Nitrous Related Wiring
Old Jun 6, 2007 | 10:41 AM
  #41
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by BayAreaSS
Can somebody help me with a wiring diagram for a single stage wet kit.
i have a nitrous outlet digital window switch, heater, purge, opener, and a FPSS.
Thanks.
the heater and opener are on independant circuits
Old Jun 6, 2007 | 10:42 AM
  #42
BayAreaSS's Avatar
Thanks Ray!!
Old Jun 6, 2007 | 10:46 AM
  #43
Ray@Nitrous Outlet
Guest
Posts: n/a
this is the diagram we send with our 4 button switch panel....
System....Purge...Heater...Opener
sorry for being blurry...it was a smaller picture I enlarged
Old Jun 6, 2007 | 10:49 AM
  #44
BayAreaSS's Avatar
Thats everything i need now. I'm just waiting for my plate to come in.
Thanks for taking the time to post those diagrams.
Old Jun 6, 2007 | 10:55 PM
  #45
tha joker's Avatar
thanks for the update
Old Jun 13, 2007 | 05:49 PM
  #46
jetlag's Avatar
Can't the N2Outlets window switch be used as WOT activation also? Why is there one of this diagram? or can I just ignore that...
Also, that green wire on the 87 side of the relay says going to Crane ignition module.. Since I do not have that..would I not use the 87?
Old Jun 13, 2007 | 05:59 PM
  #47
jetlag's Avatar
Or what about the wiring diagram?
Where would the FPSS wire up in this one??
Old Jun 13, 2007 | 06:18 PM
  #48
NXRICKY's Avatar
Closed ex-Sponsor Account
cut the yellow wire,,, So if you loose fps the relay will not click.
Old Jun 13, 2007 | 06:56 PM
  #49
jetlag's Avatar
Ok...sorry I'm not that good with wiring... cut the yellow wire, and put each end on one terminal of the fpss?
Old Jun 17, 2007 | 07:35 AM
  #50
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
what about a diagram for a nos progessive controller (single stage), transbrake, linelock, and synergy two step
Old Jun 17, 2007 | 11:28 AM
  #51
NXRICKY's Avatar
yes
Ricky
Old Jun 19, 2007 | 08:40 PM
  #52
Demon_Speeding's Avatar
Can anybody help me? TNT F1, FJO Dual Channel Wideband (acts as TPS/WOT and window switch as well as shuts the spray down if it goes lean) Harlan 2-step, HSW stand alone fuel and 860 heated bracket.
Old Jun 19, 2007 | 11:10 PM
  #53
jetlag's Avatar
Also..should i put a fuse in this diagram anywhere...or is the relay good for that?
The purge will be easy to hook up..but should I attach a fuse to the power for it also? Or use one of those Add-a-link fuse things for the fuse box...
Old Jun 22, 2007 | 09:59 PM
  #54
Robert56's Avatar
Default ZEX wet kit and MSD WS
Posted by 98TADRIVER
Robert
Old Jun 23, 2007 | 11:51 PM
  #55
Selki's Avatar
Default FJO progressive mini, Timing tuner and FPSS single stage wet
Well first off let me thank FJO for hooking me up with Rick at Trick Performance. He is the reason that I have this at all. Also Todd157k for the help in getting the Timing Tuner hook up figured out. I couldent have done it with out their help.
Some info about the setup:
1. This is for an FJO Progressive Nitrous Mini-Controller part# KWS0022.
2. All stage 1 is designed to do is controll both solenoids.
3. All stage 2 is designed to do is controll the ON / OFF of the Timing Tuner. It still needs to be set according to the directions that came with the unit. If you don't have them here ya go: http://www.fullthrottlenetwork.com/showthread.php?t=907
4. Settings for stage 2:
a. From trigger to cutoff it must be set to 100%
b. Trigger can be before, the same as or after the stage 1 nitrous trigger depending on what you need the timing to do.
c. Cutoff can be set to the same as or after the stage 1 nitrous cutoff depending on what you need the timing to do. I was advised not to set the timing cutoff for before the nitrous stops spraying.
5. All wires are 18ga. unless stated. For theses wires you should not go smaller due to current draw. You could go bigger ie. 16ga. 14ga. etc.
6. For the listed 12ga. wires. This is the min size that they should be. Again you can go bigger if you want.
With all that said. Here ya'll go. I hope that this helps someone.
Attached Thumbnails Nitrous Related Wiring-fjo-progressive-timing-tuner-fpss.jpg
Old Jun 24, 2007 | 07:58 PM
  #56
00 black ram air's Avatar
Default timing tuner wiring HELP
How should my nitrous be wired with a timing tuner? activation switch, timing tuner, wot, then soleniods Or activation switch, wot, timing tuner, then soleniods. I had it the 2nd way last year and it kept backfiring and then I blew an intake off of it, then pulled timing through a laptop and it was fine. I don't know if it wasn't pulling timing fast enough with it wired between the wot switch and the soleniods
Thanks for any help
Old Jun 27, 2007 | 11:03 PM
  #57
NOSjunky's Avatar
Default harlen 2 step
How do i wire up my harlen 2 step to my Nitrous outlet WOT switch where it wont spray while its activated. I have seen several people ask this same question with no luck. I have seen something about a relay or something ?
Old Jun 28, 2007 | 08:51 PM
  #58
NOSjunky's Avatar
Default Help Me
Anyone ?
Old Jul 8, 2007 | 09:31 PM
  #59
Robert56's Avatar
After numerous questions on how to wire the IAT, timing pull trick.
Here is some additional info for the schematic posted earlier.
For years 1999 and 2000, and C5s these are the wires your looking at:
On the PCM Red Connector,
#25 Tan wire
IAT Sensor
#57 Purple wire
IAT ground
So for this diagram,
Tan wire would go to "A",
and purple wire would go to "B".
Now I am not sure if these wires changed in latter years, or prior years (but think at least prior years are the same), but a PCM pinout can be had for any year, if ya do your home work. I haven't used this or messed with it for a few years, so...
Anyway, I hope this clarifies some of the wiring for this trick. Oh and a 750 ohm resistor will pull about 3 to 4 degrees of timing.
Robert
Old Jul 9, 2007 | 08:29 PM
  #60
TXZ0603's Avatar
#25 Tan wire
IAT Sensor
#57 Purple wire
IAT ground
Anyway, I hope this clarifies some of the wiring for this trick. Oh and a 750 ohm resistor will pull about 3/4 degrees of timing.
Robert
Thanks Robert, One question though. Is that pulling 3/4 of a degree or 3 to 4 degrees of timing.
Jerry
