Orygun guys?
#9083
#9090
#9091
Jessica
#9092
I have 3:34's from the factory. I don't know that 3:42's would be enough of an upgrade to be worth it. I'll see if some of the wise ones will chime in here.
#9093
Yes its an older cam profile. Don't always buy into the hype about newer is better bs. Sometimes an old profile will still get the job done just fine. Its more about the total package and how everything will perform together. I had an old MTI X1 grind in my 387 with self ported cylinder heads. That cam grind has got to be 15 years old but at the time (circa 2009) I was trapping 125-126mph, nearing a 10 sec time slip in a full weight car with a 6 speed and no power adders. The key to going fast is getting all the components to work together efficiently as possible.
Mike
Mike
#9094
3.34's? Autos came in two flavors, 2.73's or 3.23's. Unless I am badly mistaken. Mine had 2.73's and I went to the 6 speed 3.42 ratio.
#9095
#9096
Mods as of right now are Lid w/filter, LT's, ORY, SLP LM1, Urethane MM's. The most I want to do, or ask my husband to do is H/C/I. Heads being ported LS6 or something similar and stick with the factory LS6 intake and whatever supporting bolt-ons I haven't gotten to yet.
#9098
I agree however, I get a lot of comments like "that's old technology" and "that cam has run it's course". That is how I've gone from looking at the MS3 and MS4 to the Polluter and now I'm back to not knowing for sure what to go with. This is what I'm looking to do. Very occasionally my husband will be running the 1/4 at PIR (yes I have heard it all about Woodburn being closer and a better track but you get lots of runs in at PIR without the "Pro Racer" Doucher attitude). Mostly the car will be daily driven to work and on date nights for fun. What I want is a smooth torque band without peaky horsepower. I picked 400whp as the goal with torque coming in somewhere close to that. I also want the lopy idle of a muscle car so it sounds mean when I'm putting through a parking lot. So, all the guys who read this and think "women want everything" you are correct!
Mike
#9099
I'd concentrate on cams with less than 230 degrees duration. Anything more and I think you will not enjoy driving the car much. Honestly a 228r single pattern cam would fit your bill nicely and that cam has been around forever with proven reliability and easy on valvetrain parts. Not saying that is the cam for you, just one that came to mind. I had similar goals as you for my Tahoe build. I chose a cam very similar to the Vengeance VRX4, 228/230 and less than .600" lift. Nothing special, no fancy name, just a proven cam.
Mike
Mike
We got a recommendation from Speed Engineering to go with a ss224 or ss228 cam which is probably a lot like the 228r cam that you have suggested. Thank you for spending some time trying to get me in the right place. It's much nicer getting advice from people in the same region as me.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#9100
I have a Comp Cam custom grind 228/235 .614/.621 111+2
T/S stage 2 heads
4k Nitrous converter 4.10 gears
It's a bit rowdy for a daily but I have ran 11.61 @115 with it on motor.
Here's the only video I have of it. It sucks but hope you can somewhat hear it.
Here's another one
T/S stage 2 heads
Here's another one
