View Poll Results: timing tuner/ iat mod/ tune
timing tuner
28
39.44%
iat mod
15
21.13%
tune
28
39.44%
Voters: 71. You may not vote on this poll
timing tuner vs. iat mod vs. tune it out
Old 09-05-2007, 09:02 PM
ls2 bait's Avatar
Default timing tuner vs. iat mod vs. tune it out
which would u choose and why for pulling timing. 150 wet shot. just pull it out of the tune and run it that way all the time or use one of the others.
Old 09-05-2007, 09:07 PM
Dynojet Fan
VH5150's Avatar
I say IAT mod... Its the easiest... Just make sure you flip the switch before you spray..
Ive had all 3 before... Now I can use my efilive or my timing tuner....
Old 09-05-2007, 11:00 PM
Robert56's Avatar
I didn't vote cause dry wasn't an option. you wouldn't have to worry about any of the suggestions in the poll.
Robert
Old 09-05-2007, 11:21 PM
ls1408cp's Avatar
timing twister
Old 09-06-2007, 12:04 AM
mitymikec's Avatar
Robert
Hey Robert how much timing were u using while spraying the 200 and 250 hp shot?
Old 09-06-2007, 11:41 AM
Chris@NitroDaves
Guest
Posts: n/a
I would use either the Timing Tuner or Timing Twister so that away you can run Max timing NA so you can get the full potential of the NA tune and use the Timing tuner to take out the timing as needed for the spray. Thats what i'm doing.
-Chris
Old 09-06-2007, 08:58 PM
minytrker's Avatar
COS#5 with EFI Live, you can run NA then just flip a switch and have the pcm pull timing and run nitrous.
Old 09-06-2007, 09:55 PM
Black99TransAm's Avatar
Im a noob i guess so whats the IAT mod???
Old 09-07-2007, 10:02 PM
02SOMWS6's Avatar
Timing tuner, it has a nos delay as well if needed
Old 09-07-2007, 10:22 PM
SmaknaSS's Avatar
I would never pay for a timing tuner, I would go IAT mod or custom OS if you own EFI Live.
Old 09-09-2007, 09:12 AM
bbradyc5's Avatar
Originally Posted by VH5150
I say IAT mod... Its the easiest... Just make sure you flip the switch before you spray......
IAT mod, is cheap, simple and you can go back and forth with a simple flip of the switch. Or if you want, you can eliminate the need for a separate switch and wire in an extra relay to your nitrous arming switch and have it pull timing when you arm nitrous.
Old 09-09-2007, 10:52 AM
AINT SKEERED's Avatar
does a dry kit pull enough timing from iat sensor?
Old 09-22-2007, 07:14 PM
Robert56's Avatar
I voted tune, however, from the dry perspective. No iat, timing tuner, or n/a timing pull needed. just set up your tune to pull while spraying only and not effect your n/a tune. If it's under a 200 shot and wet, the couple degrees pulled in the tune won't matter much n/a and you'll never notice.
Robert
Old 09-22-2007, 07:47 PM
ls2 bait's Avatar
Robert
thats what i ended up doing. running 24* n/a or on the bottle.
Old 10-01-2007, 07:48 PM
Restricted User
98Z28CobraKiller's Avatar
This is what I am going to do except I am going to wire it to pull timing when the nitrous is actually spraying via the NOS mini Controller. This way, I can set a delay in the controller for the shittier tracks and come out on motor timing until the delay is over. Spray will come in and timing will come out.
Old 10-02-2007, 10:36 PM
david vericker's Avatar
Timing tuner utilizing .4 delay
Old 10-02-2007, 11:51 PM
its turbo time's Avatar
-Chris
thats why i voted timing tuner
Old 10-03-2007, 05:23 AM
JEB99TA's Avatar
That's why I bought one, as well ... also checked out a couple of other nitrous vendors and they told me it's my best option overall for under $300.00. I go with the experts.
Old 10-03-2007, 07:20 AM
Jpr5690's Avatar
I Always Think A Tune Is The Best Answer
Old 10-03-2007, 11:49 AM
i had the tune pull the timing, then the timing tuner add it back in when im off the bottle
Quick Reply: timing tuner vs. iat mod vs. tune it out
