Recommended starting VE for bolt ons?
Forum wisdom indicates that the VE tables need only minor tweaking for bolt ons (intake, headers, exhaust in this case) if at all and several of the "headers only" tunes I've reviewed from the repo confirm this.
I'll be tuning with a wideband and applying the AFR Error % to the VE table, does it make sense to start with a more reasonable VE bump, 5%-10% instead of 15%? Or log with the stock table first?
I'm only a "book learned" tuner at this point, looking for some real world experience here. Thanks!
(Also posted on the HPTuners forum.)
But if you do part throttle logging, it's mostly at stoich anyway without any PE enrichment, so you can see how close you are pretty fast without any real danger.
Oddly enough there was an -7% AFR error around the idle zone. Patching this up in the VE table overshot it and made it run lean on the next log so I just put it back to the stock VE for now. Still planning on more logging when time permits.
Thanks all for the great discussion.
Idle has a tendency to do that. When I scan I always make sure I drive the car around for a minute before I log to let temps stabilize, then when you return to the driveway collect data for idle.
Good info on the idle, searched around a bit for that today too and that was the consensus, heat soaked IATs can skew the data. I will definitely remember that the next time I log.
