-26-2011, 09:08 AM
I wasn't able to do it. I built a custom exhaust with some 3" exhaust pipe, bullets, and turn downs. Wasn't able to put an "X" or "H" in it.
Jon
Old 01-26-2011, 12:00 PM
hodge9386's Avatar
So u kept ur tunnel mount tq arm an made a custom exhaust?
Old 01-26-2011, 03:11 PM
Yeah. I couldn't find a way to make our true duals work with it.
Jon
Old 01-26-2011, 03:58 PM
hodge9386's Avatar
ok thanks for the help man
