Controller to pull timing???
Old May 24, 2011 | 08:53 PM
kylefox93's Avatar
Default Controller to pull timing???
Im looking to see if there is a controller out there to pull timing out then advance the timing again after im done spraying. I dont know much about this so any helf would be great. I woluld also like to add this is a N/A 6.0. Thanks for any help.
Old May 25, 2011 | 08:20 AM
pimpjames's Avatar
Theres a few out there just do a search. I ended up going with the "Timing Tuner" from one of our vendors here.
Old May 25, 2011 | 09:16 AM
Graham@NitrousOutlet
Guest
Posts: n/a
There is no "on the fly" timing pull option available right now.
Ligenfelter should be giving us an update soon.
Old May 26, 2011 | 10:32 AM
pokaspeed's Avatar
Timing tuner pulls the timing only when you are spraying. You could consider that "on the fly." Hey nitrous outlet guys, whats your beef with the timing tuner?
Old May 26, 2011 | 11:12 AM
Guest
Posts: n/a
I am aware. We sell/sold every timing tuner option for LSX cars at one point or another.
What I was stating is that none are available for purchase right now. Why would we have "Beef" with them? Not sure what your asking?
Old May 26, 2011 | 03:09 PM
pokaspeed's Avatar
The first half of that post wasnt directed toward you. And what im getting at is whenever someone posts up asking something about a nitrous controller that pulls timing you say there are none. Also, in another thread you said the TT didnt have a delay option, and it does. It just seems like you are avoiding it as an option as a nitrous accesory.
Old May 26, 2011 | 03:24 PM
Guest
Posts: n/a
Usually a "nitrous controller" is a progressive controller. There is not box that has a progressive that will pull timing. I was simply mistaken on the delay option.
I do try and avoid it as an option. First off is you can not verify the timing is being pulled with tuning software. This too me is very important. Especially when I have to offer it to customers.
Second, we have a horrible time getting them in our hands to ship out. Again this is a big concern when I need to be able to give an accurate time table for when a customer will have a part.
Old May 26, 2011 | 05:22 PM
raymond mckinney's Avatar
Is the msd 6010 box a good timing puller? Can it be seen making the changes?
Old May 27, 2011 | 09:32 AM
Guest
Posts: n/a
I have honestly never used that box in an EFI application. I think it would work well. Call the guys at MSD.
Old May 27, 2011 | 03:37 PM
I have a friend that uses it as a 2-step and a nitrous retard and told me it works well. Just thought you might know.
Old May 27, 2011 | 04:51 PM
KFZ)^'s Avatar
Harris Speed Works' "The Interface" is one option. I haven't used it but I saw a classifieds ad for a used one that looked tempting.
Old May 27, 2011 | 09:30 PM
hotrodsgmoney's Avatar
How long have you been using the timing tuner & would you buy another one??
Old May 29, 2011 | 12:08 PM
RedVertTA's Avatar
Harris Speedworks Interface is a great piece, pulls timing, controls air/fuel, and allows you to spray dry plate and dry direct port, and costs less than the msd timing twister. I do not understand why anyone would go with the timing twister over the interface.
Old May 29, 2011 | 09:21 PM
pimpjames's Avatar
To be honest the car is at "All American Street Performance performance" getting that and a fee other things installed before Jeremy furmato tunes it.
Old May 29, 2011 | 09:22 PM
pimpjames's Avatar
Typos from my stupid iPhone and I can't edit it sorry
Old May 31, 2011 | 11:17 PM
5.7mmImportkilla's Avatar
I'm running the interface and it works just fine..
Old Jun 18, 2011 | 07:37 AM
Bowtiedford's Avatar
am I reading it right, the interface for an LS1 can only pull 3 degrees?
Old Jun 18, 2011 | 08:29 AM
SargeZ06's Avatar
Resistor mod FTW. Pulling 9 degrees at WOT with the flip of a switch...
Old Jun 18, 2011 | 08:32 AM
is this something you did or a kit you buy? thanks for any info
Old Jun 18, 2011 | 08:44 AM
SargeZ06's Avatar
Search the nitrous section for "resistor mod".
It's basically a resistor(different ohms for different results) connected to the IAT sensor. When you trigger the relay it is run from it will trick the PCM into thinking the IAT is a different temp(204 in my case). The PCM will reference the value set in the Base IAT adder table for spark. I put a negative number in so it pulls instead of adds. -9 in my case. I do this in the cells above .60g/cyl so it only pulls when I'm at WOT.
I've got less than $10 in this.
