shreveport/bossier hang out!
MS3 cam kit ordered. PRC .650" springs, 7.4 pushrods, LS2 timing chain set, front crank seal, gaskets. now to wait until the 15th for the install/retune money. which reminds me I need to talk to Todd to set the date lol
Tough Mudder
Tough Mudder
I'm REASONABLY sure that the rear main seal is the culprit.
Take a look:
Look how much oil is over on the passenger side over by the starter.
I'm assuming it was slung up from the rear main seal to the bell housing, then ran down to that area.
Here is the flywheel. Anyone recognize it? It's not aluminum, but it is lightweight. I need to know if it will work with a Mcleod RST
Take a look:
For those of you who have ever been paid to do mechanic work OR work in the service industry where you deal with customers:
http://www.xtranormal.com/watch/7452...c-the-customer
Rockstar
Took a test drive tonight. Everything seems to be working and no fluids are gushing out, yet. Didn't go past half throttle but that thing has some power, and the fuel trims looked great even with minor preliminary, mostly stock tuning. The speedo and tach gauges are off though.
Looks like I found some MT ETs someone's gonna let me finish off at the track. Hopefully they'll grip from a boost launch. The rims and tires are 18s with a little life left in em.
Hey no problem, I'm likely never gonna use them anyway.
To all the daddy's and Josh R. soon to be one. This couldn't be any more true.......And yes this is Hootie, apparently he is doing well without the Blowfish.
http://www.youtube.com/watch?v=y5zCaRaJ-kE&ob=av2n
hey yall, just found this shreveport/bossier thread. im on 318racing.org as well, i know some of yall (cold,kappa). drive an ls4 gxp bolt ons. are any of yall going to the track this weekend? (thunder road)
Andy, I think you are going to like the ms3.
Todd, do you think it is odd that we saw solid 14.5s while cruising and 12.5s while in PE? Seems almost too good to be true with a stock VE table. We were running closed bloop with the MAF disconnected.
I blew off a section of charge pipe tonight making adjustments with Todd. We walked I20 for an hour, but couldn't find it. I'm gonna go to Lites tomorrow and see if they can fab up a piece. That will depend on whether or not I make it to the track. I'm gonna get fresh couplers and v band clamps.
I'm also on 318 and I'll be at the track this weekend as well. I'm sure I'll see you there.
