Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
Old 07-26-2013, 05:59 PM
  #1421
JD_AMG's Avatar
Originally Posted by JD_AMG
Hopefully people still check this thread frequent enough...
Just installed a brass gear Ive had leftover for years (I bought both gears years ago when I did the passenger side headlight for the typical nylon gear wear issue) on the drivers side light and now the damn motor is strait up not working... Worked fine before, minus having a stripped gear, now nothing. There is no binding, or anything, everything looks good (wires didn't look corroded but after it didn't work first time around I brushed them off anyway, no effect). WTF... What could have changed literally over night for the motor to strait up not work?
Update. Fixed the issue, I didn't think the wiring harness look all that corroded at all, especially after I cleaned it. Well that was it, I spliced into it and now it works.
Old 07-26-2013, 06:02 PM
  #1422
JD_AMG's Avatar
Originally Posted by Huezzy
Problem here, so I installed the new passenger headlamp motor, but its out of sync or something. The lights turns on when it's suppose to but it flips down when its suppose to flip up and flips up when its suppose to flip down. Any ideas?
Manually raise or lower both headlights so they are the same. Then turn on the headlights, they should be in sync then.
Originally Posted by Toxic Fish 9999
I installed a new driver side head light motor worked perfect for a day now when i turn it on it goes up and down like 3 times the stays half wide open! Does anyone know how to fix this?
Thanks
Check the little yellow bumper things, I bet one fell off. Check the arm while you are in there and make sure its tight and the nut holding it on didn't come loose.
Old 08-11-2013, 04:19 PM
  #1423
99WS6MAN's Avatar
Originally Posted by Wing Zero
There is a way to adjust the level on the motor at the top beside the head light there is an alen (I forget the size- you might need to remove the cover) fittiing to raise the light manuly. It can sometimes work to rasie the light after the lights are up.
Anyone else have this problem? I have the same issue wihere there is 3/8 difference when my driver side light comes up so it looks like a lazy eye.
Old 08-12-2013, 02:05 PM
  #1424
1Bad_Hawk's Avatar
my driver headlight stopped coming up so i manually cranked it up. Now it comes up down but it makes thta horrible noise, im just wanting to know whats the fix for that problem. Ive seen people say buy the brass gears but then ive seen people say dont buy them Help Thanks
Old 08-15-2013, 10:23 PM
  #1425
FCar2000TA's Avatar
Default Rebuilding my headlight motors... how much grease?
Should I fill up the inside of the motor with grease? I'm going to use white lithium grease.
Old 08-15-2013, 10:39 PM
  #1426
gto65lvr's Avatar
if you are replacing the factory stripped plastic gear then no it will be too thin. I think just enough wheel bearing type grease/multi purpose will do the trick. just enough to coat things like when you took it apart.
Old 08-15-2013, 10:46 PM
  #1427
FCar2000TA's Avatar
replacing the plastic gear with aluminum ones.
Old 08-15-2013, 11:33 PM
  #1428
gto65lvr's Avatar
coat them good, just don't pack the motor. Dude that sells those gears I thought supplied a packet of grease with the epoxy. I had to do the same thing with one of my motors. Otherwise a standard wheel bearing grease coating them is good white lith. will not keep things coated too thin
Old 08-16-2013, 12:04 AM
  #1429
FCar2000TA's Avatar
They did come with grease, but I lost it.
Old 08-16-2013, 05:43 PM
  #1430
NC01TA's Avatar
If all else fails, use whatever he is using in his hair.
Attachment 414300
Old 08-16-2013, 06:25 PM
  #1431
FCar2000TA's Avatar
Attachment 414300
I don't think I want what is in his hair these days...
Old 08-16-2013, 07:43 PM
  #1432
Blackpanther99's Avatar
I just lightly coated mine with grease. Havent had an issue.
Bronze gears that is.
Old 08-16-2013, 08:55 PM
  #1433
silverTransAm140's Avatar
Just replaced headlight motor gear on both. when I did a little research on how to do this I didnt see anyone say to do this so I thought I would share. Just take the whole light assembly off the hinges and you will have plenty of room to work. do this by taking off the plastic headlight cover in the front with your lights up. then 4 screws hold on the light cover (painted peice). then 2 bolts for the hinge that you will take off later. you will need a torx for the hinge part. take off the support that goes to the motor first. This is easier if you loosen the tension on it by slightly lowering the light. when this is off finally take the light assembly off the hinge. now you should see what i have in the picture. IF you carefully lay the lights up there you dont have to remove those wires. the third screw for the motor is still a PITA but at least you can see it. to take the motor apart you need to get the wiring free from its holder for more room to work with it. take your time and its really easy fix. I went with plastic gears because I am cheap and dont use my headlights much.
Attached Thumbnails Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE-photo-1.jpg   Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE-photo-2.jpg
Old 08-28-2013, 10:48 AM
  #1434
GNO22's Avatar
Just wanted to let you know that I tried your free fix and it works like a champ. It's only been two days, so I will have to check back in with yas after some time.
I can not thank you enough for sharing your knowledge. It was very detailed and most helpful. That sound was aweful!
Thanks again!
GNO
Old 08-30-2013, 08:04 PM
  #1435
JUSTINSWS6's Avatar
On my 02 trans am my passenger side headlight is only going up half way. Any ideas what it is? The motor is only a year old
Old 09-05-2013, 08:30 PM
  #1436
vanwyk99's Avatar
Default 99 Trans Am headlights wont go up!!!
I went to turn on my lights and there was nothing. No grinding or sounds at all. Checked all fuses and they all looked good. Checked connections they looked good also. 20 min later i tried again and they came up? any idea what this is????
Old 09-06-2013, 07:35 AM
  #1437
MMWS6's Avatar
Searched "headlamp horrible noise" and landed me here. Guys... awesome... just great! Took me all of 10 mins to do the free fix and can drive it again! I refused to move it making that noise.. lol This site has been a wealth of knowledge and again, big thanks here. Very new still to the Firebird scene and imagine you guys just saved me a few hundred easy
Old 09-07-2013, 06:23 PM
  #1438
gnomee's Avatar
Very strange for both lights not to do anything.
The system is pretty straight forward so I would take a look at the switch itself.
There is a DRM(Daytime Running Light Module) that may be in between the switch and the lights but I'm 90% sure it isn't so I vote your switch is going bad.
Old 09-26-2013, 01:33 AM
  #1439
blaze_400's Avatar
Just replace the motors in my 89 formula, now the headlights will come up but they won't go down. Is there a relay that I'm missing are is it in the switch
Old 10-01-2013, 12:45 PM
  #1440
NoSloZ_1's Avatar
is there a way that i can make my headlights stay up all the time? one motor is stripped out and the other one just stopped working all together today.
Quick Reply: Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
