FJO Progressive Controller - Problem
Old Sep 14, 2006 | 12:33 PM
barkingspud's Avatar
Default FJO Progressive Controller - Problem
Folks,
Just finished my N2O install and for the final step I need to program my FJO controller. I installed the software on my laptop per the instructions and connected to the controller. I get an error message on my laptop "Com 10 is in use, please choose another port". Any of you get this message? If so, what was the fix?
I e-mailed FJO tech support yesterday afternoon and haven't heard from them as of yet.
Any insight is greatly appreciated.
Cheers,
BS
Old Sep 14, 2006 | 01:27 PM
wyndzer's Avatar
Find what is using Com10 on your computer and assign it to a different com port.
start>settings>control panel>system>hardware>device manager>ports
Old Sep 14, 2006 | 01:36 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
call me 888-463-2781 and I think I can talk you through it.
Ricky
Old Sep 14, 2006 | 01:42 PM
Ricky
Hey Ricky,
Thanks. I don't have the car right now as it's in the shop for a bunch of engine work but, I will ping you in a few days once I get the car back. I really appreciate the assistance.
BS
Old Sep 14, 2006 | 01:45 PM
NXRICKY's Avatar
you need to go into you system and find the ports.
Start
control panel
system
look for the ports folder. find out what is holding port 10. look at the fjo file in ports folder. It should not be yellow, red, !, ? or a cross throu it.
If it does then uninstall and reinstall...
Ricky
Old Sep 14, 2006 | 07:52 PM
charlie c5's Avatar
NXRICKY is right, and having you call him to help you is going far beyond the norm. I would take his help. He seems to be a great guy to offer it..
Old Sep 15, 2006 | 07:09 AM
Charlie, trust me, I will give him a call. I NEVER refuse help from anyone that is willing. Especially someone with Ricky's reputation.....
Not sure when the car will be back in my garage though. As far as the Com 10 problem goes, When I look in my device manager, it shows the controller on Com port 10 is enabled and working properly that is what has me a bit baffled.
Old Sep 15, 2006 | 01:42 PM
ivandrea's Avatar
If you hot synk your palm pilot through that connection that could be your issue. I had a similar problem with recognizing my software with the hardware because the port was in use. Palm software uploads designate that port and always leave it active, so that whenever you link up it already knows its there.
Old Sep 15, 2006 | 01:51 PM
Yea, I have a Blackberry but it uses ports 8 and 9 so, I should be OK.....
Old Sep 20, 2006 | 08:57 AM
Well, I installed the FJO software on another laptop I have and it worked, no problem. Guess I need to figure out what is going on with PC #1.....
Old Sep 20, 2006 | 09:06 AM
NXRICKY's Avatar
Great to hear its working for you...
On pc1 did you uninstall and reinstall?
Ricky
