98 trans am with nitrous ( recomendations please)
Its only got hooker long tubes, SLP lid, texas speed y pipe, and magnaflow cat back.
And 410 gears
What's the safest nitrous to use wet or dry and why??
Not spraying over 100-125 HP
I know a dry kit u spray before mass air flow it changes timing is that true?
How would u take timing out for wet
I like a plate better then a nozzle but the nozzle works up to approx a 150 shot. Research and install it correctly with no shortcuts, make sure the tune is safe with a wideband, back off some timing depending on size jets, change plugs to a colder non-projected tip plug. Every set up is a smidge different so do plenty of research.
Hey, i just realized my son bought a nitrous kit off you last fall...why didn't you just run that one? The purge solenoid had junk in it but once we cleaned everything out and wired it up it worked fine. He went from N/A 12.30 @ 112 to 100 shot 11.20 @121 with that little nozzle kit.
How do u do it high impact?
What's the easiest way to take timing out
I have a feeling my son is going to be looking for larger solenoids and a plate this summer. lol
Im running the LNC 2000 Timing Computer.... It works Great !
Im spraying a 100 shot... pulling 5 degrees of timing.
The advantage with the timing computer is that you can run full timing while running motor only. Timing is only pulled once you arm or power up your nitrous system.
This method is much safer for your motor.
Spraying before the Mass Air Flow meter while Running a Dry Kit... Does not Pull timing. It alters fuel flow at the injectors.
The MAF sensor tells the computer to deliver more fuel at the injector nozzles because of the increase in Oxygen & Air Flow caused by Nitrous injection.
If it was me, I would put a Proton Plus Single Nozzle System , I ran one on my car for awhile, with no issues, let me know what you decide and we can make a deal!
-Garrett
I never said to blindly remove 5 degrees off current n/a tune for a 100 shot. I said a couple of degrees for a 100 shot. 2 degrees per 50 is what has been suggested as a rule of thumb but that is very conservative. What my son and I are both doing is just pulling enough timing for the tune to be safe yet still remain drivable for n/a. I can't tell you where your timing will end up since every system is a smidge different. If you tune correctly and read plugs you can easily remove just enough timing for a safe hit and still remain drivable for n/a. It does't cost as much horse power to accomplish this as you think.
