2000 firebird v6 to built LS motor questions
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
First off, I would like to thank this forum for it's valuable information and it's search function, as a previous pontiac/gm enthusiast and taking my 3.8L N/A L36 into a M112 hybrid supercharged, nitrous injected FWD burnout box I have experience in rebuilding and swapping engines/transmissions. Obviously I am new to the LS1tech forums as a poster and before now i frequented mostly W-body forums...
Now, I have my next project.. I bought a 2000 firebird v6 with the Y87 package. From the research I can tell I already have the correct driveshaft and steering rack for an LS motor swap, which is only a few of the many things I will need.
My plan is to put an LS1 (346ci) in this car with the correct 4L60E, but my goal is to actually build something along the lines of a forged L92 on an engine stand and eventually put it into the firebird. (I understand the ups and downs of forged pistons, I am not totally against stock/hypereutectic pistons at this point, but I may want boost in the future, however I am only initially after 500-550whp. Cost is somewhat an issue, i'd rather spend small amounts here and there rather than buy a motor built by someone else. I have time, i have tools, I am a machinist, and I would love to build my own LS engine.
I know the v6 to v8 thing has been beat to death, but fortunately from what i have searched the 2000 year Y87 is better than most years for swapping (especially if i can find a 2000 year donor car or wiring/engine).
My question is, am I on the right track? Should I just get an LS1 and stroke it, do L92 or ported heads, intake, an aggressive camshaft, etc... or am i better off going with an L92 6.2 Liter long block and building it for an F-body? Is there way too much to do disabling VVT and AFM on these truck motors and swapping parts/gears out to make this work?
And something I haven't seen yet (i've searched), whether i get headers or not, will the stock exhaust from the v6 "bolt up" to the LS1? Or at least the cat back? I don't know if it has at least 2.5" exhaust or if it will even come close to bolting up? (obviously i know the manifolds/headers won't be reused from engine to engine)
At this point, I am not interested in required (transmission/rear-end) parts to handle the power, i understand the stock rear end (zexel torsen 3.42) probably won't handle much, I am interested in information on making a functional, running v8 car, but more-so what path I should take to do this.
I know I will need a wiring harness from a trans am of the same year and gauge cluster, and other items listed in other sites on threads, but I do not know all of what the L92 would require to be swapped out if i should go that route...
What do you guys think?
Yes, i'm looking for the build to be some-what streetable as well.
Thank you very much for any replies/information and taking the time to read my novel.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
Sounds very familar.
Check out my build thread and it will show you everything that I did to swap my 3.8 into a 6.0 in my 2000 Firebird.
http://www.mifbody.com/vbulletin/sho...Family-Project
Then here is the recent update to the build:
https://ls1tech.com/forums/forced-in...ird-build.html
Good Luck!
Good Luck!
Good Luck!
Good Luck!
You spent an immaculate detail on that car and did a stellar job on everything! kudos!
I don't have any immediate plans on doing THAT much detail to the car itself, but to the drivetrain mostly.
You don't mention much about the wiring except for the IGN 2 fuse issues, did an LS1 harness pretty much work with that LS2? (i'm new to f-body stuff)
I will primarily be wanting to do the minimum amount of changes in parts to get an LS motor in my car, which will obviously mean a new wiring harness (Is there a place it plugs into the cabin somewhere or do i have to rewire the whole car or splice it into the v6 wiring??), trans am/z28 k-frame, transmission, engine (obviously), gauge cluster, fueling, coolant/ac hoses, some way to switch the electronic throttle control to a cable throttle and make my pedal work, and some way to make an exhaust work as i don't know if the stock cat back can be used at all until i can afford a catback on top of this..
Initial plans were to find a motor and start the engine build and once assembled to begin putting things together with the car.
Thank you!
Thank you!
Thanks.
The 2000-02 LS1 engine wiring harness will work fine. It feeds though the driver and passenger side firewall in which there is are connectors.
I swapped my electronic pedals for a set of pedals that accept a cable for the throttle body. They are very easy to find.
Exhaust - I would trash the old system and get headers and etc.
This is a huge but rewarding job, so do your research and take your time.
Good Luck!
The hybrid forum mostly seems to apply to non-LSx vehicles, and while my car did not come with an LS1, there is a version of it (the trans am/formula) that comes with it. I have been reading through there and I appreciate that.
So far my parts list (i'm sure nowhere near complete, but i feel it's close):
Complete engine & accessories
Transmission
Engine wiring harness
Radiator (maybe?)
Fuel pump/lines/regulator (or convert current lines with a vette regulator and use a walbro)
Throttle cables & system (including pedal)
Exhaust (Complete headers to tips? Catback may be too small)
PCM (PCM for an LS1 T/A or Z28 99-02 should be okay?)
TA Gauge cluster (For correct signals and for the 150mph speedo)
Fbody oilpan/pickup (unless motor is out of an fbody)
Z28/Trans am K-Frame & engine/tranny mounts
I made a note to try to get stuff from a 2000 if possible, and i am keeping my eye out for a wrecked LS1 car just in case i get that lucky....
Transmission
Radiator (maybe?)
Kyle, I'm not sure where you are located (shipping would be out of hand) but I have a very clean k-member with motor mount stantions for sale. I went turbo this year so I replaced it with a tubular frame.
I will look this weekend and see what other stuff I have that you may need.
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
![](http://i1134.photobucket.com/albums/m616/jsuzak/Stuff%20For%20Sale/IMG_0004.jpg)
![](http://i1134.photobucket.com/albums/m616/jsuzak/Stuff%20For%20Sale/IMG_0005.jpg)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I updated my garage/profile best i can after a long day of work to reflect my current vehicles. Apparently i never added my location, i mostly have done just reading/lurking on the forums until now.
Thank you BlackBirdDaddy!
