whats the biggest shot i can run with 91 pump gas?
title says all the only thing i got for my nx kit is tr6 spark plugs and a msd window switch. was wondering whats the biggest shot i can go with on 91 pump gas im in CA.
stock motor my only mods is pacesetter long tube, hooker off road y pipe, cutout, lid and k&n if thats even a mod. im gonna get my air fuel tuned sometime this week also cause the LT's got put in saturday. i dont know to much about compression.
Originally Posted by Magic Chicken
you're good with a 150 shot
You would be safer to spike your fuel with some Xylene (117 octane) found at your local paint supply house. 5 gallons is about $50.
7 gallons 91
3 gallons Xylene (117)
3 ounces of Marvel Mystery Oil
yields 99 octane
* don't add more than 30% Xylene or cold start issues will arise
Or you could simply buy the 100 octane fuel from your local race shop or motorcycle store.
It is worth the extra cost in using quality fuel when doing any form of nitrous/forced induction racing as a buffer and not blow your motor. Changing head gaskets or melting a valve isn't good.
Just my 2 cents.
7 gallons 91
yields 99 octane
Just my 2 cents.
7 gallons 91
yields 99 octane
Just my 2 cents.
7 gallons 91
yields 99 octane
Just my 2 cents.
Jim C.
11 & 7 Second Clubs
200 with a wet shot would be ok.
12 Second Truck Club
Originally Posted by Big Geek
PS- I thought Shell and Sunoco were selling 100-Octane at the pump out there in Cali at one time. Cheers !!!
Jim C.
Jim C.
I run a 150 nx shot on a regular basis at the track on 93 with a walboro fuel pump and tr6's on amoco 93 with out any problems. Ran a 200 shot once but traction was no where to be found and actually ran faster on the 150 shot.
I think you would be fine on 93 octane if your comp ratio isnt that high. Im running LS1 block with truck heads so my comp is 11.3:1 and Im spraying a 100 shot. SInce the summer has cvome Im getting det on hot days with no n20 use so Im mixing 6-7 gallons of 100 octane AV fuel with the rest 93 octane and IM fine even with n20!
