Any way to insure WB02 is calibrated correctly (i.e. propane gas)?
Is there any way to check that a WB02 sensor is calibrated correctly? I know that you can look at the values while driving and see if they are way off base, but is there anything where you can do "______" and the value of the sensor should be precisely "_____".
I know for example that when calibrating small scales people take a penny or nickle because their weights are already known and don't vary much. Is there a similar thing for o2 sensors? I have heard unlit propane should give a reading of 14:1, but I am skeptical.
I know about the free air calibration, but my problem is this: a free air calibration just tells the Wideband that whatever voltage it is seeing at the moment is that of pure air.
I had issues with my wideband over the past few days where I did a free air calibration several times (took the sensor out of the pipe and everything) but the reading in both LogWorks and on a DMM was CLEARLY wrong. I mean either pegged below 7.4AFR all the time, or pegged above 20.9 all the time, etc. I eventually traced it down to a "ground" wire that for some strange reason had 5V going through it, but basically the free air calibration didn't tell me the sensor was off. It just told the sensor "this voltage means it's in pure air, adjust accordingly".
I'm looking for a way to do a sanity check on the WB02. Meaning is there a gas or something that will give a standard AFR if blown over the sensor?
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
There are reference gas samples that are used for test/
calibrating O2 sensors. $100 can of stale air, anybody?
(I have no idea of the actual price but I bet you wants
none).
none).
But a wideband measures air, not propane or butane etc.
So you need to calibrate it to air.
If you want to run it inline with a methonol engine etc you can check its reading right, but the only way to calibrate it is to reference it against what its measuring.
Calibrating and measuring are the key concepts IMO
Originally Posted by oange ss
which ground is gettin the 5V signal ?
Moderator
From everything I've read the NBO2 and WBO2 are both
oxygen-transport "fuel cells". The partial pressure oxygen
difference across them is what makes the voltage. You
need free oxygen, not bound up in N2O or anything else.
Looks like people use 0% - 10% oxygen reference gasses
to calibrate WBO2s...
http://cafee.wvu.edu/Assets/Document...0Operation.pdf
But the curve is very nonlinear and I think calibration
would be a real "science project"...
http://wbo2.com/lsu/default.htm
PLX devices is all proud about not needing (allowing)
recalibation. Personally I find this pretty questionable
from a "what do you do about sensor aging?" view.
But they do mention that elevation in particular can
skew free-air calibrations...
http://www.plxdevices.com/AppNotes/P...Technology.pdf
Moderator
If you have good, already-functioning closed loop
operation then this may in fact be your best bet.
Just set the thing up with a bit of smoothing in
there to eliminate the chatter, and you should see
the magic number. The narrowbands are trying
their best to make your 14.7:1 reference gas.
May not help if you're way out in the weeds with
the mixture loop open or comatose O2s though.
