My Stock shortblock/cubic inch cam-only entry:) 56k beware
Old 08-05-2012, 10:23 PM
  #401
n2ols1cam's Avatar
Originally Posted by Fbodyjunkie06
Yep leaded race fuel, cold plug just don't mix for a long time street driving. You may want to think about a B8EFS if you know you're going to be street driving it a lot while spraying.
Leaded race fuel will load up and foul a TR55 if you drive on them long enough.
Its weird because ive been driving like this for a few months and this is the first time this happened. Do you think id be able to get away with running c16 if i switched to a 8 plug? Also do you think i could have old wires? They are about 2 years old.
Old 08-07-2012, 08:01 PM
  #402
Fbodyjunkie06's Avatar
How often have you changed plugs?
It could be that you loaded them up inadvertently sitting somewhere at idle for a long time or a number of other conditions.
It all depends on how clean your motor tune is, but they will eventually become fouled.
I think if you don't run more than a 250 you could get away with an 8, if you're going to run it at the track though put a 9 in it.
Old 08-07-2012, 09:46 PM
  #403
n2ols1cam's Avatar
Ok. Thanks for the help man. I change my plugs every month. But the last set of plugs lasted me just over 2 months and then one day when i sprayed the car it broke up. So i changed the plugs and it was ok for a couple passes but now its breaking up again, even on motor. The car drives fine and doesnt misfire but when you got WOT it will break up a slight bit. What gap should i gap my plugs at? I have them gapped to .030 right now.
Could i have another problem other than the plugs getting fouled?
Old 08-10-2012, 04:05 PM
  #404
Sales@Tick's Avatar
Try .026.
Old 08-10-2012, 04:09 PM
  #405
n2ols1cam's Avatar
Originally Posted by Martin@Tick
Try .026.
Ok will do.
Congrats on the new job bud!
Old 08-10-2012, 06:25 PM
  #406
Sales@Tick's Avatar
Ok will do.
Thanks man, I love it, couldn't ask for a better shop and group of people to work with.
Old 08-11-2012, 12:22 AM
  #407
n2ols1cam's Avatar
Thats good to hear man.
Old 08-11-2012, 02:22 PM
  #408
Sales@Tick's Avatar
Just wait to you guys see the motor we are putting together....hehehe
I also have some new products I will be showing off soon for the stock bottom end run at the record and I think they will do exactly what I want out of them.
Nitrous class killer coming soon!
Old 08-11-2012, 04:04 PM
  #409
AJGls1's Avatar
^oh the suspense haha. How long till some new track numbers?
Old 08-11-2012, 08:36 PM
  #410
Sales@Tick's Avatar
Just waiting on the last item I have coming as it was the only piece that had to be built after I ordered it. It should be here next week and I'm hoping I'll be out at the track the following weekend.
I am really excited to see how it runs.
Old 08-11-2012, 11:49 PM
  #411
camscam02's Avatar
You gotta catch us first....
Old 08-12-2012, 10:27 AM
  #412
Sales@Tick's Avatar
Oh believe me, I don't give up that easily cam!!!
You already know what I've got brewing and it's going to be interesting to see how far it puts me into the mix.
Old 08-12-2012, 10:48 AM
  #413
My6speedZ's Avatar
I for one am excited to see the difference these changes bring
Old 08-13-2012, 07:35 AM
  #414
Sales@Tick's Avatar
You and me both buddy.
You've been there and seen it first hand the struggles I've gone through with the set-up.
I will probably be ridiculed by some, but I hope that the majority can see I am not out to prove anyone wrong or down anyone, I just want my car to move forward in progress.
Old 08-13-2012, 07:47 AM
  #415
WhiteLTone's Avatar
Oh the suspense is killin me. Good luck with changes!
Old 08-13-2012, 09:01 AM
  #416
Sales@Tick's Avatar
You guys will see them very soon!
Can't let the cat out the bag half skinned now can I?!?!
Old 08-15-2012, 11:00 AM
  #417
Sales@Tick's Avatar
Some super secret spy shots to keep you guys tided over....
I'll post more when I get back from lunch. Food>pictures
Old 08-15-2012, 11:41 AM
  #418
My6speedZ's Avatar
Going to have to change the thread title now!
You need to call me bro and fill me in had to replace the iphone and didn't have any contacts backed up.
Old 08-15-2012, 12:15 PM
  #419
Sales@Tick's Avatar
I now will be using a dual stage 92mm plate set-up by NX. I will be using their entire system from plate, to lightning solenoids(bad *** solenoids btw), their custom solenoid brackets that mount to the throttle body bolts, -6 feed line, and their high flow .500 orifice DF5 valve.
Going to work my way up to a 300 shot with 200 off the trans brake release and 100 brought in on a digiset timer as quickly as I can possibly get it in. I really think this will allow me to get the amount of nitrous flowing that I was looking for before.
I don't want to start a "this product is better than that product war" I just will let the results speak for themselves. Of course you can ask questions I don't mind answering them. I've spent a good deal of time with NX so far now, and I will say that their customer service is just as good as N20 outlet(which is superb BTW) and they are another top notch of the rung company to deal with. They have been MORE than generous by sponsoring me in my new fledgling racing program I'm building now and I couldn't ask for better support.
I am building a 408 stroker for the car with around 13.5:1-14:1 compression, and either All Pro 15* Hurricane cathedral port heads or AFR 245 cathedral port heads with a big solid roller cam and either an PI/Mast intake or a heavily ported Super Victor, 4150 TB, and a 2"-3" spacer for added plenum volume. I'm looking to run up front in RS275 at the end of this season and the coming season and also be able to run in Ultimate Street and SR275 with weight taken out to compete. I will be running a Powerglide with a 1.80 gear set, FTI 9" converter (Lenny at UCC will be tweaking it to work with the bigger more powerful motor so I don't have to send it to Fl. as Lenny is in NC) and a 3.73 rear gear to keep it loaded and where the nitrous wants it, and to make it manageable off the line as RS275 doesn't allow a progressive.
I'll mainly be running a 82 jet in RS275 as I am restricted to that jet, but in Ult. and SR275 I will be pulling the .104 or .110 jets out to give it to the Ford boys I can't wait to at least get the car back out on the track with the newly re-valved Mark Menscer Afco shocks and get this car not pointed towards the sky all the time and really let her fly.
Old 08-15-2012, 08:25 PM
  #420
Sofls1's Avatar
Aww snap! someone's going off!
Quick Reply: My Stock shortblock/cubic inch cam-only entry:) 56k beware
